Question about Tommy Bahama Mojito Moxy Sunglasses
Nose pad fell off - Tommy Bahama Mojito Moxy Sunglasses
Where can I find a replacement nose pad for these sunglassess?
Hi Courtney,
Juicy does not offer authentic replacement parts for their sunglasses. I looked up a picture of these and it looks like they are held on by a little screw. You can go to any local optical shop and they should sell a similar nose pads for a few dollars.
May 16, 2014 | Juicy Couture Day For Night Sunglasses
Hello, I have Just Cavalli JC225 glasses. They were too tight and the arms were widened, to stop the glasses being pushed forward. Now they rest too heavily on my nose, causing red marks and...
There are a couple of things that can be done to fix this problem. One of the easiest solutions is to have the nose pads replaced with larger and/or softer nose pads. Alternatively, a saddle shaped nose pad can be helpful in distributing the weight across your nose. Most local optometrists should have nose pads available that they can change out for you.
Furthermore, if the nose pads are set at a bad angle they can dig into your nose also. Adding some curl to the end of the arms can bring the glasses closer to the face if they are sitting too low. If you are careful you can attempt some of these adjustments yourself.
Feb 25, 2011 | Roberto Cavalli Just Cavalli JC225 097...
I need two replacment nose bridge pads for a Kate Spade 135 EMME 1/S KADP. Where can I get them?
you can get the nose pads from any opticians, and they only cost a few pence each,
hope this helps
Feb 03, 2011 | kate spade Emme Sunglasses
Paslode 900420 piece fell out
Be sure to remove the metal nose piece that covers the lockout bar when assembled. It may be stuck to the other half of the gun. Replace the bar and the spring and put the metal nose piece in its position over the lockout bar. At this point the metal nose piece will be on the opposite side. This will allow you to replace the 2 halves carefully so as not to loose the spring.
Apr 23, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Printing labels and it jammed. pulled nose to get out label.
if you r trying to print from word , changet the papet type in the printer . this will solve the problem
Dec 14, 2008 | Dymo LabelWriter 400 Thermal Printer
Tommy Bahama Mojito Moxy Sunglasses Logo
48 people viewed this question
Top Tommy Bahama Clothing Accessories Experts
Da Doc
ray gallant
Are you a Tommy Bahama Clothing Accessory Expert? Answer questions, earn points and help others
