Question about SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive
I see the light on the simpletech but the computer does not recognize it. How can I open and see what I have stored inside.
lykin2005
SOURCE: COMPUTER DOES NOT RECOGNIZED SIMPLETECH EXTERNAL HD
If your External HD is not regerstering it might have errors in it, I had this problem with my Simple Tech 500gb pininfarina and heres the steps that finnaly after days of trying to figure out it worked:
(Before starting make sure to disable your screen saver)
1. Restart the computer without the device plugged in to start fresh
2. Wait till it loads up and NO OTHER PROGRAM IS RUNNING
3. Plug the usb into the device then the computer usb port
4. Plug in the power to the device and wait till all the lights are cycling if they do
5. Now open the command prompt
6. Type in “Chkdsk /f N:” or whatever letter your device is in and let it run if its not moving don’t do anything till it is complete.
Mine was fixed after letting it do it for about an hour of just sitting there it had a lot of errors in the HD
Hope it helps
Posted on Jul 09, 2009
SOURCE: computer does not recognize simpletech
I have a simpletech external drive that was working, but after i disconnect it unproperlly, i was getting the message <usb not recongnize>. I called simpletech, but customer service is ****, and anyway the drive inside is a hitahi, i have another simpletech and the drive inside is a western digital, whatever...
They told be to go to best buy to make a recover, so i called and they told me it s 250$, and if they cant do it, they will send it to a labotory witch cost 1700$, crazy ******* hein?
I red about getting drivers, putting the hdd in a fridge and much more stupid thing, BUT THE SOLUTION IS SIMPLE, OPEN THE CASE, UNDER THE ALLUMINIUM STICKER THERE IS 2 SCREWS, REMOVE THEM, OPEN THE CASE, TAKE THE HDD INSIDE OUT AND REMOVE THE ADAPTER CONNECTED TO THE HDD(WHERE YOU CONNECT THE USB CABLE) CAUSE THIS IS THE PART CAUSING THE PROBLEM, THE HARD DRIVE IS OK AND YOU DIDN T LOOSE NOTHING. So now what you can do is just buy a new case for laptop hard drive (with a new usb adapter included), or buy another simpleshit hdd and switch the adapter part or just buy an adapter to make your hdd an usb hdd and Voila, and after that i suggest you buy yourself a better hdd than simpleShit and make a new backup.
Posted on Jul 25, 2009
  • 146 Answers
SOURCE: The computer does not recognize the Simpletech
not all usb devices work on all machines
You need to find a driver or ask simple tech what the issue is i had the same issue with My WDC drive Western Digital gave me a driver after emailing them
Posted on Aug 14, 2009
  • 788 Answers
SOURCE: simpletech 160gb
I would guess you are useing USB.
If correct, try a differant USB port.
The USB port you are useing may not be configured for USB2 speeds.
Posted on Sep 21, 2009
  • 113 Answers
SOURCE: hi i have a simpletech 160 gb mini hardrive....my
> try to check the connection,also try to connect it to a working computer
Posted on Jun 14, 2010
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Simpletech 250 GB Pininfarina was knocked on the floor
oped it, maybe loose cables or connections. or the worst case, a faulty hd. ticking sound means bad drive, cannot read disks. retrieve data? the better chance will be a recover technician, dont try anything else, will turn a worst problem.
Jun 02, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
Hi, I have a simpletech/hitachi signature 160 gb external hard drive. It was fne until yesterday. Suddenly, my laptop is not recognizing it. what do I do?
Connect it to a different computer.
If it works, then connecting to _your_ computer is the problem.
If it does not work, then either:
* the USB-to-disk-drive adapter inside the casing has failed, or,
* the disk-drive inside the casing has failed.
Open the case, and remove the disk-drive, and connect it as a "slave" disk-drive in your computer, to see if the disk-drive itself is "good" or "bad".
Google-search for "Data Recovery Services" -- these are commercial, high-cost, companies, that can temporarily repair a "dead" disk-drive, just long enough to try to copy all the files from the disk onto a new disk-drive.
Jan 24, 2010 | SimpleTech Signature Mini 160GB External...
Six month old Simpletech 500 GB ext. drive not recognized
I had the exact same problem. Solved by removing Simpletech drive from the 'flashy-box'. Unplugged drive from internals and threw the 'Pinnaferrina' case away and installed it on my motherboards extra sata plugin site (if it has one). If you open your computer case it should be labled on the Motherboeard as such. Mine has four. On the first attempt when I started the computer i Had no OS system showing on first boot-up. Shut off computer and power and shifted SATA (RED Cable) to another Sata plug on Motherboard and it booted right up and I had the drive back. You will need a longer Sata cable than the attached to the Simpletech drive and a power cable that matches the one on the Simletech . Forget looking for the drivers on the net and the Simpletech web site was no use.
Oct 10, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
SimpleTech 500 GB external hard blinking red light
I got one with the same problem. I opened up the case and hooked up the hard drive to a generic usb to sata adapter that i picked up on ebay and it works fine now if a bit clunky looking.
Sep 10, 2009 | SimpleTech 500GB SimpleDrive Pro External...
I have a simpletech 1TB ext. hard drive BOM No.
You need to install the hard drive driver for the PC to recognize it. If you don't have one, just look in the internet for a free driver.
Regards,
Jeep Brainy
Aug 14, 2009 | SimpleTech 1TB SimpleDrive Pro External...
Computer does not recognize simpletech
Assuming Windows, try the Device Manager and see if the (old) disk is listed there in the disk drives section.
If so, right-click it and select Uninstall. (do this while the new driver is disconnected)
That should force Windows to recognize and reinstall the new drive when you plug it again.
For other causes check out the external hard disk problems.
Apr 20, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech 80 GB Portable HD Won't Read
It sounds like a problem with the board inside the case,- the actual hard drive is probably OK. Opening the case will void any warranty but there may not be much left anyway. There should be 4 screws in the bottom of the drive,- front 2 may be hidden under a sticker. Try installing the drive in your new case or an empty drive bay inside your computer. I have had external hard drive cases fail before and the actual hard drive was ok.
Jan 23, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech PininFarina external hard drive - site to download drivers
the hard drive you have is plug n play.
if windows does not recognize it, you may have to uninstall the hard drive.
right click your computer. click properties.
click on the "Hardware" tab. Click on "Device Manager".
open the category of "Disk Drives".
If you see your drive with a yellow exclamation point or a red "X", continue. If it does not, either it was dropped or its a faulty drive.
Right click your drive and click "Unistall". Click OK.
Now, unplug the drive and plug it in again.
it will install by itself.
Go to my computer and check that its there. If its not, you may have a bad drive. either send it for a new one (if still in warranty) or replace it.
Aug 12, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive Logo
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
