Computer trouble My computer turns off randomly, its not laptop andit happens very often. Ive tried pulling it apart and ther's nothing wrong with the power
    Scholar:
  • 113 Answers
Opening and touching the IC's and any components can be killed by electro-static interference, if your going to handle the motherboard or any daughter boards, get yourself a static bracelet, and avoid touching contacts etc: now... firstly: The power supply count be failing, check this with a volt meter, each power cable to your optical drivers has two black leads and a yellow and then a red wire, the red is 5v and the yellow is 12. If this is fine, take your motherboard installer booklet, and look at where the power and reset pins are on the board and make sure the switches, reset, LED's and Power buttons are all correctly installed. Now carefully remove the battery on the motherboard and with the power disconnected push the power button. The led should flash then die out, now replace the battery, and you have just reset your cache and your bios is reset too. Now start up your comp and go into the BIOS settings by hitting "del" in the POST, 'when it switches on.' check the voltages to the CPU, syst fans etc to make sure they are all normal. Now when you exit the comp. will reset. Start the computer in safe mode, and use system restore, to role back to 2 or 3 days, too make sure it?s not a software prob. Good luck! If the prob persists, use a new or spare power supply, 400W or 200W is fine. Also put up a new post here, and I will go into more detail. Cheers.
Posted on Sep 25, 2007
SOURCE:
Asus m50v wont boot up
You may have fried a/some components due to overheating. It may need a ride to a Qualified Computer Tech.
Dec 30, 2012 | Computers & Internet
Power light on computer and nothing else
Remove main battery to see if it will start up, no change! pull the ram memory out one at a time and try again, if still nothing! the DC jack in the laptop is a common source of trouble from no power to intermittent operation, at this point the laptop must be dismantled to assess the situation.
May 08, 2012 | Acer Aspire 5535-5050 Notebook
Help My laptop wont start up?
sounds like you Ram has blown (RANDOM ACCESS MEMORY) SIMPLE TO REPLACE'unplug from the mains turn the laptop over remove the battery you will see a few panels remove then to expose the RAM which is a chip about 3cm on and 1.5 wide two metal clips on the side pull them apart the chip will pop out ther may be two remove one and try to start the computer if it works then the one you removed is faulty on the chip it will be marked ( PC-333-5400) OR SOMETHING LIKE THAT this is the part you need to replace put the code in eBay order pop it in job done
Feb 11, 2012 | Computers & Internet
My coby mp705 4gb mp3 player randomly stopped working
your MP3 player have its on system inside, this time the program itself is corrupted, you can reformat and reinstall it using its own recovery disk. and first of all install first the program of the mp3 to your PC.
Jun 19, 2009 | Coby MP300 MP3 Player
Trouble uploading photos from my camera.
you need the driver for your camera so that the computer can read
May 29, 2009 | Fuji Finepix Z20fd Digital Camera
You may not have the software installed on your computer or it's not installed properly.
First tru plugging in your camera using the USB and turning the camera on (press the arrow buttun for about a second). The FinePixViiewer should open.
Apr 30, 2009 | Fuji Finepix Z20fd Digital Camera
My hp laptop turns on but nothing is on the screen
It sometimes happens when u use sleep or hibernate on computer using Vista that it doesn't start properly. You would have to use sleep regularly tho. In your case i'm not sure. Sometimes computer randomly manages to run properly and other days it just won't start even after many tries. Just repeat process of turning it on until it starts properly. If it does it's probably the case of what i mentioned... if it doesn't problem might be somewhere else ( maybe your power cord is damaged and your battery too? ) i had friend with the same problem and it kept getting worse. They had to change motherboard or power source for her i'm afraid. Hardware change is definitely required i guess. Good luck
Apr 04, 2009 | HP Pavilion dv2000t Notebook
Sony Vaio
could be overheating CPU, trying cleaning the air vents with some compressed AIR, i doubt theres a security to shut off the computer if you gotten the wrong password.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 18, 2008 | Computers & Internet
Toshiba satellite that randomly shuts off
may be hitting event of your laptop
also u can try to reset your bios.
go to your bios setting load default settings.
then restart pc.
Apr 01, 2008 | Toshiba Satellite 1805-S274 Notebook
Open Questions:
WEBROOT TechnICal SupPoRt pHone ~II+[[18OO8-O31O69}} NumbEr u.sa//vs Usa WEBROOT USA phone number is ranked #2 out of 2 because 7,728 WEBROOT USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the WEBROOT USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, WEBROOT USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. WEBROOT USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact WEBROOT USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling WEBROOT USA Calling WEBROOT USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from WEBROOT USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with WEBROOT USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare WEBROOT USA's phone numbers against each other. Contacting WEBROOT USA in General While I8OO8O31O69 is WEBROOT USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach WEBROOT USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact WEBROOT USA.
Oct 17, 2019 | Webroot Computers & Internet
Computers & Internet Logo
191 people viewed this question
Ekse
Alun Cox
