Question about Car Audio & Video
I have pyle PT560 AU receiver and cannot get the MP3 connection to work... Error code "0" shows on display. What can I do?
I have a Pyle PLR14MP that I am installing in my 1975 Ford F100 - There is only one wire to the ignition switch on the radio whereas my old radio had two wires. There is a green wire, a blue wire, a back...
The other wires are for display brightness and memory. In old OEM installations, there is only one wire for each speaker. The other wire is the chassis or body.
Aug 09, 2014 | Pyle PLR14MPF
How do I set the clock on my Pyle PLR34M mobile audio system?
press and hold DISPLAY button until numbers start blinking on display screen use volume knob to change numbers press volume knob to switch from hours to minutes press DISPLAY when done
Jul 11, 2014 | PYLE Audio NEW PYLE PLR34M IN DASH USB SD...
Pioneer Model: DEH-P8400BH
Press and hold the source button until the CD Receiver turns off. Press and hold the center of the volume knob top bring up the settings menu rotate the volume knob until Clear memory is displayed and then press the center of the volume knob Clear memory YES will be displayed, press the center of the volume knob to confirm. The display will change from Clearing to Cleared
Aug 07, 2012 | Pioneer Deh-p8400bh Cd/mp3/ Receiver W/...
It shuts off and blinks 11
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
May 27, 2012 | Sharp Heating & Cooling
I am looking to reset my toshiba studio 163 spanner signal.the machien stoped functioning. i need he reset code.
Hello
Fisrt off please hold down the 8+C buttons together, there will show a error code in the copy quantity display.
Now not knowing what the error code is, i am going to hope that it is C44 that is the most common
error code on the E163 machine. If it is C44 please do the following.
Switch off the machine.
While holding down 0+8 buttons, switch on the machine.
When ad shows on the display, input 400 then press the start button.
If the value is not 0, input 0 button and press the interupt and energy saver buttons to save the change.
Switch off the machine wait awhile and then switch the machine on again.
The problem should be sorted out.
If the error code is not C44 you will have to let us know what the error code is, by holding the8+0 buttons down together.
Here is hoping the machine is working
Regards
Apr 15, 2011 | Toshiba e-Studio163 Copier
Says searching but never connects. the yba-10 blinks boes not connect
On RXV3900 using the remote there is a submenu for YBA-10WH (submenu shows Trim, Pair, Connect). Selecting Pair causes the YBA-10WH blue light to flash. Once iPod has Bluetooth set to ON it then displays a box showing "YBA-10WH not connected".
First attempt to connect requires tapping this box which produces the invitation to enter a 4 digit pass code. I had several attempts using pass code for my iPhone - all failed giving message "Make sure yba-10 yamaha is turned on in range and ready to pair". I finally tried keying in a pass code 0 0 0 0 and it paired!
Once turned off subsequent attempts to enable Bluetooth were much easier requiring tapping of the box but not requiring entry of any pass code.
Turn off seems to work easiest by using the remote to select the "Connect" option on the submenu and then selecting Enter on the remote - this caues display of "Disconnected" message on the RXV3900 screen.
Now works fine!
Apr 10, 2011 | Yamaha YBA-10WH Bluetooth Wireless Audio...
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
ITS DOING NOTHING
I'V GOT A CASIO TK-2300 ELECTRIC CASH REGISTER.ON SCREEN IT SHOWING INDW OVER 0 WHEN I PRESS ANY KEY IT SHOW MAC-CODE 0 THE NUMBER PAD IS WORKING.IF I TURN THE KEY TO REG1,REG2,RF,PROGRAM IT STAY SAME BUT IF ITURN KEY TO X1,Z1,X2/Z2 IT SHOW OPE ERROR 0.CAN SOME ONE HELP ME TO SOLVE MY PROBLEM.THANK YOU.
Apr 16, 2009 | Casio Parts Cash Register PC Desktop
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
