Question about Frigidaire Gallery GLHS66EJSB Stainless Steel Side by Side Refrigerator
Temperature setting - Frigidaire Gallery GLHS66EJSB Stainless Steel Side by Side Refrigerator
The freezer is set at -4. How do I adjust it? Everything is freezing too much.
Hi Marisa:
Following is the instruction for adjusting the freeser temperature for your Samsung refrigerator:
You press the freezer temperature button repeatedly till you see your desired temperature. If you want to set it to -2F, stop when the display shows -2F and don't press the freezer button again. After 5 seconds this new temperature will be set.
The instructions from the Samsung manual is shown below:
Controlling the Freezer temperature:
The Freezer temperature can be set between 8°F and -14°F to suit your particular needs. Press the Freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at 4°F. The temperature display will move sequentially from -14°F to 8°F. When the display reaches 8°F, it will begin again at -14°F. Five seconds after the new temperature is set, the display will again show the actual current freezer temperature. However, this value will be changed to the new temperature.
Feb 15, 2016 | Samsung RF265AA Bottom Freezer French Door...
The temp says 14 and 8 but should be -21 and 3? Can anyone help
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
How to set temperature on a general electric
Copied from ehow.com
Instructions
    • 1 Open the fresh food compartment and locate the two temperature control dials. Each dial is labeled for the compartment that it controls.
    • 2 Rotate the dial to increase the temperature setting by one to lower the temperature of the compartment. Rotate the dial to decrease the temperature setting by one to raise the temperature of the compartment.
    • 3 Wait 12 hours to allow the temperature in the compartment to stabilize before increasing or decreasing the temperature further.
Read more : http://www.ehow.com/how_8772966_adjust-temperature-controls-ge-refrigerator.html
Aug 28, 2014 | Refrigerators
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
I have a Skytech 3301 for a propane stove with some thermostat problems.
Great question! It sounds to me like the Skytech's swing temp setting may be out of whack.
Here is a quick link to the product page with a link to the owner's manual at the bottom if you need: Skytech 3301 Fireplace Remote.
Below is an excerpt on how to check and modify the swing temp settings for the Skytech 3301. (I apologize if the copy/paste formats poorly).
The Thermo Mode on the transmitter operates the appliance whenever the ROOM TEMPERATURE varies a
certain number of degrees from the SET TEMPERATURE. This variation is called the "SWING" or
TEMPERATURE DIFFERENTIAL. The normal operating cycle of an appliance may be 2-4 times per hour depending on how well the room or
home is insulated from the cold or drafts. A smaller "swing number" increases the number of cycles so the room temperature is more
constant. A larger "swing number" decreases the number of cycles, which saves energy, in most cases. The factory setting for the "swing
number" is 2. This represents a temperature variation of +/- 2
0
F (1
0
C) between SET temperature and ROOM temperature, which determines
when the fireplace will be activated. The "SWING" number values are:
1=+ 1
0
F (.5
0
C), 2= + 2
0
F (1
0
C) and 3 = + 3
0
F (1.6
0
C).
SETTING THE TEMPERATURE SWING (TEMPERATURE DIFFERENTIAL)
1. To change the temperature "SWING" setting (1-3), press the TIMER/TIME and DOWN buttons
simultaneously to display the current "SWING" setting in the SET TEMP frame. The letter "S" will
display in the ROOM TEMP frame on the LCD screen.
2. Press the UP or DOWN button to change the temperature differential or "SWING" (1-3). See above
for 1-3 "SWING" temperature valves.
3. To store the "swing number press the SET button or allow 15 seconds to lapse, and the new "swing
number' will be automatically programmed.
MANUAL CHECK OF " SWING" OR TEMPERATURE DIFFERENTIAL
The operation of the factory set "THERMO SWING" can be checked by adjusting the SET TEMP 2
0
F above or below the room temperature.
This will cause the system to turn ON or OFF. Normally the system will only respond to temperature changes every two minutes. Manually
changing the SET temperature will activate the system in less than 10 seconds. IF the "SWING" is changed, then a new room temperature
differential will respond. Factory setting of "SWING" temperature is 2
0
F.
Jan 17, 2013 | Skytech 3301 Thermostatic Gas Fireplace &...
I had a white rodgers thermosat system & its digital. I dont what model # it is but I want to know should I have the temperature set low or high if its 80 degrees in the house?
The set temperature is the temperature you want the system to cool the inside of the house.
A lot of digital thermostat will display the current ambient temperature. When you push the set temperature up or down buttons the thermostat will display the set temperature momentarily and will change if you push the up or down button.
Hope this helps.
Sep 04, 2011 | Heating & Cooling
We have a honeywell cm921 and we cant set the therm astat to come on in the mornijng and then go off then come on again in the afternoon on timer please can you help
Your CM921 has 6 built in temperature settings based on time of day:
1 - 6:30 AM
2 - 8:00 AM
3 - 12:00 PM
4 - 2:00 PM
5 - 4:00 PM
6 - 10:30 PM
meaning that at 6:30 AM the themostat will change its temperature setting to setting 1, at 8:00 AM it will change the temperature setting to setting 2, and so on. To schedule temperature settings which best fit you, determine which time periods you would like more or less heat.
For instance, to fit what you requested in your question you could program a temperature you would like to maintain in the morning and afternoon times when you would like it to be on, and in the time periods in between set a lower temperature as follows:
1 - 20C
2 - 16C
3 - 16C
4 - 20C
5 - 20C
6 - 16C
With this example your thermostat would turn on at 6:30 AM as long as the temperature was below 20C and maintain that temperature until 8:00 AM. At 8 it would change its setting to 16C allowing temperature to drop from 8 AM to 2 PM to a lower setting to conserve energy until afternoon time when the setting would change back to 20C from 2 PM to 10:30 and then change back to 16C to save energy throughout the night. The actual temperatures would be at your discretion based on your individual comfort level.
Pages 5 and 6 of the following link will guide you in setting each of the 6 temperature settings.
http://www.wolseleysbc.co.uk/_STEPData/Assets/Honeywell%20CM921%20Room%20Thermostat.pdf
I hope this helps. Let me know if you have any additional questions.
Dec 10, 2010 | Honeywell Programmable Thermostat Heater
I can not set the temprature differantial of my honeywell beutler thermostas
well back when i worked on honeywell controllers, you don't set differentials on thermostat you set the temperature and it has its own differentials like + or - 1 or 2 degrees to the set temperature they don't let you play with this setting, you set your temperature and it will maintain around that temperature you shouldn't need to change the differentials around that temperature as controller does what the heater needs to get to the temperature you require setting the differential closer to set temperature will make the unit cycle a lot more and coast you more and having it to far away can let the conditioned area start to get back out of comfortable range so they set these in factory and you shouldn't be able to change them as they are set to how it should work to wrok properly so i wouldn't change them even if you could!
Nov 25, 2010 | Honeywell Programmable Thermostat Heater
Frigidaire Gallery GLHS66EJSB Stainless Steel  Side by Side Refrigerator Logo
20 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
