Cost to replace a home central AC compressor in MA
I am looking for general ballpark figures. I don't know what brand, how old or the condition of the AC unit.
  • 2 more comments
  • George B Apr 25, 2009
    I will have some further details today on brand, model and possibly age of AC unit. If you recommend replacing the whole thing, what is the cost of installing a new one? The home is approximately 2000 sq ft and the unit is inside.
    Here are the details on the unit:
    Bryant QuietLine Furnace with heat/off/fan/cool switch
    Uses natural gas, it is forced air
    Series SF-F
    Model 125-394 U/C for Upflow/Downflow
    Serial 294452
    100,000 BTU
    115 V
    Currently the heater works, but the AC compressor is not working. Any idea on the cost of replacement would be appreciated.
    On a second note, I see that Goodman 3-4 ton gas AC with heater run about $3700 shipped to the door. http://www.acdirect.com/air_conditioning...
    So my additional question is:
    How much to put one of these babies in, or should I look at Carrier or Trane?
  • George B Apr 27, 2009
    what is roughly the cost of installation?
    Guru:
  • 1,524 Answers
With the phase out of R22, it is suggested to replace the system with a more energy efficent R410A system.
Posted on Apr 23, 2009
  • Robert Moller
    Robert Moller Apr 26, 2009
    They are all very good. Goodman is now Amana or vice versa.
  • Robert Moller
    Robert Moller Apr 27, 2009
    It varies. Check the reliable dealers listed here.
How much does it cost to replace a magnatron in a microwave
It varies by the power rating and the brand name, but $200 is a good ballpark figure.
Jan 29, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Boiler doesn't fire up. 25 years old Amana outdoor boiler model #3612M-A Mfg # P68191-1F,It had leak in pump housing and replaced, replaced igniter ,but no fire, no leak in system ,pump are keep running...
How a Central Air Conditioning System Works
Facts:
  • The typical central air conditioning system is a split system, with an outdoor air conditioning, or "compressor bearing unit" and an indoor coil, which is usually installed on top of the furnace in the home.
  • Using electricity as its power source, the compressor pumps refrigerant through the system to gather heat and moisture from indoors and remove it from the home.
  • Heat and moisture are removed from the home when warm air from inside the home is blown over the cooled indoor coil. The heat in the air transfers to the coil, thereby "cooling" the air.
  • The heat that has transferred to the coil is then "pumped" to the exterior of the home, while the cooled air is pumped back inside, helping to maintain a comfortable indoor temperature.
  • Central air conditioning can also be provided through a package unit or a heat pump.
Benefits:
  • Indoor comfort during warm weather - Central air conditioning helps keep your home cool and reduces humidity levels.
  • Cleaner air - As your central air conditioning system draws air out of various rooms in the house through return air ducts, the air is pulled through an air filter, which removes airborne particles such as dust and lint. Sophisticated filters may remove microscopic pollutants, as well. The filtered air is then routed to air supply ductwork that carries it back to rooms.
  • Quieter operation - Because the compressor bearing unit is located outside the home, the indoor noise level from its operation is much lower than that of a free-standing air conditioning unit.
ed.
Sep 10, 2008 | Amana Heating & Cooling
Just had ac charged on 1995 Chevy Suburban after replacing, nearly, the entire ac system last autumn. Told there were no leaks (vaccum check). However, got the truck home and it still blows warm air and...
you can run the compressor for a few minutes to see if you get cold air with the low pressure switch crossed out. if you don't have cold air after about 5 minutes then you still have a leak somewhere.
Jul 30, 2011 | Chevrolet Chevy Cars & Trucks
I have a Goodman AC unit that isn't working. I believe its the fuse. My power went out and the ac unit stopped working. the first time the repair guy said it was the fuse. I don't want to spend...
Generally, the fuses are located in a box outside by the outdoor unit. The box has a door on it and you will probably have to pull a cartridge out and the fuses will be behind the cartridge. If you don't have an ohm meter to check the fuses , just go to home depot, lowes or another hardware store where they can check them for you. Be sure to check the circuit breakers too.
Jul 11, 2011 | Goodman CKL36AR36 Air Conditioner
How do i know if the ac needs to be recharged or replaced in my 1990 toyota celica gts.blows hot air.
Normally, if when you turn on your AC the compressor will activate and you can visually see the pump turning if you look. If it turns, then you can attempt a recharge. If it doesn't turn, then first check the fuse for the AC and if that is good then your compressor might not be any good.
While this is just a quick check, and you system will probably take further diagnosis, it is a general guideline that should get you into the ballpark.
Jun 09, 2011 | 1990 Toyota Celica
Sony KP53S75 Problems
Google to Encompass Parts Distribution and type in your Model number they Do list it and Parts as well as Service Manual you can Print out online. If you do not hear sound or anything it could be FBT flyback transfomer Ck hori out put Transisitor and small blue high voltage capacitor 2k they go bad alot.
Jun 01, 2010 | Televison & Video
Blows air not cold I don't know how to tell if the compressor is dead or the thermostat
Hook a set of ac guages to the high and low side of your system and see what your pressures are. ballpark low should be 55 psi and ballpark high should be 350 psi. If off replace inline filter on high side, vacuum system and recharge with specified capacity and check pressures again. check to make sure clutch on compressor engages when you turn your ac on. if no charge in system clutch will not engage
Jul 29, 2009 | American Standard Heating & Cooling
From where normally freon leak in central air condition system
Stuff frozen is usually where the leak is. It's under high pressure and when it leaks out the pressure drop causes the freeze.
Cost to fix is a guess depending on where it is. If the evaporator is what is leaking, you probably have to buy a new one and it'll be $1500-$2000. If an excessible line is leaking, it probably won't be all that much for them to solder it.
Good luck.
Jun 19, 2009 | Heating & Cooling
Cost?
Hello Exorbio,
As stated the problem is a lack of horizontal deflection. A ballpark figure on this would be as follows (take into mind this is the worse case scenario):
Parts:
1) Yoke transformer (if windings are open or shorted) $50.00
2) Fly-back transformer (if windings are open or shorted ,most likely shorted) $25.00
3) Horizontal Output Transistor (if going bad) $19.95 (sold in packs)
4) yoke capacitor (if defective) $1.49
5) Horizontal driver Transistor (if going bad) $10.95 (sold in packs)
6) Misc parts $20.00
Labor:
$60.00 per troubleshooting hour (standard troubleshooting time 2hrs) $120.00 (total)
$70.00 per repair hour (standard repair time 1hr) $70.00 (total)
Parts Total: $127.39
Labor Total: $190.00
shipping and handling for parts: $55.00
Grand Total: $ 372.39 (This is just a ballpark figure based on the worse case and the straight totals of parts, labor, and shipping costs)
This could cost much less depending on if only one of the listed components is bad.
I hope this helps,
Thank you,
Shuttle83
Oct 09, 2008 | Toshiba 27A34 27" TV
Heating & Cooling Logo
4,648 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
