Question about Symbol PTC 701 Portable Terminal
Backup batter fault 710 - Symbol PTC 701 Portable Terminal
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
These old Telxon devices had a switch in the battery compartment to disable the backup battery for storage, power off the unit then change the switches position and try again.
If you still have the problem the unit will need a new backup battery fitting. The unit will need to be opened and a new cell soldered onto the mainboard.
If you really get stuck contact:
www.portablesolutions.com
Posted on Nov 29, 2013
APC SmartUPS X (SMX1000)- "AVR Relay Weld" error message
I had this exact problem after a major power out: Fault, call support: AVR Relay weld.
I fixed it by resetting the UPS: Remove battery connect at rear of UPS (it is marked, just unplug the bat connect tab). Plug the UPS back in, and then turn on. Let it power up... it will tell you it needs a battery. Next, power it down and unplug. Plug the batter connect back in (see rear). Plug in the UPS.. power up. Presto.. it is reset. If it is NOT reset, there may be a real 'relay weld'.
May 13, 2013 | Computers & Internet
Tomtom 710 western europe map
Posting with them is a good thing, they know their system better than anyone else...good luck.
Oct 13, 2012 | Tomtom GO 700 GPS Receiver
Backup battery fault error on ptc 710
Nov 30, 2011 | Symbol PTC 701 Portable Terminal
IS EXIDE 1103 A MODEL OF A UPS? also have part # 106-710-7988
The Exide 1103part #106-710-7988 should be is a battery pack for a UPS and not actually a UPS itself. Please email me a picture to kw7157@yahoo.co.uk and I can advise by return.
Nov 12, 2009 | Exide Computers & Internet
Loox 710 will not turn on or charge, i have been charging the battery for over 24 hours, and still nothing, is there an internal battery and how to i get to it to change it
If you have the right charger with cable and can plug in at the bottom of the LOOX,then You can use the 710 WITHout removal battery (LiON). The internal backup battery
will charge then The internal backup battery is NiHm and will sometimes NOT recognized by WindowsMobile. P.lease check several times energy state in WindowsMobile
(green bar shows percentage). If you have craddle and charger you can try to charge removal battery in slot behind plastic shield.
If you not have the rigth charger try to lend a ASUS MyPal A serie (A632 aso) it will fit
Apr 04, 2009 | Fujitsu Siemens Loox 710 Pocket PC
Formatting a tomtom go 710
Hi, I probably cant answer all of your questions but I might help with some of them. You should be able to access your TomTom 710 without removing TomTom home software from your PC. It should be accesses as a drive through the USB connection in "my computer" on your PC. When a USB device is connected to your PC it appears as an external drive. Therefore you should be able to delete , load onto , or format the TomTom hard drive ( or with some other models the SD card ) as you would a normal drive . ( an example of this is where you might have a camer with SD memory card and relevant manufacturers software on your PC . you might connect your camera to the PC via USB and the camera software on your PC automaticly detects the camera for it to eb accesssed . However , the camera and it's SD card can also be accessed seperatly by going to "MY Compter" and it should also be visible there as an external UDB device / external drive ) . Now .. to another another question . If you do un-install TomTom home , I dont think it will also delete any backup of your TomTom , it will only delete TomTom Home software . ( the word "think" is mentioned because I have never tried this ). Besides that , you can choose in tomtom home , where you want any backups to reside , so you could save backups via TomTom home to a CD for istance. If you did that , then you would have the backup on a CD rather than your harddrive which means you could safely un-install TomTom home knowing that if it also removed any saved backup you would still have the CD with a backup on it. So , to summerise.... If it were me , I would make a backup of the TomTom by simply copying all the files on it by opening the TomTom up as a folder in "MY Computer" , simply drag any files and folders from the TomTom into a folder I have prepaired ( call it for instance "my tomtom backup" ) on my PC . Then I would format the TomTom drive then reinstall the backup and see what happens. If the TomTom still doesnt work properly , I would Format the tomtom again then use TomTom home to obtain all relivant files , then copy only the maps and .MAC files ( these are the authorisation files for the maps ) from my Backup to the TomTom manually ( not from tomtom home ). I would guess that would result in a working TomTom again ... Good luck.
Nov 15, 2008 | Tomtom GO 700 GPS Receiver
Tomtom Go 710 - help
The answer is Yes. I would make sure to have a backup on your PC. Uninstall TT home make sure you delet all of it. Reformat your card then install TT home. Connect your tt and let TT home reinstall your navcore. You may need to reconnect your tt a couple of times to get it updated to the newest navcore for your device. I believe it is 7.903. If you want to keep the older navcore just don't load the new one. Then install your maps as you normally would. I have just used this method to get the latest navcore for six 710's.
Hope this answers your question
Nov 15, 2008 | Tomtom ONE GPS Receiver
Alam going of when Phone turned off
ok some electronic items has a backup source some internal so alarm may just be in the sof ware manufature ..also the cell battery can still be inuse if the cell is on stanby come customer may think thecell is off so your battery could have
Aug 29, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Symbol PTC 701 Portable Terminal Logo
201 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
