Question about Estate EED4400WQ Electric Dryers
Estate YEED4400WQ Dryer - The wall plug has power, the timer has power but no power @ the on switch. Even when pressing it on and off no power. What keeps the switch from getting power? Would the door switch/ Thermal Fuse / Thermistor stop switch power?
  • Estate Master
  • 2,699 Answers
Yes,usually people don't know that the dryer and vent line has to be cleaned out,if it's gas it should be done at least once a year,electric 1 1/2 years,so you don't have a fire and so none of the t-stats will pop.if the dryer isn't taken apart and the lint filter duct,the cabinet where the motor is and the vent line isn't cleaned out you will have bad air flow,the dryer will run hotter than normal and the t-stats are made to pop if this happens for safety reasons.your lint filter is on top so unplug the dryer,pull it away from the wall,remove the vent line,remove the back panel,now pull out the lint filter and remove the two phillips screws in front of it,go in the back and on the left side you'll see the metal duct the lint filter slides into,remove the four screws,they are 1/4 or 5/16 inch screws,clean out the duct and any lint you see in the back,also if the duct doesn't pull out completely push it to one side and clean off the top vent,now look to the bottom right of the duct,youll see a white piece with two wires,that's the thermal fuse,check that with a meter,you always have to remove at least one wire when checking a part,set your meter to say 20k ohms,touch the leads together,you should get a reading,now touch the leads to the fuse part 3392519,if it stays at 1 the fuse is bad,any other reading it's good.if it's good go to the heater box,start at the top,pull at least one wire off and check it,part number 279816 this is a kit,you change this t-stat and the one on the bottom.if the top t-stat is good check all the others.if all these check ggod you could have a bad timer or motor but this is unussual.after you clean the back and find the problem go to the front,with the two top panel screws out,you want to pop the top panel,get a screw driver,stick it into the space between the top and front panels around two inches from the corner,push down on the screw driver and pop the top up,do this on both sides,now you'll see a 5 /16 inch screw one on each side a few inches down from the top,remove them and disconnect the door switch wires on the right side,a small screw driver can be slid in between the plastic to separate the wire harness,now tilt out the front panel and pull up one side at a time and remove the front panel,with a shop vac vac up any lint,then set it up to blow and blow all the lint from the back to the front so you don't have to pull the drum,blow off the mmotor too.put it back together,now go outside check the outside duct or hood,if anything is blocking it remove it like a cage or screen,go back inside,i use a leaf blower,stick the leaf blower into the vent line that you removed from the back of dryer and blow it outside,hope this helps,if you need any other help let me know.sal de.
http://www.youtube.com/watch?v=xGIG8Wo5-N4
Posted on Oct 13, 2013
  • Sal De Oct 13, 2013
    first thing you want to check,open the door and make sure the door switch isn't broke,just push it in and out,if it doesn't pop out on it's own it's broke and is your problem,if it's good go to the back of dryer where the cord connects and make sure you have 240 volts going to dryer,if checks good do the other steps i told you to do.
  • 185 Answers
SOURCE: Estate Dryer Model TEDS680EQ1
check the thermostats and see if your belt is still there if not put a new belt in
Posted on Mar 25, 2008
  • 1073 Answers
SOURCE: Estate dryer won't come on..
check the white thermal fuse on the blower housing
Posted on Apr 26, 2008
jsrock516
  • 5911 Answers
SOURCE: Wall plug is 3 prong, dryer is 4 prong...is there an adaptor available?
The following link explains the wiring scheme for 3 and 4 prong power cords. I know the instructions are for converting from a 3 to a 4 prong, but if you look under the "Additional Notes" section it explains how to convert back to a 3-prong if you are currently using a 4-prong.
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. If you have any questions, please let me know.
Posted on Aug 13, 2008
  • 949 Answers
SOURCE: My dryer will not come on period and The
The thermal fuse is located behind the back panel just to the left of the exhaust opening (looking from the back), it is white in color and has 2 wires (usually blue) going to it.
If you dryer comes on sometimes I would suspect this is not the problem.
The symptoms you describe most often are a loose wire or a bad motor.
Posted on Apr 24, 2010
jsrock516
  • 5911 Answers
SOURCE: my dryer is an estate whirlpool dryer does not
I'm assuming from the symptoms you posted, that the dryer does run, correct? If so, the fuse box may have checked out, but have you also checked for the correct voltage at the wall receptacle? A dryer will still run, but will not heat, if its missing a portion of the input voltage. The reason is that the drive motor only uses 120VAC to run, while the heating circuits need the full 240VAC service. If you are missing one leg of the input voltage, the dryer will exhibit the symptoms you describe. In addition, depending on when your home was built, some houses use two separate breakers that feed the 240VAC source the dryer needs to run. Have you checked to make sure there isn't more than one breaker that feeds the dryer? If you have checked for the correct voltage, have you also checked the continuity of the power cord to the terminal block? A broken power cord can give the same symptoms.
If the model number is correct, this is a very simple dryer to work on. There are no other switches or relays, other than the door switch and the built in centrifugal switch inside the drive motor. If the door switch were bad the dryer would not run at all. If the centrifugal switch in the motor were bad, the dryer may or may not run (depending on how it is faulted), which may give you the symptoms you describe.
When you checked the components, how did you determine they were good? If you need assistance (just to clarify your measurments), the following two links can give you some tips on how to troubleshoot this problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
I hope I'm not insulting your itelligence. I ask these simple questions, because they are things that can easily be overlooked. If you need further assistance, please post back and elaborate a bit more on your symptoms, so i can provide you with a more definitive answer. I hope this information was helpful to you.
Posted on Jun 30, 2010
Motor will not run
The heater is not supposed to come on unless the motor is running. The cent switch inside the motor powers up the heater. You must have a shorted element and that is probably what took the timer out as well.
Here is HOW IT WORKS
Another interesting video I made is estate dryer no heat which I show where the fuse and all is. The fuse by the way ties into the door switch and is mounted on the blower housing.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 09, 2013 | Estate TEDS840JQ Electric Dryer
Change cord on estate whirlpool dryer to fit outlet in wall
If this is an ELECTRIC dryer, the following link explains how to install either a 3-prong or 4-prong power cord:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If this is a GAS dryer, the standard color code for a three prong grounded plug is:
BLACK - HOT
WHITE - NEUTRAL
GREEN - GROUND
If you have any questions, please post back and let me know. I hope this helps you.
Jun 23, 2011 | Estate Dryers
Whirlpool estate teds840jq2 dryer just stopped working. I can hear a clicking sound from the timer when the timer is turned to a setting but when I press the start button, nothing happens
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Estate TEDS840JQ Electric Dryer
Estate TGDS680EQ3 gas dryer blows cold
The timer is stripped inside and needs to be replaced. The cogged teeth are made of plastic and a tooth or two has broken off keeping the timer from moving while running
Jul 16, 2010 | Estate TGDS680EQ Dryer
Young dryer quits in mid cycle.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 05, 2010 | Estate EED4300TQ Electric Dryer
Estate dryer wont engage
Check the following--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Dryer is getting Power but not coming on.
Check the following---
Jun 01, 2009 | Roper RES7646KQ Electric Dryer
Aug 13, 2008 | Estate TEDX640JQ Electric Dryer
Apr 26, 2008 | Estate EED4300SQ Dryer
Estate EED4400WQ Electric Dryers Logo
91 people viewed this question
Top Estate Dryers Experts
Tim Whalen
Terry Schneider
John Tripp
John Tripp
Are you an Estate Dryer Expert? Answer questions, earn points and help others
