Question about KitchenAid Kitchen Ranges
KGRS807SSS00 start buttom will not turn on the oven, all other functions are working, error code F2E1
SOURCE: F2E1, F3E0 Error Codes
Believe it or not, but on my Whirlpool Estate (Model: TES400PXHQ0)....after reading about this error, I looked at the sensor, and I noticed it was touching the metal on the inside of my oven. I moved the sensor away just by pulling on it to the center of the hole that was cut out for it, plugged the oven in....and didnt get a code at all....not even the PF code. So, I tried the oven out....expecting for it to beep at any second, and it didnt!!!!
So, in conclusion.....I guess by the sensor touching the metal on the inside, it couldnt get an accurate reading, so the computer threw out the infamous F3E0 error.
I've had this oven for 4 months and always had to stare at the F3E0 display (it was donated to me). Thanks for all who had done the research on this to point me in the right direction, as Whirlpool wanted someone to come out at $60 just to come out, then $80/hr!
Thanks again
~Luke
Posted on Oct 14, 2008
jackiaria
  • 350 Answers
SOURCE: Error Code F2E1
Did you try unplugging it for a couple of minutes and replugging it?
This might reset the computer control.
Posted on Jan 17, 2009
  • 3 Answers
SOURCE: oven on our electric kitchenaid
UNLOCK DOES NOT RESPONT AND ERROR F2E1 COME ON
Posted on Aug 09, 2009
jsrock516
  • 5911 Answers
SOURCE: my kitchenaid architect series II gas range is
In most cases, this is an indication that the Electronic Range Control (ERC) is defective and needs to be replaced. The ERC controls all the features of the oven, so without it, you cannot turn the oven on or regulate the temperatures. You can attempt to reset it by unplugging the range for at least 30 seconds, first. Or you can try disconnecting each wire from the ERC and reseating it (one-at-a-time) to ensure you have good connectivity. However, if the problem persists you will need to replace the ERC.
If parts are required, you can purchase on line at the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Use whatever parts source you like, but I have found these websites to be reliable, offer great service and the prices are usually cheaper than retail. The prices will differ between sites, so shop around for the best deals.
If the model number you have this listed under is correct, the part number for the ERC is 9762794. The cheapest website I could find it was on the Sears website for about $158. (Not a cheap part no matter where you look for it).
To replace (if necessary), follow these steps:
1. Make sure the appliance is unplugged.
2. Remove the screws that hold the back of the control panel in place.
3. Take note of the wire color coding BEFORE removing any wires from the ERC. Most control boards will have the colors printed on the board by the terminals. If yours is not listed, either write the wire color codes down or use a digital camera to ensure you note the proper placement of the wires.
4. Remove the wires from the control board and the screws that hold it in place.
NOTE: Most ERC boards do not come with the overlay (This is the plastic that covers the facing of the EOC with all the features on it). Remove the old overlay from the old board if you wish to reuse it and install it to the replacement board.
If you have questions, please let me know. I hope this helps you.
Posted on Sep 23, 2009
  • 291 Answers
SOURCE: Kitchenaid Superba - oven stopped and code F2E1 is
F2 E1 is an error code that says the membrane (touch pad assembly) is not connecting to the ERC(Electronic Range Control). Call the warrantee company and give them the model number and serial number of your range and ask them if it still has a parts warrantee on the electronics. If it does, they will have to send their technician out to replace the part or parts and charge you for the labor. Your model may have the membrane and Erc all in one part, so an easy diagnosis, if it is seperate you need to make sure the membrane ribbon connector is plugged tightly into the Erc, plug your range back in, press cancel, and then retest. If it still fails then replace the membrane, test and if it fails again, replace the Erc. Before you tear into this make sure you unplug the unit for 30 minutes, plug it back in and test. Sometimes this will reset the Erc and solve your problem. If it doesn't the make sure you unplug the range before doing any repair work. Good Luck, Appliance Specialists
Posted on Jan 06, 2010
When I turn on the oven the bake burner does not ignite but one of the top burners tries to ignite. Neither the bake or broiler oven will ignite. KitchenAid Model:KGRS807SSS00
you don't have a regular igniter in this stove you have stick igniters it sounds like you have a bad spark module part WPW10331686 all the igniters are plugged into it,the spark module is up in the top console on the left side or on the back wall but it's easier if you pull out the stove to get behind it,make sure you unplug the stove before you work on it,go here to see picture of module
https://www.repairclinic.com/PartDetail/Control-Module/WPW10331686/1937904
also you can go here to sears site,put your model number in and see all parts,go to control panel to see spark module
https://www.searspartsdirect.com/model-number/KGRS807SSS00/0593/0124002.html?searchType=modelSearch&q=KGRS807SSS00&searchTerm=KGRS807SSS00
Jan 26, 2018 | KitchenAid Kitchen Ranges
Err F2E1 stuck/shorted key
The control panel is either faulty and needs to be replaced. One can be purchased at repairclinic website or partselect.
Or you can dismantle it, and clean everything with rubbing alcohol and a cotton swab
Apr 27, 2010 | Ovens
F2E1 message on range
I have a repairman coming to check it out.
Jan 25, 2010 | Kitchen Ranges
Display showing F2E1
HI. This code will appear if the key pad becomes unstable. This may be a loose cable, or faulty control board. Use the procedure to isolate the issue.
1. Check The keypad connector, which will be located on the backside of the control board, for a firm connection. Pull off the connector, and re-attach. If the code comes back, after the re-attaching method, move on to the next step.
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models may incorporate the keypad and control board as one unit. In this case, replace the control board (also referred to as the ERC or clock).
Dec 25, 2009 | KitchenAid Kitchen Ranges
Oven not working
F2E1 refers to disconnected keypad.If you can; check for the keypad, else have it replaced.
Jan 01, 2009 | KitchenAid KESC307 Electric Kitchen Range
Oven on our electric kitchenaid stops working and f2e1 error message comes on. It does this frequently
F2E1 is a fault code that indicates the keypad my be unplugged or has failed.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jun 22, 2008 | Kitchen Ranges
Thanks again
~Luke
Dec 21, 2007 | Whirlpool SF367 Gas Kitchen Range
Kitchen Ranges Logo
57 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
