My brother MFC-J425W printer won't detect the new
My brother MFC-J425W printer won't detect the new black cartridge the came with the printer. Help please
  • 25 Answers
Try taking all the cartridges out while the printer is on then turn off at wall for about five minutes,turn on then insert cartridges.maybe the sensor inside the machine thats had it as well
Posted on Oct 30, 2013
  • 3 Answers
SOURCE: Brother DCP-165C Printer not printing black
dear sir,
1- replace cartridge
2- HVPS replace
your problem would be solved.
Posted on Feb 16, 2009
bob_computer
  • 3153 Answers
SOURCE: not detecting ink cartridge - or saying empty - Brother MFC 240c
Is it an ORIGINAL BROTHER cartridge ? ?
OR
A cheaper version ? ?
Posted on Aug 22, 2009
  • 127 Answers
SOURCE: Brother printer won't recognize ink cartridge.
I use generic cartridges all the time in my brother printers with no problem. better to pay $2 per cartridge than whatever the brother brand ones cost!
Posted on Jan 05, 2010
SOURCE: I have a brother mfc-295cn printer that won't print black
Mine wouldn't print black either on Plain Paper, but if I changed the settings to Transparency Paper type it would. Hope this helps
Posted on Dec 14, 2010
SOURCE: I have a brother mfc 295CN printer . i just
How do I get my printer to acknowledge the new "M" ink cartridges?
make sure you remove the yellow sticker from the cartridge. insert cartridge till it clicks and the lever goes into the up position. close door. if it doesn't detect it there is something wrong with the printer.
If that doesn't work there is a mant mode that your printer can go into for field techs to reset counters and other advanced features. Here is a link to the service manual for your printer. The Menu you want to get into is called maintenance mode and is accessible by unplugging the printer and holding a button and reapplying power. Here is the PDF with the instructions for working on your printer.
http://support.brother-usa.com/Virdata/Content/en-US/MFC/Technical/ServiceManual/SM_MFC_J280W_J425W_J430w_J435W_J625DW_J825DW_J835DW_EN_5063.PDF
Good luck. It will look intimidating but no worries it isn't like the printer is working now so you can't get much worse.
Dec 22, 2014 | Brother MFC-J425W
Clean print heads brother MFC J425W
This is what I figured out to get the printing back to normal.
Open up the printer so you are looking at the place where the print heads go back and forth, you will also see the paper feeder. In the back left corner is where the ink is dispensed. There was build up on mine. As usual grab a 10 or so q-tips and some rubbing alcohol and clean the build up of goopy ink.
You won't ever get it completely clean because more ink will keep dispensing. Close it up and run a test print again.
Jan 25, 2013 | Brother MFC-J425W Inkjet Multifunction...
Won't print black
TRY CLEANING THE INK CARTRIDGE. If it doesnt work, go to service center with the printer.
Jun 30, 2012 | BROTHER INTERNATIONAL CORPORAT BROTHER...
Brother MFC-295CN printer was stored for 2 years. Black ink won't print now no matter if brand new cartridge.
this work for me with a mfc 255cw. why it works I don't know but I will continue to use this setting. thank you
Jun 05, 2012 | Brother MFC Office Equipment & Supplies
My Brother LC61, bought in Nov.2010, won't print black. Recently replaced black ink along with all color inks...replaced black ink again when it quit printing...still won't work. Machine whirs...
This is common problem with Brother Printers. I am going to assume you are using Non-Brother branded ink cartridges. Brother cartridges have a cleanser in the ink that most generic cartridges don't have. This in turn causes the jets to clog and not allow ink to pass through them. The fix is to go buy a couple of Brother cartridges and do a cleaning with those cartridges. You may spend some money doing this as a cleaning wastes a lot of ink, but it will clean the injection lines and fix the printer. You could also consider buying a new printer. I know this is not the answer you were looking for, but it is the true answer. I just bought a new printer due to this fact.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Brother Multi-Function Center MFC-240C...
Won`t recognize new ink cartridges. Still insists black is empty, other colors low, although all have been replaced. Any way to reset or override? Thanks
Hi there
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need: · Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 03, 2010 | Brother MFC-230c Printer
I cant get the black print,after putting a black cartridge in,can you help please...brother 135c
Dear sir.
If your black cartridge is original
then it is problem printer black ink head
change it and buy a new one
Thanks
Tareq
Aug 26, 2009 | Brother DCP-135C Flatbed Digital MFC...
Not detecting ink cartridge - or saying empty - Brother MFC 240c
OR
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
113 people viewed this question
jasbo
jasbo
