Question about Locks & Locksmithing
How forgot the combination of my Abus 1801/50 lock. How do I reset the combination?
5 Suggested Answers
  • 638 Answers
SOURCE: ipod lock code
  1. Enable hidden folders.
    In Windows Explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders".
  2. Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked".
  3. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds.
  4. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Posted on Nov 01, 2008
  • 61 Answers
SOURCE: resetting combination bike lock
Try rotating locking device 180 degrees and hold it down and set combo to 0000, then let up on locking bar. That should clear the old combo. To reset, rotate the device 180 degrees and hold down while inserting your new 4 digit code and then release it.
Posted on Feb 04, 2009
ipodslinger
  • 688 Answers
SOURCE: screen lock combination, forgot n tryin to reset but it wont let
You will need to hook your iPod up to itunes and Restore the iPod software to the original factory settings.
When your iPod mounts to iTunes, you will see a button that says "Restore"
Press the restore button and your iPod will be restored back to it's originally state.
Here is the draw back, You will lose your music and have to resync or reload your music
and any other files.
Good Luck
Posted on Mar 05, 2009
SOURCE: Forgot combination to 1500id master lock how do I
Forgotten my combination, how do I open and reset a new combination??
Posted on Feb 18, 2012
How do I reset the word lock bike lock when I forgot the word I used last.
You can't reset it if it is currently locked together. You have to try to "crack" the combination.
184 WordLock Combination AVOID THIS LOCK
Wordlock pick
Apr 14, 2017 | Cycling
How do I set an abus 1460 combination lock
Your lock is here Linda, but no instructions
https://www.abus.com/eng/Mobile-Security/Bike-Safety-and-Security/Locks/Steel-O-Flex/Steel-O-Flex-Raydo-Pro-1460
there are a number of videos showing how in the main link. This one is good;
https://youtu.be/ZyPmi1o_o1M
This one has the key built in
https://youtu.be/m32HP5E8Ak8
Go to Bing homepage
Jul 21, 2016 | Abus Raydo 1460 Lighted Combo
How to reset built in lock on my Delsey Helium suitcase
The default combination of new lock is always 000..If you forgot the correct combination, it is not possible to reset it.
Jan 07, 2016 | Delsey Helium Shadow - 25 Trolley Luggage...
Have a abus comb lock its locked i put in the four numbers which are correct but it wont open only just bough it shop put in the combination
Take it back to the shop. They will provide the correct combination or reset the combination; or will owen you a new lock or refund (if you did not actually forget the combination). Abus makes good locks.
Mar 14, 2015 | Locks & Locksmithing
How to set combonation on Airbus Bordo Granite lock
Go on line to the manufactures web site and seek a new manual download from the support division.
May 10, 2014 | Abus Cycling
How to set lock combination
The device came with a manual to help you do the setup procedures. Review the pages and follow the instructions accordingly. If you do, the combination can be achieved.
May 10, 2014 | Abus Bordo Granit X Plus Foldable Lock:...
Forgot my Presto Lock combination!
You cannot reset the lock unless you know the combination. You would need someone to pick the lock, like a locksmith and then once it's open you can reset the lock with a new combination.
Jan 25, 2013 | Locks & Locksmithing
Reset combination abus 160/50
The answer can be found at http://www.lockwiki.com/index.php/ABUS_160: "The shackle can only be opened when the correct code is dialed and this is required in order to reset the code. With the correct code dialed in the user pulls out the shackle, turns the key on the right-hand side of the lock 90 degrees clockwise and sets the new code on the dials. The new code is in effect once the key is turned back to the vertical position."
Dec 09, 2012 | Locks & Locksmithing
Locks & Locksmithing Logo
50 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
