Question about Microsoft Xbox 360 Controller
Left analog stick My Xbox left analog stick does
Left analog stick My Xbox left analog stick does not run when i push it in and forward, it just walks. Is their any way i can fix it?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 139 Answers
Analog stick might be bad and may need replaced. If you don't feel comfortable tearing it apart, you may want to look into a new / used one.
Posted on Nov 13, 2013
playon186
  • 45 Answers
SOURCE: The left analog stick on my xbox 360 controller is faulty
In this game you must check your settings, you may be set to right handed in which case movement/advance is on the right side and attack is on the left. You should be able to go to settings and change the settings to make the left analog control your movement. Hope this helped and if it does, don't forget to leave feedback....FIXYA!
Posted on Feb 14, 2009
  • 20 Answers
SOURCE: xbox 360 left analog stick
i might be able to help... go on to setting go to controller setting and you will have multiple different ways your controller will work look at the one it is at before you change it then try different controller setting if that diddent work write back ;)
Posted on Mar 03, 2009
  • 20 Answers
SOURCE: Left analog stick click will not work
i might be able to help this may just be a controller defect meaning the controller might not work.. but first go on to your setting than look for controller setting change the controller setting then change it back to the one you were on ion the first place ... hope that helps:)
Posted on Mar 04, 2009
  • 5 Answers
SOURCE: Xbox 360 Controller "sticky" analog sticks.
Open up your controller with a screw driver and disassemble it a little bit look for the butons and take them out and give it a wash then dry the buttons and put them back into the controller and screw up the controller.da.da....
Posted on Jul 25, 2010
  • 6 Answers
SOURCE: my xbox 360 left analog stick does not work
What the problem is inside the controller where the left joystick is attached to mechanism that makes the controller register into the system to play a game. There are only two things I advise you to do.
1, Open up the controller and see if you are able to re-adjust the joystick on the pad.
2. See if you can get a refund or you might have to by one.
Warning!!! Do not open up the controller then get the refund because if the store you got the controller from finds out that you opened up the controller then your warranty on the controller will be gone.
I hope this information helps you.
Posted on Jan 04, 2011
Analog problem
Do you mean it the analog stick turns left or it turns left in-game?
Jan 30, 2014 | Sony Dual Shock 3 Controller for...
Xbox 360 analog stick problem.
You could try to disassemble the controller and reseat the stick, but the stick might be faulty. If so, try to look on eBay for a replacement, or at a game repair store, if there is one near you.
May 23, 2012 | Microsoft Xbox 360 Controller
Left analog stick drifting left
Hello Iwn666,
There could multiple things wrong, and hopefully nothing serious. Here is a complete list of some problems and solutions that can be wrong with the analog stick.
1. The Left analog stick may be sticky. If you eat greasy foods while playing your Xbox 360 console, try to avoid this from now on. Grease from food particles may slip into the analog stick, and make it sticky, causing the analog to move constantly to one fixed position. Please look at the next problem and solution ahead before attempting to remove your controller with a screwdriver. Here is a complete guide on how to access the inside of an Xbox controller.
http://www.ehow.com/how_5410334_fix-xbox-controller.html
2. There may be a simple glitch in configuration. Try turning off your Xbox 360 controller by holding the Xbox Guide button for approx 4 seconds untill a menu comes up. Select "Turn off controller". After doing so, try turning on your controller again. If the problem persists, there may be a greasy analog stick, or an object that broke that holds the analog stick together. Go back to problem/soltution #1.
Nov 12, 2011 | Microsoft Xbox 360 Controller
The left analogue stick keeps moving the character around even when im not doing anything
Hello alsupjonatha,
Aug 07, 2011 | Microsoft Xbox 360 Controller
My left thumb stick is really messed up. When I use this controller I don't even need to push it forward to walk forward. It started after i accidentally knocked over an ashtray my cousin recently used...
Take out the screws on the back of the controller, open it up and clean out the area around the analog stick. The inside of the controller is actually quite simple.
Jun 16, 2011 | Microsoft Xbox 360 Controller
How do u swing the bat?
Your left thumb stick controls the batters eye, if you push in on the left stick it will show a transparent circle which represents were the batter is looking. If you place it in the same place the ball comes in it will show the pitch location and you make better contact. You use the right thumb stick as follows,
contact swing (pull back, release) power swing (pull back push forward)
defensive swing (push forward) check swing (pull back immediately after your swing has started)
you can also change the controls to just use the buttons.
Feb 13, 2011 | 2K Games Major League Baseball 2K8 for...
Xbox 360 controller left analog stick
If you bought it brand new, contact Microsoft ASAP.
Otherwise, no luck. Just an unfortunate side affect of playing a 360.
Apr 04, 2009 | Microsoft Xbox 360 Wireless Controller
How do I kick off in ncaa football 07 for xbox
You use the left analog stick to position the kick. When you are ready, pull back on the right analog stick and when the gauge fills up, press forward on the right analog stick. The key to a good kick is to position the right analog stick in the same direction of the kick. (As if you were kicking in the direction your turned with the left analog stick.)
Good luck and happy gaming!
Mar 22, 2009 | EA Sports NCAA Football 07 for Xbox
Feb 14, 2009 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Controller Logo
152 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
