Question about Stryker 20l High Flow Insufflator
Stoped flowing and shows failure notice E 04 - Stryker 20l High Flow Insufflator
I have a 04 trailblazer 4.2 v6. It keeps over heating after high rpms. I noticed a coper colored substance floating in my radiator. I have since flushed the radiator but still have the problem.
How long since u bought it? sounds like a previous owner has put a "rad seal" or "kseal" type product into radiator to disguise a burst rad or cylinder head gasket failure .and its now showing.flushing rad wont help u prob now have poor flow or head gasket failure.get engine compression tested to see
May 19, 2016 | Cars & Trucks
Why does my 04 chevy silverado show a MAF problem, after replacing the mass air flow also temp gauge shows normal 210 temp then drops to 160, also driver side air blows hot and passenger side blows co
Because the vehicle was not diagnosed to find a problem
Parts were replaced for no reason & some of the issues
have yet to be checked out
Sep 09, 2014 | Cars & Trucks
2001 4 wheel dr stoped working the lite that shows ur in 4 wheel doesent even come on
no road surface stated.
try on dirt or ice.
Part time 4wd is not for dry pavement.
driving on dry pavement., causes wind up
or failure to engage
or failure to release.
its not AWD..
i never us my light, i test it offroad first.
for really works , if not , i fix it there.
ask how., (its easy)
Feb 14, 2014 | 1990 Toyota 4Runner
Misfire cylinder # 3, only when in drive and stoped
Make sure that it is an electrical issue or a fault in the cylinder.Remove the plug in cyl 3 to check signs if ignition.If the plug connected externally to test for a good intensity spark.If not check the HT cable to the distributor.Have a compression check of the cyl3,If oils smear is noticed on plug then it must be checked for oil ring failure in this cylinder.
Sep 29, 2010 | 1998 Nissan Quest
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
Mass Air Flow Sensor
If you clear the codes and the MAF code is generated again, AND the connector is OK to the MAF, then replace the MAF. Also, be sure your air filter is ok and the air horn (air flow tubing) from the air filter housing to the throttle body is securely connected and has no cracks in the rubber. If ok, replace the MAF sensor.
Mar 07, 2010 | Suzuki Verona Cars & Trucks
"04 saturn ion problem
check fuses relays and connections to fan first then test fan[s] for failure if good check and test sensors
Nov 07, 2017 | 2007 Saturn ION-2 Quad Coupe
MY DURABRAND TV IS NOT SHOWING
it is due to high voltage section failure.
it is better to call skilled tech to repair it.
good luck.
Oct 11, 2007 | Durabrand DWT1905 TV
Stryker 20l High Flow Insufflator Logo
53 people viewed this question
Top Stryker Science & Laboratory Experts
ray gallant
Andrew Taylor
Andrew Taylor
S J Parkin
S J Parkin
Are you a Stryker Science and Laboratory Expert? Answer questions, earn points and help others
