Static on my sylvania tv, how can I fix it? - Televison & Video
How to fix speaker in Sylvania projection clock radio SA 85018 2
if it is too loud it will make static and make a weird noise in the speaker my arlarm clock(very old) does that but when i turn it down it stops the static and the noise.
May 03, 2016 | Sylvania Audio Players & Recorders
Sylvania lc320ss8 horizontal bar discoloration
Do you have tv repair exp. If not then take it to a shop.If you do then reseat the plugs on the T Con board ( Timing Control). If that don't fix it then go on E-Bay and get a price on a used T-Con board and try that. Those boards have a high rate on going bad.
Jan 13, 2014 | Sylvania LC320SS8 32 in. LCD Television
I can't get my Comcast remote control to sync up with this sylvania 32in HD tv. I tried every code in the Comcast DVR manual under sylvania tv's and nothing, I would love a fix to this problem.
the tv is likely to be generic in nature i.e. parts used by many manufacturers. if you knew what tv builder actually designed it you could find the code. does the remote have a search feature if so use it, it should find something that operates most tv functions eventually
Mar 09, 2013 | Televison & Video
The front panel on my SRT2232S Sylvania TV has began acting weird. The menu button will turn up the volume and the volume buttons change channels. When I let go of the menu button the volume goes back to...
This can be due to moisture build up or dirt accumulating with a static charge to induce voltage and so change the customer control panel switchings.
You can try with a good cleaning of the board and panels. Make sure to dry if moisture is seen. Also check for static conducion of high voltage to the control panel that can induce the inputs to work erratic.
if not check the processor section- processor damage- and the board for a possible weakness.
Oct 09, 2011 | Sylvania SRT2232S 32" TV
Sylvania MTS/SAP TV. I don't have a remote I accidentally hit the ''menu'' button on the front. Now I can't get the TV to show anything but static -- like there is no signal coming in from receiver...
I accidentally hit the ''menu'' button on the front. Now I can't get the TV to show anything but static -- like there is no signal coming in from receiver (either through input jacks on front or on rear. Menu gives various options, but none of them gets me back to being able to see the picture.
Apr 07, 2010 | Sylvania SRT2232S 32" TV
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
Programming it to a Sylvanvia TV model 6420FF
Hello thank you for choosing FixYa.com for your answer my name is David.
I have found a list of codes for the rcu600m for the sylvania tv here they are
Code For Model RCU600M
Code 004 for Sylvania TV Code 006 for Sylvania TV Code 008 for Sylvania TV Code 019 for Sylvania TV Code 062 for Sylvania TV Code 068 for Sylvania TV Code 069 for Sylvania TV Code 075 for Sylvania TV Code 076 for Sylvania TV Code 077 for Sylvania TV Code 088 for Sylvania TV Code 116 for Sylvania TV Code 130 for Sylvania TV Code 132 for Sylvania TV Code 134 for Sylvania TV Code 161 for Sylvania TV Code 183 for Sylvania TV Code 196 for Sylvania TV Code 353 for Sylvania TV Thank you again for choosing Fixya.com
Nov 08, 2008 | RCA RCU600M Remote Control
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
