Question about Lincoln 75-83 84 85 86 87 88 Ford F150 Alternator 55 Amp
I HAVE A 1984 F150 6 CYL. I fried the Mega fuse to the Alternator. . How do I replace or bypass this fuse?
2 Suggested Answers
  • 115 Answers
SOURCE: replace mega fuse
Buy a voltohm meter to test voltage at battery. Should be 13.8 to 14.2 volts. Sometimes need alternators need to be "enegized".
Posted on Mar 30, 2014
Where is the Mega fuse located on a 2004 Lincoln Navigator
probably alternator fusible link
press the helpful button, and check video link below
Fuse link replacement for Ford Expedition 2003 5 4
Jan 21, 2016 | 2004 Lincoln Navigator
Where do I find the mega fuse or in-line fuse from alternator on a 2000 F-150 XLT 4.6 V-8 triton?
Mega fuse ford. - YouTube
? 1:35
https://www.youtube.com/watch?v=o9npBfNjKsU
Dec 2, 2013 - Uploaded by Mn09lfV6f
Mega fuse ford. .... Thanks Bud you saved me from getting analternator! I didn't ... 8:39. How to Find and ...
Part 2 -How to Test the Alternator (Ford 4.6L, 5.4L).
troubleshootmyvehicle.com > Ford > 4.6L, 5.4L
Mar 1, 2011 - The newer Ford vehicles use an inline fuse that goes by the name ofMega Fuse. So, before we can condemn the alternator as BAD, we need ...
Where the heck is the Mega Fuse pics needed. - Ford Truck ...
www.ford-trucks.com > ... > Super Duty & Heavy Duty
Jun 5, 2010 - 2001 F250 5.4 V8 4x4. I have had ... Even tried a new alternator and the battery light still stays on. ... 04 F350 XLT 4x4 6.0L SC/LB 4x4 ... I looked there and see one line marked FUSE but there is no mega fuse on it. .... 2005 F-150 Lariat having huge charging issue please help me, JoeJN, 2004 - 2008 F150 ... Installed battery backwards, truck wont start.
Jan 17, 2012
charging problem 99 5.4
Feb 20, 2010
2001 F150 Fuse Box Diagram
Jan 23, 2010
Fusible links and inline fuses?
Sep 17, 2009
More results from www.ford-trucks.com
Dec 16, 2015 | Cars & Trucks
How do i change a mega fuse in a 2003 chevy trailblazer? Do i need to disconnect the battery first?
THE FUSE LINK TO ALTERNATOR. YOU HAVE TO DISCONNECT NEGATIVE BATTERY CABLE BUT FIRST TURN OFF RADIO BEFORE DISCONNECTING NEGATIVE BATTERY CABLE.TELL ME WHAT SIZE MEGA FUSE YOU REPLACING 40 AMP FUSE IN FUSE BOX..FORD CARRIES MEGA FUSE 175 AMP FUSE A MEGE FUSE DOES SAME JOB FUSE LINK.YOU NEED TO REPLACE FUSE LINK.FUSE LINK IS HEAVY GAUGE WIRES TWISTED TOGETHER THEN USE ROSIN CORE SOLDER AND SOLDER WIRES TOGETHER.WRAP A LOT OF ELECTRIC TAPE AROUND SOLDER WIRES TO KEEP FROM GROUNDING STARTING A ELECTRICAL FIRE. FUSE LINK LOCATED IN THE WIRE FROM THE BATTERY TO THE ALTERNATOR YOU WILL SEE WORDS FUSE LINK ON THE LINK.
Aug 27, 2011 | Chevrolet TrailBlazer Cars & Trucks
Replaced bad alternator, but battery light is still on! 1998 Ford F150
ALTERNATOR IS PCM CONTROLLED BESURE ERASE FAULT CODE.CHECK TO SEE IF POWER GOING TO ALTERNATOR BATTERY FEED WIRE.AND CHECK VOLTAGE REGULATOR WIRES FOR DAMAGE.CHECK BATTERY CABLES MAKE SURE THEY ARE CLEAN AND TIGHT.CHECK THE LARGE MEGA FUSE NEAR THE BATTERY.THAT WILL CAUSE CHARGING PROBLEM IF MEGA FUSE IS BLOWN.
Feb 11, 2011 | 1998 Ford F150 Regular Cab
1984 300zx non turbo.battery hooked backwards now engine starts and stops immediately.all fuses have been checked and they are working .
that could have damaged the alternator now when the car starts and the alternator gets to operating speed, it stalls the engine. could also be the cars computer fried. any questions you can email me at meanness628@aim.com
Jun 27, 2009 | 1984 Nissan 300ZX
Alternator fried batts @ wires
It has got to be a bad short to ground some where from the regulator to the fuse box? Or the Alt. your useing is not the right one for the truck.
Feb 25, 2009 | 1984 Dodge Ram Wagon
Engine fires but stops, holding accelerator will idle
Have you run the test to get the trouble codes out of Powertrain control modules menory, that is a good place to start. post the code(s) back here on this thread and I will help you.
Nov 15, 2008 | 1998 Ford Taurus
1984 jimmy 4x4
alternator is defective regulatorbroken you have to change the alternator good luck pierre
Sep 16, 2008 | 1984 GMC S-15 Jimmy
98 Ford Contour not charging
I dont know if yours is a 4 or 6 cyl. On the back of the motor by the firewall there is a 175 amp mega fuse inline on the positive cable comming from the battery. On the 4 cyl it is below the air box center of the back of the motor. On the 6 cyl, it is below the coil pack on the center back of the motor. Be sure to disconnect the negitave battery cable before you attempt this. There is a 3 inch long cover you pop off and you will see it. It takes a 10mm socket to unbolt it. Remove the fuse and ohm it out, if there is no continuity, you have a bad fuse, replace it. I have had 3 people replace their bats and alts ($350 in parts) just to find out it still had the problem. An $8 fuse. Good luck and hope this helps..
Jun 30, 2008 | 1998 Ford Contour
Lincoln 75-83 84 85 86 87 88 Ford F150 Alternator 55 Amp Logo
22 people viewed this question
Top Lincoln Electrical Supplies Experts
John Trevino
jdthefixer
Jay Finke
Jay Finke
Are you a Lincoln Electrical Supply Expert? Answer questions, earn points and help others
