It dosent read sata hard disk . - Computers & Internet
  • Timothy Farley May 11, 2010
    Hi there. Could you explain? Did it just stop reading it? Is it a new hard disk?
  • 39 Answers
If you are refering to a Sata generation I hard drive and you were previously using it and now you cannot access it, then it has probably failed.
Buy a external hard drive shell to put the disk into and then go to another machine. Test it there.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2703735&CatId=2778
Posted on Apr 24, 2009
Hard disk head dosnt move
if your hdd is power on and head does not move - it's stuffed
if you did not have anything important on it - buy a new one
Nov 11, 2013 | Western Digital Computers & Internet
My laptop it dosent asept windows xp
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Dec 26, 2012 | Toshiba Satellite L45-S7409 Notebook PC
I bought a new Western Digital Caviar Blue 1TB SATA 3.5" Desktop Hard Drive 6Gb/s It dosent work for me, I can see it in the CMOS Setup under Sata 1. My MSI K9N8PGM2 motherboard only support...
you need hard drive formatter this is in disk manager, windows 7 press windows key and then X go to disc manager, in the menu you will find your hard drive and make sure its the right one. and click on format drive, on the folder of the drive.
Jul 08, 2017 | Western Digital Caviar Blue 1TB SATA 3.5"...
My hard disk dosent get detected but if i touch it then i can feel motor inside is rotating please help
could be the sata cable not seated properly or bad cable. check connections. If its the only sata drive connected make sure it's plugged into sata #1 slot. Could be drive, motherboard or bios problem. Next step would be to update the bios. That might help.
Nov 11, 2010 | Seagate BARRACUDA ES.2 - HARD DRIVE - 1TB...
Motherboard : ASUS P5GV-TMX Which hard disks does this motherboard support? It came with sata-I hard disk. Recently i bought a sata-II hard disk bt it is giving some problems..to be specific on windows it...
Yes, it can be causing a problem. You have 2 hard drives that are working at 2 very different speeds. The computer is having to do a translation and adjust rates of transfer between them on top of having to do the read and writes between them. Will SATA II will be backwards compatible to SATA I it won't work the other way. If you have to keep these drives, I would make the SATA II Drive the primary and SATA I drive the secondary on a different channel if possible. The SATA II drive is teh faster drive and should be your main.
Oct 09, 2009 | ASUS P5GV-MX Motherboard
How to configure bios to read sata hard disk problem
Are you sure it is a bios issue? In many cases you need to load additional Sata drivers during Windows installation to support sata disks.
Oct 08, 2009 | HP Pavilion dv8235nr Notebook
To configure your bios to read sata hard disk follow this Steps:
1. Power on the computer
2. Keep pressing the delete keys until bios utility will show
3. Go to the advance settings
4. Find the Sata Mode and then change it to IDE:
5. Save changes and Exit
Hope this could help.
Sep 27, 2009 | MSI K8MM-V Motherboard
WD Notebook Essential 80G just quit working
if you are not getting any broken noise from the hard disk its not ded so ushut down the computer first then connect the hard disk to the power and then connect the hard disk to your system in the usb 2 port then connect the start the system if still dosent detect go to manage by right clicking on the my computer icon the go to disk management check your hard disk shows ther if shows forign just right click on the forigen and say import forigen hard disk if shows the drive helthy and dosent show up on my computer then just right click on the helthy place and say change drive letters and choose one of the letters and should show up on the my computer if still dosent see at all then change the usb cable....
if still dosent work remove hard drive from the external case and put it directly to your computer for this u need a sata cable and a sata power if it detects and work this way your data is safe but you casing of the external hard drive has probs ...
thanks
Nov 12, 2008 | Western Digital 320GB MyBook External USB...
Via p4m800 CE - 8237
You set your BIOS to "SATA = Enabled" under that set it to
" IDE ". Most 160gig HDD's are only 1.5gig max read/write. Hope you left the jumoer pin on.
Dec 03, 2007 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
Computers & Internet Logo
David Payne
David Payne
