Question about Dryers
Older kenmore dryer heating problem
My dryer will not heat, its a older model kenmore, model number 86863100 and i took the back off to look at it, i dont see any lint stuck anywhere, and the wires look pretty old, i am hoping there is a quick fix. thanks
  • 113 Answers
Its probably either a thermal cut off, thermostat,and or heating element. you need an ohm meter to check each one for resistance and replace whats bad
Posted on Apr 23, 2009
  • amy copeland Oct 30, 2013
    So what kind of reading would i look for?
All of a sudden, my 18 year old Kenmore gas dryer is not producing hot air. The motor is working & the barrel is revolving. What can I do short of spending $500-$600 for a new comparable Kenmore gas...
It sounds like your heating element has given up the ghost and broken OR you have a bad thermostat that isn't telling the heating element to work. I would suggest you find the tag on your dryer with the model number on it and then go to www.searsparts.com and look it up and find the heating element and thermostat and decide if you want to spend that much.
NOTE: Usually, on older models, I always recommend that my client replace both so that I don't have to come back again in a few months to change the other. They seem to both fail close to each other.
Jun 18, 2011 | Kenmore Dryers
How do I change out the heating element on my kenmore oasis electric dryer model 110.67032600
Use a putty knife to press against NUMBER43.
This is a newer cabinet but basically busts down like an older one.f4825eb.jpg9b58516.jpgAfter the front is removed the dryer magically becomes exactly like this older model here: Cabrio dryer service manual. Similar to oasis.
Oct 10, 2010 | Kenmore 67082 Electric Dryer
I have an older Kenmore 70 Series Dryer, but when I set the timer to dry it doesn't move, it stays in the same place. Any ideas?
do you have heat in the dryer?is it on time dry or auto dry?when the heat shuts down then the timer will advance in auto, when the heat starts again the timer stops.let me know if you have heat or not and send the model next time,will start with 110. or something like that and eight numbers after the dot
Aug 29, 2010 | Kenmore Dryers
Dryer turns but we are gettin no heat book said to look for fuses i was wondering where they were located?
On back side of older models885b56b.jpgOn newer models the limits are inside06ad40b.jpgThis video shows how to get into a newer machine
This LINK shows how to get into an older Kenmore dryer
Typical fuses and locations
Aug 16, 2010 | Kenmore Dryers
I have an older model kenmore dryer and it won't heat up. What should I do?
Check the heat sensor.Hope this helps.....Hold a lighter to the heat sensor and u should here it click to turn of the element......It may be stuck in the of position not allowinr the heat element to work.
Aug 12, 2010 | Kenmore Dryers
Dryer does not heat
Clean it up and replace the fuse amigo Older models have the fuse to the rear39b9f91.jpgabf02b3.jpgnewer models have it on the blower housing. Post yer model number for a better answer friend.5d0f07f.jpg
May 08, 2010 | Kenmore 73952 Gas Dryer
How to take off heating element. The fuses seems
do you have a meter?pull one of the wires off the heater and read it out,you could have a bad thermal fuse,a,bad high limit t stat or a couple of other problems,check to make sure you have 240 volts coming in at the back of dryer at the block where the cord connects to dryer,there are 2 house fuses that can go to dryer and one could be bad,next time send model number,if the filter is on top then go to the back of dryer,if the filter is inside,take off the bottom panel and check out the thermal fuse there,it's located on the blower wheel housing it's either 3392519 or 3390719 depending on model number,if you need more help let me know,good luck
Feb 18, 2010 | Kenmore Dryers
Kenmoore Model 86863100 - Dryer won't heat
The heating element on a Kenmore dryer typically reads about 9 to 13 ohms if good. Isolate the terminals by disconnecting any wires to ensure accuracy of your readings.
Dec 23, 2009 | Kenmore Dryers
Older dryer just stopped heating. Air still blows
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | Kenmore 64742 Electric Dryer
Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Apr 29, 2008 | Kenmore 63942 Dryer
Dryers Logo
210 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
