Question about Panasonic KX TG6511 Cordless Phone
Www panasonic com help
After charging the base and phones, I cannot get a dial tone to use the phone, what is the problem?
  • 45 Answers
Make sure that the handsets are registered to the base.
if not, look at handset registration in the user manual.
Posted on Oct 29, 2013
SOURCE: Almost constantly gives "no link to base" message
I had this problem too. I popped the battery out, waited 1 minute then put it back in. Unfortunately this clears the memory of all recent calls, etc. but it immediately started working again. So far its only happened once...
Posted on Mar 31, 2007
SOURCE: Link to Base
unplug both wires at back of base and replug after about 5 minutes - it should work now
Posted on Jan 02, 2008
  • 12 Answers
SOURCE: i have no dial tone on one line. call my number and it rings
IT IS DUE TO NETWORK FAILURE OF THAT LINE
Posted on Jan 05, 2009
SOURCE: Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Posted on Sep 10, 2009
Testimonial: "This responder did nothing but repeat my initial post and yet gets credit for a solution?"
  • 5 Answers
SOURCE: My cordless phone says No link to base Move closer
This is the usual message that the phone gives when the battery has died and it has lost connection with the base unit. The usual fix is to remove and reinstall the battery, then place the unit on the charger for a full charge. This will usually fix the problem that you discribed. If after a full charge, you still get that message, you will most likely need a new battery. Good luck...
Posted on Nov 06, 2009
I have a Panasonic phone with one extension. I cannot get a dial tone and the base says phone in use. Can you tell me why??
Hello. You probably did not hang up one of your phones. Check all the phones associated with that Panasonic base and make sure none of them are in use . If one phone is left on none of them will have a dial tone.
Please let me know if this was the issue.
Jul 02, 2017 | Panasonic Lands Phones
Where can I get a telephone manual for Panasonic KX-TG2205W
Hope this helps
Panasonic Telephone KX-TG2205W User Guide ' ManualsOnline.com
www.manualsonline.com > ... > Communications Panasonic > Panasonic Telephone
2.4GHz Digital Cordless Phone. Model No. KX-TG2205W. Pulse-or-tone dialing capability. OperatingInstructions. Charge the battery for about 15 hours before ...
Apr 02, 2017 | Panasonic Lands Phones
No dial tone on hand set battery is new lights up
Make sure your connection to the phone jack is secure.
Use another wired phone to make sure connection is good to your phone.
Secure connection in back of phone, and plug it in. The base MUST have power to transmit the signal to the handset even if the handset has a fresh charge.
Although the handset is normally linked to the bases, check to make sure via the instructions. To determine if the base recognizes the handset, press the "LOCATE HANDSET" button.
If the hadset responds, the links is there.
Hope this helps
good luck and don't forget to vote!!!
Sep 27, 2010 | Panasonic KX-TG2356 Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
No dial tone
Try disconnecting all units plugged into telephone service. ie. phones, computers, fax machine, sat. rec etc. Then take a known working wired phone to check for dial tone in each of the jacks. Plugging in each unit one at a time, you should be able to find your bad equipment. Disconnect bad equipment and reconnect remaining.
Apr 16, 2009 | Panasonic KX-TG5230M FHSS GigaRange...
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Panasonic KX TG6511 Cordless Phone Logo
50 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
