Rheem RAKA-060JAZ trouble question
My Rheem RAKA-060JAZ doesn't work. The inside fan works fine. Nothing outside turns on. I have replaced the capacitor, the contactor, and the fuses. When the thermostat switches the A/C on, the contactor button goes down, so I know its getting power to the contactor. What other component could it be? thanks
  • 148 Answers
If you get 24v to contactor and it made you should have 220v to compressor and condensing motor. you may call me 9015501503
Posted on Nov 12, 2013
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 53 Answers
Pls check for compressor shorting and relay issue in pcb
Posted on Oct 15, 2013
darjr
  • 378 Answers
SOURCE: a/c unit not working
So only fan is running, the compressor not running okay check the voltage going to the compressor. The connection is coming from Thermostat or temperature controller, if there is supply going to A/c Comp. check the safety thermostat relay above the compressor.
Posted on Jun 01, 2009
  • 7 Answers
SOURCE: On outside compressor for whole house
There should be a wiring diagram on the back of the access panel. If you can't read it, check online for model wiring diagram. Don't guess, you may cause more expensive damage.
Posted on Jun 26, 2009
jeffbvegas1
  • 520 Answers
SOURCE: Rheem outside a/c fan won't turn off
I would probably start at the thermostat and see if 24 volts is continued to be applied to the yellow wire which calls for unit activity even though you have called this off. Shorting the cool (yellow) wire to the return (red) wire will cause the HVAC system to begin cooling and the fan will be turned on automatically.
Posted on Aug 23, 2009
  • 1151 Answers
SOURCE: outside fan runs constantly Aux Heat only 50%
Let's start out by your statement that the fan would not run, then you changed the contactor, not it won't stop running.
I believe, based on your info, here's what you need to do. Kill power to the unit. The 2 wires bringing power to the outdoor unit should be on the top 2 terminals. The 2 fan wires should be on the bottom 2 terminals. This is providing that the contactor is mounted Vertical. The could be an outside chance that the unit has a short in it and you are getting voltage feedback somewhere.
Take another look.
Posted on Dec 31, 2009
  • 1033 Answers
SOURCE: rheem RAKA 037 JAZ
When power is applied to the motor try spinning the fan blade with a small object such as a stick, if this gets the motor going than the capacitor is faulty and must be replaced. The capacitor is located in the outdoor unit.
Posted on Jun 21, 2012
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
Replace contacts in ac rheem 060jaz split system were is reset switch
Get wiring schematic check wiring and the restet is turning breaker on and off to unit. Furnace included. Start checking for 24v . To contractor and through pressure switches. 208-230 volts in unit. Beaware
Sep 06, 2013 | Heating & Cooling
I have Rheem RAKA-060JAZ. When a/c is turned on, we feel the breeze, but no cool air. Later learned inside unit is works, but outdoor unit won't start. Outdoor unit makes no sound whatsoever.
You might consider checking the circuit breakers in your fuse panel, also the pull out fuse block mounted on the side of your house next to your a/c, you might as well check those fuses while you are at it. And lastly, look at the small thermostat wire that is attached to your cooling lines from the house to the unit. Sometimes people cut through those wires while trimming the weeds from that area. Hope this helps.
Aug 13, 2013 | Heating & Cooling
Raka 060jaz
clean coils filters
Jun 29, 2013 | Heating & Cooling
What evap coil can be efficiently used with a 10 seer rheem raka-024jaz condenser
Hello, if the outside condenser is 2 ton than the inside evap coil should be 2 ton aswell. There are 12,000 btu's per ton and the number 024 in the model # represents btu's per ton so you have a 2 ton unit.
Jun 25, 2012 | Heating & Cooling
Rheem RAKA 037 JAZ
Jun 21, 2012 | Heating & Cooling
I HAVE RHEEM AIR CONDITIONER THAT STOPED WORKING, ITS ONLY 13 YEARS OLD.....SHOULDN'T IT LAST 15 YEARS AT LEAST MODEL NO. RAKA 037JAZ SERIAL NO. 5429m119608316 replaced freeon twice. ITS...
yes abd more like 20 or more if you take care of it. But you do not say hwat is working . you just say its not working.. does the indoor fan work? does the compressor try to start? have you checked the fuses or breaker?
Jul 17, 2011 | Heating & Cooling
Frozen central ac line inside and out Rheem RAKA-030JAS SER# 4951-M1593-1350
There could be a few possibilities, but I will tell you the most prevalent ones.....Dirty air filter or dirty indoor coil, bad blower, restricted air etc. The other is too low on freon. Turn ac to off and fan switch to on...wait 45 minutes and try again by setting thermostat no lower than 72. While waiting the 45 minutes check the filter , blower, and indoor coil.
May 15, 2010 | Heating & Cooling
Heating & Cooling Logo
159 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
