Question about NAD Audio Players & Recorders
NAD 514: It starts to play some time and the it stops and goes back to the track 1 again
  • 54 Answers
SOURCE: CD-MP3 Player stops after playing a specified number of Track
Check your lens on the laser....is it dirty? IF so it needs to be cleaned....STOP !!!......the laser lens is on the focusing mechanism, which is EXTREMELY delicate.
TO clean the lens, get a Q-Tip and some distilled water ( the lenses are plastic, so do not EVER use alcohol, cleaners, window cleaners,etc... on the lens. These will make the lens cloudy and you will then have to replace the mechanism).
Moisten the Q-tip ( Not to the point where it is dripping, but just moist ), and CAREFULLY clean all dust and dirt off the lens. Wait 10 minutes untill the lens has dried completely and try it then.
Hopefully this solved your problem. Dirt is the enemy of all Optically read formats.
Good luck... Rob
Posted on Mar 13, 2008
tripletauto
  • 1450 Answers
SOURCE: Plays CD 107 minutes and goes back to start
plays 107 minutes or 1minute7 seconds of first track?
Posted on Aug 22, 2008
SOURCE: NAD 5000 CD player
I FIX MY NAD 5000 CLEANING THE LASER LENS USING COMPRESS AIR
Posted on Oct 06, 2009
AJIN G
  • 6694 Answers
SOURCE: Hi Skipping problem with a NAD
hi
There is a diode in the power supply which gives dc supply to the laser focusing coil driver ic . if the diode get faulty this problem can occur. Just replace all the rectifier diodes in the power supply stage. Its better than searching for the exact one. then check the cd player is it skips the tracks. if then also its skips the tracks then you have to change the laser pickup unit.
ok
Posted on May 19, 2011
SOURCE: Nad C542 Troubleshooting
found same problem with mine, solution .. place clean paper over the optic, then a magnet, leave for a few seconds, the build up of static causes a magnetic field in the optic preventing it tracking, have cured a few other brands with this as well .. shows manufactures are putting inferior parts in to their players, hope this helps !!
Posted on Apr 20, 2013
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
Sound distortion with NAD T 514...
You are probably clipping in that midrange. Since the DVD player is fine and CD player is distorting: they are line level outputs, If you are running those through an equalizer- the equalizer should allow you add in a 10db attenuation.
If you are running them straight to the amp, The CD line level output should be about 1.5 volt peak to peak, it may be the line level input of your amp is only 1 volt and the DVD player simply has that level of output so does not clip..
Simply adding into the cable a 0.1 microfarad polyester capacitor for each channel should be enough attenuation to avoid clipping. The midrange is where you hear the most content in large part because that is the range that the human ear is most sensitive to. Which is why that portion clips. The DVD audio is actually recorded to the same specs as CD audio. You can confirm this by playing your CD disk in your DVD player. .
Sep 25, 2012 | Audio Players & Recorders
Hi. Hope you can help me out here. Some1 is offering to sell me his NAD C521i CD player. Its been with him for 5 years. Is it wise to get it since it is already 5 years old (at least that i what the guy is...
This cd player sound great but have in mind it is fitted with NE5532 op amps in linedriver stage, but single trafo supply, and this player is a standard production line cd player. I owned one, i liked the NAD sound, and i think if you pay something like $100-$130 you will be happy. Also you ask if you shall be aware of something, in older nad cd player displays is sometimes defect, but easy to fix. Also the laser need to be adjusted often. (as in most cd players.)
Step from track 1 to the last traack fast and back to track 1 again, listen to music parts from track 1, track 4, track 10 track xx.
If the sounud is not choppy, if there are coming sound in both speakers and otherwise it sounds good then i think you can buy it without expecting major problems.
Oct 03, 2011 | NAD C521 CD Player
Nad cd541i doesn't always read cd's; it can tell me how many tracks/minutes there are but won't find the beginning of the cd; in this case, sometimes if I skip forward two or three tracks and...
It sounds like a physical problem in the laser seek mechanism. Possibly a sticky area on the guides. Heavy reading for all malfunctions related to optical disc...
http://www.repairfaq.org/sam/cdfaq.htm
May 19, 2011 | NAD C542 CD Player
Hi Skipping problem with a NAD C545BEE, plays OK for 1 minute, then skips randomly wthin the track, then will skip to different tracks on the CD, like fast forwarding. No problems with the disc themselves
hi
ok
May 19, 2011 | NAD C545BEE
Player stops mid track and shows ''no disc''.
HELLO
Have you tried cleaning the lens? It's incredible how a dirty lens can cause so much grief! You'll need the CD player cover removed and powered off then get some isopropyl alcohol and a cotton bud. Wet the bud but not too much get any excess moisture off.
Using a careful circular motion clean the lens, let it dry and try the player again. If this does not cure the problem, you may have a defective laser and that will need replacing.
ALL THE BEST (:-)
Oct 04, 2009 | Audio Players & Recorders
NAD 5000 CD player
Nov 06, 2007 | Audio Players & Recorders
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
