GA- F2A85X-UP4, can't bring up initial bios, upon build
  • 212 Answers
Gigabyte motherboards boot to BIOS setup by pressing 'del' at startup. if this doesn't work, it may mean that the boot-time usb support for keyboards isn't activated, which means your usb-keyboard only works when windows is loaded. if you have a usb-keyboard, you can get around this by attaching a PS-2 keyboard or putting a PS-2 adapter between your keyboard and the pc.
Posted on Oct 14, 2013
How to boot from cd in ga 6wmmc7
When you turn on the computer and BIOS just begins to load, the computer will display something like..." Press (some key) to enter Setup". This key is usually "DEL", "F12", or something like that. This would bring you to the BIOS Setup Menu. Explore the options there, there's an option for boot device order. Make sure that CD comes before HDD. Of course, your CD must be bootable in order for it to actually boot.
Jul 21, 2011 | Gigabyte GA-6WMMC7 Motherboard
Just installed seagate barracuda 250gb 6gb internal hard drive with a gigabyte ga-945pl-s3 mother board and it will only recognise 130Gig! been through the bios but nothing stands out to say enable larger...
The maximum hard drive you can install depends upon the BIOS. You MAY BE able to install a larger hard drive if the BIOS upgrade will allow it. I suggest you go to the Gigagyte WEB site to check on this possibility.
http://www.gigabyte.com/support-downloads/support-downloads.aspx
May 19, 2011 | Seagate Barracuda 7200.9 (ST3250824A) 250...
GA-K8VM800M MOTHERBOARD The problem with the board is that, initially it got the message that disk boot failure, after checking bios settings, still it got same message. I have changed the IDE cables...
Try making your hard drive as the first boot in the bios and just connect your hard drive only on the motherboard ( remove cd/dvd drive, etc..). Make sure your hard drive is detected in the bios. Then restart your computer again.
Oct 11, 2010 | Gigabyte GA-K8VM800M Motherboard
System shuts down at times. May take several times to try and reboot. When I try to reinstall windows with a CD Recovery Disk, I get an error which says Bios ACPI not comliant and will not go any further....
Enter you're bios and disable ACPI. Wait until you have at least SP2 installed before enabling ACPI. While in the bios open, Hardware Monitor & MISC Setup. Watch the CPU temp. See page 53 in you're manual.
You're system shutting down may be caused by the CPU over heating. This is a safety feature for all MBs. Suggest that you remove the CPU heat-sink assembly from the CPU. Check the thermal past / tap. If it is dried or cracked replace. Remove the old using house hold alcohol on a clean rag. (Not dripping wet). At this point there is no need to remove the CPU. Clean the CPU's fan and blow out any dust build-up within the assembly. The heat build up will cause you're system from booting untill the CPU cools. This is why it seems to take awhile for you're system to boot.
Link to Gigabyte GA-7VKML manual; http://europe.giga-byte.com/FileList/Manual/motherboard_manual_7vkml_e.pdf
Gigabytes main site for GA-74KML;
http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=1306
Cheers'
Mike
Feb 06, 2010 | Gigabyte GA-7VKML Motherboard
I have GA-8iD533 motherboard. One of my friend tried to flushing the bios, but during the flushing the electricity was gone. After the electricity come i power on the computer,now it shows nothing and i...
To recover your motherboard bios and bring it back to life, you will need this following things:
1. Floppy Drive: It is needed to load the Boot Disk and the new BIOS update.
2. Boot Floppy: It is needed to load the basic operating system, preferably MS DOS.
3. ISA Video Card: Optional, but can simply the recovery process.
Notes:
A startup disk can be automatically built from the Add/Remove Programs applet within the control panel. The boot disk is a vital part of this guide, though users with WinNT/2K will need to build this boot disk from a system running MS-DOS or Win9x/ME.
You can obtain it also from this website: www.Bootdisk.com
Be sure to copy all needed BIOS utilities and update/backup files used during the original flash process to this disk as well.
After making the boot disk, delete the config.sys and autoexec.bat in the boot disk. It can be found in the disk primary directory path.
Create your own autoexec,bat. Using a notepad, build the autoexec.bat file by putting all the command lines in flashing a BIOS.
The approach for using flash utility from AMI or Phoenix is similar, but be sure to read the provided help information about each command line option before building the autoexec.bat entry. Create the text command entry, and then save to the file "autoexec.bat" in drive A: . This will load the command at floppy boot time, regardless of whether an ISA video card is available.
Dec 16, 2009 | Gigabyte GA-8ID533 Motherboard
During initial configuration and build of the system, when the system tries to boot it recognizes the IDE hard drive but places it on channel 4. That's as far as it gets, it will not boot into the...
Try changing the settings on the BIOS, like drive configuration and boot sequence/priority. also check the jumper on the OS HDD and make sure that it is on Master.
Sep 27, 2009 | Gigabyte GA-EP45-UD3L Motherboard
D-Link DFM-562IS HSFi Dial-up modem brings system out of stanby
Simply disable the sleep and hibernation option in the desktop(right-click) to bring up the window/submenu and on the screensver tab, appears a power button to manage sleep & hibernation. Keep both these select--- never---,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,sodeep
May 13, 2009 | Computers & Internet
Setting up gigabyte ga-686lx3 verion motherboard
Here's a link to where you can get the manual free and it will show you the jumper options and all. Hope this helps.
http://www.motherboards.org/mobot/manuals/Gigabyte/GA-686LX3/
Mar 29, 2009 | Gigabyte 440LX (GA-686LX3) Motherboard
Only fans are starting - nothing else
Have you checked the CMOS/BIOS Battery? How about reseting the BIOS jumpers?
Test the system using Motherboard with processor and 1 RAM, just connect power and screen only, switch it on. It it fails try another memory... Whether the memory, board of processor is the problem.
Fixya me when done....
Post me back if it doesn't work...
Feb 08, 2008 | Gigabyte GA-965QM-DS2 (rev. 2.0)...
Help!!! How to restore bios ?
You can replace the old BIOS chip with a new one, but unfortunately you will have to find a place to buy it (i would try the manufacture).
 Also you can check this link for some more information.
Oct 23, 2007 | Gigabyte GA-8SR533P Motherboard
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
