Question about Tyan Trinity S1590S Motherboard
The wiring came off the motherboard (Tyan Trinity S15905)
I took my hard drive off to get to the RAM slots and the wiring came off of the mother board (the small little wires such as the key lock wire) and I don't have a diagram where they go
  • 3 Answers
Download the manual from the following link you will a adobe acrobat reader as its a pdf file
http://www.generalmanual.com/Motherboards/Tyan-Trinity-100AT-S1590-Motherboard.htm
Posted on May 03, 2009
USB 2.0 on Tyan S1845 Trinity 400 Motherboard
look at board near front panel on the sides
Jan 24, 2014 | Tyan Computers & Internet
I have a pentium 4pc, the tyan s2090 motherboard went out, is there another motherboard that would work with the processor & other parts?
Certainly, tons of them. You have to look at them and find one that supports the P4 processor and has the connections in the correct locations for your case though. Asus has a series of motherboards that would work and Tyan has other versions as well. The selection you make sure support the processor you have, the type of hard drive interface you have and with luck the Ram and any other devices you may have. Today's motherboards don't have as many expansion slots as some older ones because they are building everything onto the motherboard. So take that into consideration.
Jul 22, 2010 | Tyan Trinity S2090 Motherboard
I have a Tyan S2662 Intel system board ...I am trying to find the onboard Lan drivers for it.....So far I have spent over an hr trying to get drivers...Got an idea on where I might get these drivers.?...
From the model number you have supplied, I have found the following info:
Motherboard: Tyan Trinity i7205 (S2662)
LAN: Intel 82540EM
Tyan Trinity i7205 Specifications
LAN driver from Intel support website: Intel 82540EM
Intel 82540EM LAN Drivers
From the list of results, look for the LAN driver file that matches your operation system. Take care to get this correct before downloading the driver.
I hope this information is helpful!
Mar 01, 2010 | Tyan : S2662AN...
Can I use 1gb memory board and which slot do I use?
There are 3 Slots on this Board. The Maximum Memory you could use would be 512 MB per Slot.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 01, 2010 | Tyan Trinity KT-A S2390B Motherboard
Board will not boot
Hi, try the motherboard with only CPU, RAM ,graphic card & Power supply. Unplug all other devices attached to it. Clean the golden pins of your RAM & graphic card. (you may need to try other RAM & graphic card)
Please note that you should use not more than 4GB of RAM & the frequency of the RAM should not exceed 533MHZ (It won't boot).
If the above don't work, you should clear CMOS of your motherboard.
I think that would help you.
Please send us your feedback & vote as they are really important!
Feb 17, 2010 | Tyan Trinity GC-SL (S2707G2N) Motherboard
Low or no voltage for the two fan connectors on the motherboard. Fans will not run when attached. Have to use a direct connector from the power supply. All voltages from the power supply check okay.
there might be a short on the mother board where the fan connectors are.try different fans.if they don't work then there is a short.the fans work the same way on the lines from the power supply.
Aug 04, 2009 | Tyan Trinity KT S2390 Motherboard
Need a schematic for this motherboard tyan tiger 133 (1834)
I found the information that you are looking for and you will find it here: http://www.tyan.com/archive/products/html/tiger133.html. This page on Tyan's Web site will provide you with a color image of the mother board (with slots labeled) along with the specs for the board. I hope this is exactly what you need.
Thanks for using Fixya and please rate my solution.
IT_GURL :)
Mar 27, 2009 | Tyan Tiger 133 S1834 Motherboard
Manual to tyan s239001
Try This link to Tyan Archive Files.
http://www.tyan.com/archive/support/html/manuals.html
I think your board will be here.
Trinity KT Manual under Socket 462/A ( AMD Athlon/MP/Duron )
Mike @ Compurepair.
Mar 12, 2008 | Tyan Thunder n6650W Motherboard
Making a bench machine on the tyan dual core pentium III mother board
Howzit
If you had no problems installing the XP second time around your problem is definitely not the harddrive. Suspect that that error you got was a blue screen. You problem most probably lies with your memory modules (RAM) if you are using more than one memory module then you need to check that they work on the same frequency (probably not since you are having this problem) If you are in fact using more than one module try just using one. If you only have one then you might try another as this one could be faulty. As to NTFS it is the best suitable format for XP therefore that is not a problem. Let me know how things turn out. Thanks
Regards.
Oct 30, 2007 | Tyan Trinity 450 (S2507S) Motherboard
Front usb
In case you don't have it, here is the manual for your motherboard: ftp://ftp.tyan.com/manuals/m_s2090_100.pdf Unfortunately, this motherboard does not appear to have USB headers on the motherboard itself so the only way that you can connect up the front motherboard headers is by getting an USB PCI card that has headers on it. Something simillar to this: http://www.newegg.com/Product/Product.aspx?Item=N82E16815108107
Jun 19, 2007 | Tyan Trinity S2090 Motherboard
Tyan Trinity S1590S Motherboard Logo
160 people viewed this question
Top Tyan Computers & Internet Experts
Jerry Umali
Larry Chandler
General Systems...
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
