Question about Hampton Bay Sidewinder 04890 Ceiling Fan
The fan is not detecting the remote. - Hampton Bay Sidewinder 04890 Ceiling Fan
    Genius:
  • Hampton Bay Master
  • 1,617 Answers
You need a new receiver. That's a cheap store brand so good luck.
Posted on Oct 13, 2013
Off button on remote doesn't work
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
http://homenol.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Sep 04, 2017 | Televison & Video
Haam air conditioning split then I switch on come to E7 what is the problem in my a c please give me answer any parson
Malfunction of Outdoor Unit Fan Motor ( E7)
Remote Controller
Display
E7 Method of
Malfunction
Detection
Abnormality of fan motor system is detected according to the fan speed detected by hall IC when the
fan motor runs.
Malfunction
Decision
Conditions
?? When the fan runs with speed less than a specified one for 15 seconds or more when the fan motor
running conditions are met
?? When connector detecting fan speed is disconnected
?? When malfunction is generated 4 times, the system shuts down.
Supposed Causes ?? Malfunction of fan motor
?? The harness connector between fan motor and PC board is left in disconnected, or faulty connector
?? Fan does not run due to foreign matters tangled
?? Clearing condition: Operate for 5 minutes (normal)
Troubleshooting
Caution
Be sure to turn off power switch before connect or disconnect connector, or parts damage may be
occurred.
Replace the outdoor unit fan motor.
Connect the connector.
Remove the foreign matter.
YES
NO
Are fan motor
connectors
disconnected?
NO
YES
Is the pulse input?
Check No. 11 Check for pulse input
for number of rotations
on the outdoor unit
PC board.
Replace the outdoor unit PC board.
YES
NO
NO
YES
Is there
any foreign matter
around the fan?
Can the fan be
easily rotated by hand?
(S2584
Jun 07, 2016 | Heating & Cooling
Copa Breeze ceiling fan. Why is remote not working?
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
Feb 01, 2016 | Televison & Video
Cannon ir 3025 photocopier displays error code 805-000.
E805
There is a fan error.
0000
Failure in heat exhaust fan (front) (FM2)
When lock signal is detected for 5 sec while the fan is stopped.
- Replace the heat exhaust fan (front) - Replace DC controller PCB
0001
Failure in rotation of heat exhaust fan (front) (FM2)
When lock signal failed to be detected for 5 sec while the fan is driven.
0002
Failure in heat exhaust fan (rear) (FM1)
- Replace the heat exhaust fan (rear) - Replace DC controller PCB
0003
Failure in rotation of heat exhaust fan (rear) (FM1)
there are 2 fame in the right door if you just look on the right door you will see 2 square vents
get in there and remove the fans and clean them out with canned air and apply a small amount of oil in the center then flick the fan to make sure it spins softly
reinstall and try it should fix the problem but please go ahead and order a new fan the part number is on the fan itself in the sticker it will say FK2-????-????
Oct 30, 2013 | Office Equipment & Supplies
Remote control will not turn on fan
Do you have the correct type of fan connected to the motherboard ?
For fan control to work you must be using the type of fan that has at least three wires in the connector plug (if it has four wires that is ok too) but if it only has two wires then it will not works since the third wire is the control wire that the motherboard uses to detect fan speed and so on...
Fans that connect through a connector on the power supply will not work either must be conected to motherboard plug on the motherboard itself with at least three wires
hope this info helps
NOTE: if you are sure you are using the correct type of fan then check BIOS power/hardware monitor settings to see if the fan is connected to the correct plug on the motherboard and to verify it is being detected properly and fan speed setting is correct.
May 15, 2011 | Computers & Internet
Chassis fan not detect
there are two ways a chasis fan can be connected....
1)to the motherboard(it should detect)
2)directly to the SMPS(it wont detect)
if its connected to the SMPS, then remove and plug to the fan port for external fan on your motherboard.......i wud personally advice you to leave it as it is if the fan is working properly......moreover its not necessary for the chasis fan to be monitored....HOPE IT HELPED................DO VOTE IF IT HELPS.........
Jan 18, 2011 | Compaq (283983-001) Motherboard
I have a mitsubishi wd62725 green flashing led non stop replaced all the bad caps, 2 big and 4 smaller on power 4 1000u on fmt and 4 1000u on the dm board still getting the non stop led if i boot up with...
You can press the "DEVICE" and "MENU" keys on the front of the TV (not the remote) and the TV should flash an error code. Here is a chart.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
If the code is lets say 36 the LED will flash 3 times then pause then 6 flashes.
May 22, 2010 | Mitsubishi WD-62725 62" Rear Projection...
My new fan with light fixture is hooked up but it only works through the pull strings not from my wall dimmer. Can someone please tell me why and what do I need to do to have it work from the wall dimmer....
It depends if the fan and lights are ran for separate control. If only one power line is ran from the fan to the switch location than you are out of luck. You should install a switch instead of a dimmer because a fan is not designed to work with a dimmer. A dimmer works by rapidly turning the power on and off faster than our eyes can detect creating a dimming effect for lights. This is not good for your fan. The strength of the fan speed will be limited by the dimming/power output of the light dimmer.
Nov 21, 2009 | Universal Remote Control Hampton Bay...
Remote control
in the remote and the fan the little blue box is called a dip switch
you will have to open fans base to access the remote power sender
on both the fan and remote the dip switches have to match in order for the remote to work the fan properly
or your signal will never make it to remote box
Jun 05, 2008 | Hampton Bay 24002 Ceiling Fan
Magic fan
Sounds like a defective infrared sensor in the fan. I assume you have tried removing the batteries in the remote to rule out the remote. I don't think you have a wiring issue....your light works and the fan works. Typical fan wiring involves the fan & lights. The wiring for the infrared should already be wired from the factory. Its in the infrared detection circuit.
- Jim
Feb 12, 2008 | Hunter 21617 Palermo Brushed Nickel...
Hampton Bay Sidewinder 04890 Ceiling Fan Logo
55 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
