Question about Garden
Should the two blades on a Victa ride on mower be offset 90 degrees to each other
  • 38 Answers
Only if it has a timeing belt
Posted on Oct 14, 2013
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
mowerman1857
  • 389 Answers
SOURCE: PTO will not engage blades on riding mower. The
Using a test light or volt meter, check to see if you are getting a full 12 volts at the connector where the PTO plugs in. If no voltage present, locate the fuse for the PTO and check it, also check the PTO switch to see if it is working. You can turn on the ignition switch to the run position, don't start the engine, and turn the PTO switch on and off several times listening for a clicking sound. If you hear it clicking, have someone sit in the seat and start up the engine, while it is running, observe the PTO clutch and see if it spins when turned on and if the belt turns with it. If none of this works, post a follow up and include your Craftsman Model number. I will look it up and see if I can find anything else we might be missing
Posted on Sep 21, 2009
  • 31 Answers
SOURCE: I have a murray riding mower with twin blades..how to change
take a socket rench with 2 feet pipe....slide the rench handle to the pipe and that well give you enough power to turn you have to hold the blade with something from turning .....ometime you can hold it with a towel
Posted on Oct 03, 2009
  • 16 Answers
SOURCE: i am after a victa mower 2 stroke repair manual
I have a victa workshop manual covering some of the older models which i would be willing to copy the relevent pagesfor you. or might be able to give you soom tips, what model do you have and can you discribe the carburettor, soom victa's use a very odd carb made of plastic
Posted on Nov 28, 2009
Does it matter how the blades are lined up with each other on a Huskee LT4200?
The blades are belt driven, and once installed will do what they are designed to, spin and cut the grass. They wont hit each other, and the belt allows them to "pause" for a split second seperately from each other in case you hit a rock or stick or...
I wouldn't worry about it.
May 19, 2012 | Garden
Manual for victa TRX ride on mower
hello, to get your victa manual you are going to have to contact the dealer in your area,they just don't post manuals,hope this helps,,
Feb 16, 2012 | Garden
Manual for victa 4016 trx ride on mower
Feb 16, 2012 | Mtd Garden
I have a problem with my ride on mower. we need to replace the belt that drives a twin cutting disks on a Victa 4013TX but cannot find any diagrams to help.
4013 HT is a Victa with a 13hp briggs and stratton engine normally with a twin blade 40in deck. These were badge engineered Noma mowers and essentially equivalent to murrays made at the same time. Check diagrams for murray decks to find one with the same deck configuration.
Jan 08, 2011 | Garden
I need a diagram of how the drive belt is put on
4015 HTX is a Victa with a 15hp briggs and stratton engine normallu with a twin blade 40in deck. These were badge engineered Noma mowers and essentially equivalent to murrays made at the same time. Check diagrams for murray decks to find one with the same deck configuration.
Dec 13, 2010 | Garden
Looking for a victa pro 12 ride on mower parts catalogue
what year? and if you can post a picture it can be more helpful. Victa ride ons were made by other manufacturers with Victa stickers on them.
Oct 02, 2010 | Briggs & Stratton Garden
I have a victa corvette cox made ride on mower
Being cox made I'd go looking for cox manuals for the same era. Victa just rebadged others mowers.
Nov 18, 2009 | Garden
Mows crooked
Riding mower decks are typically canted (offset) to avoid this issue. Double check to verify the new blades are the same length as the original blades.
Not all mower blades are created equally, universal replacement blades do not adhere to the same standards as OEM blades for size, hardness or many additional standards built into the OEM blades when the mower deck was designed.
May 26, 2009 | Craftsman Garden
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
