Question about Samsung HP-T4254 42 in. Plasma Television
Samsung hgtv 1080i won't work
Tv just went off and won't come back on
Re: samsung hgtv 1080i won't work
Look, You only have to open the TV.. Then put the Sink Bulb in the connection cable you can buy it in E-bay or in MercadoLibre for 799,99$ Cheap Price
Posted on Aug 05, 2009
I had the same problem....long story, but with some help I found it needed a power supply. Bought one on E-bay used for 55.00 feel free to contact me
Posted on Feb 10, 2009
0 characters
3 Points
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from
The power light keeps flashing and the tv wont turn on - TV ...
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - > Technology > Television & Video
Jan 03, 2016 | Flat Panel Televisions
I have a 47" Visio 1080p. Tv is always set at hdmi
AV inputs are for standard analog video which is 480i. HDMI and Component inputs are the high definition inputs that run at either 1080i or 1080p You won't ever get 1080i or p through AV inputs.
Oct 22, 2012 | Flat Panel Televisions
I have a 42" Samsung
This clacking and clicking noise could have been coming from a capacitor going bad in the tv. If this is the case where the tv will not turn back on, I would suggest calling samsung to try to get a replacement or get the tv serviced. Trying to replace bad capacitors can be a tedious job and requires knowledge of soldering small components. This may also void your warranty if you still have coverage.
Aug 19, 2011 | Samsung PN42A400 42 in. Plasma TV
I have a Sharp TU-T2 freeview HD set top tuner. I inadvertently set the HD output to 1080p but my TV only accepts 1080i. An error message "out of range" appears whenever I switch on the set top...
Here is the correct solution from the user manual:
Hold the HDMI button on the remote control for 5 seconds to reset the output to 1080i
Worked for me.
Aug 13, 2011 | Sharp Flat Panel Televisions
How do I change the resolution on my samsung ua32c4000
The TV resolution is controlled by your VIDEO sources, if you feed nit with 720P it will display 720p, 1080i in 1080i dipslay if it capable of 1080i. It is not set at the TV, just like the resolution setting of the monoitor which is doen on the PC not at the monitor.
Failed TV and Monitors:
Oct 24, 2010 | Samsung Flat Panel Televisions
Samsung lcd 720 ln32b360 doesn't fill screen in 16:9 mode. Went through tv setup, connected it to hd box (verizon Fios) plays all HD channels but does not fill screen as it should. TV is connected to set...
If by regular cables you are talking about the standard red/yellow/white composite cables, then, yes, it will affect HD as composite cannot send an HD signal. Only HDMI and component (red/blue/green video only) cables.
Change to HDMI and let us know if it works for you.
Jan 07, 2010 | Samsung LN32B360 32 in. LCD HDTV
I have a samsung LN52A550 LCD tv set and it won't show anything with a HD signal. If I hook up a 480I signal the tv will work,but if I hook up the tv antenna or any other hd source to it,the tv goes crazy...
Get a roof or digital antena.Will give u better signal.HD 1080i CBS,NBS check that if u have that in 1080i well able to get HD on the set.U might have a 720p tv set.
Dec 15, 2009 | Samsung LN52A550 LCD TV
Samsung sold the LNS4695DX/X as a 1080P TV it only 1080i
Nothing broadcast in 1080p....nothing. You probably just need to set your blu-ray player to output 1080p most will default to low resolution. A 1080i max TV is very rare these days.
Jun 10, 2009 | Flat Panel Televisions
Picture shifts to left
I had the offset left issue for non-HD channels with my Panasonic 42" plasma, using Comcast HD cable box. Went into the configuration menu (to get there with the newer Comcast boxes, you have to turn the box off, then hit the menu button on the box immediately after). You will see on the menu a resolution (probably says 1080i), then below it a "4:3 override". Our said 480i. When I changed it to "none", so that it stayed 1080i, it worked! It also works by selecting 480p, but then the picture is stretched.
Mar 13, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Samsung HP-T4254 42 in. Plasma Television Logo
340 people viewed this question
Top Samsung Flat Panel Televisions Experts
xxxxxx xxx
Steve McIntosh
Level 1 Expert
Steven Wander
Steven Wander
Are you a Samsung Flat Panel Television Expert? Answer questions, earn points and help others
