Question about Garden
Removal of top cover on yard works lawn mower electric model 18-407-515
  • 22 Answers
SOURCE: I have Black and decker electric lawn mower does not start
one of the problems i found with electric detectors was that they do not tell you if there is a break in the neutral cable so you could have a break there,another problem is that the levers can break inside the cover giving the impression that it should work but is not making contact with the switch ,hope this helps
Posted on Mar 30, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
  • 110 Answers
SOURCE: lawn mower keeps dying
Remove gas cap. If mower now runs without stalling, your problem is the vent in the gas cap is blocked. Replace the cap. Common problem!
Posted on Sep 22, 2009
rwvanlue
  • 486 Answers
SOURCE: oil change in yard man lawn mower
Some mowers are designed to drain oil out of the dipstick tube. remove dipstick and tilt the mower to allow oil to run out into a drain pan. 2/3 rds of a quart or 20 oz is what to expect.
Posted on Dec 06, 2009
kel1guy2002
  • 3740 Answers
SOURCE: yard machine lawn mower won't start
Several questions here...
1. Is the oil serviced to the full mark?
The oil level sensor can cause a no spark condition because it grounds the ignition.
2. Is there spark at the spark plug? You can remove the spark plug and test for spark but if the plug is internally grounded it will show spark when removed but if it is installed it can still be defective. (Spark Plugs are cheap replace it)
3. Is the handle safety cable loose even when depressed? A bad safety cable or an improper cable adjustment can also cause a lack of spark.
4. Do you note gas on the spark plug or is it very dry? If the spark plug is dry try adding a splash of gas into the cylinder via the spark plug hole and see if you get a temporary / momentary start. If you do then you have either a fuel supply or carb problem.
Make sure the fuel selector is in the ON position.
5. If you suspect a fuel problem disconnect the tank feed line to the carb and see if there is fuel flow from the tank, No fuel flow no start.... then problem in the gas tank or supply line.
I will post this as a solution but will watch for any responses and continue to assist you if needed.
Thanks for using FixYa.
Kelly
Posted on Jun 17, 2010
How do I get to the carburator?
remove the air filter and also the top cover of the engine and there it will be
Aug 13, 2012 | Mtd 22" Yard Machine Push Mower
We have a yard man model 565 21" self propel lawn mower and we are having and oil leak, How can we fix it?
clean the engine first and run to see were the leak is coming from. The remover the engine to service the leak. I would have a trained Lawn Mower tech perform this work for settings will not be the same if done by yourself.. Marking all locations of springs and the governor settings are critical
Jul 09, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Lawn mower miss firing changed the spark plug. When started it's making a punting sound. What would be the solution?
Did you hit something with your mower? It sounds like a timing problem. The shear key may be dented throughing off your timing. The shear key is located between the flywheel and the top of the crankshaft. Remove the top cover to your engine and any attachments. Remove the flywheel. Check the key, I believe you will find your problem, a deformed shear key. Get a new one, replace all parts,and you should be ready to go. GOOD LUCK.
Jun 29, 2011 | Yard Machines Garden
Brand new and cant pull recoil
You say brand new so I assume that your pull cord has tangled up somehow. Things happen sometimes for no reason. To fix and check, remove the top cover to your mower and any attachments. The recoil is in the top cover. Look at it closely and try to loosen the cord. . Replace top cover and your ready to go. GOOD LUCK.
Jun 29, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
The pull cord does not rewind properly
A lot of times the rewind will get crud in it. Try removing the engine cover and spray a good silicone spray behind the rewind pulley and pull the cord many times while doing this to work the lubricant in. Usually works.
Apr 26, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Need to remove the starter on a Yard Machine 32hoe253869069
What kind of engine is on the mower? If its a briggs and stratton engine generally the starter is on the right side. The gear is covered with a plastic cover held on with a very small screw on one side and the other slides into the engine cover. The starter should be held on with two bolts behind the gear on top. They can be a pain to remove ( kind of a tight area) . the only bolts holding it on should be the two at the top of the starter/
Aug 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I remove electric clutch pulley on Craftsman 917.257720 lawn tractor?
if i'm not mistaken there should be a bolt in the center of the clutch that screws to the crankshaft remove top cover and have someone hold a wrench or socket on the top nut while another unscrews the bolt running through the clutch (righty tighty lefty loosey) may need to unbolt the steel rod that keeps the clutch housing from spinning. also dont forget to unplug the wires hope this helps
Jul 19, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
I have an MTD Yard Machine, model # 12A446D062. The starter rope tore, cannot find a part # for rope and do not know how to replace. Help!!
Remove the engine shroud cover bolts and get a comparable size diameter and length rope and reinstall.
Jul 14, 2009 | Yard Machines Garden
Carbaeurator problems - 22" Yard Man push mower
That is the intake tube. You have to remove the rewind starter housing and the armature (what the sparkplug wire is hooked to) and unscrew it. IfI knew the engine model and type numbers, I could tell you the part number for the tube. They are located around the spark plug and stamped into the cover. Model-Type-Code.
Jun 18, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
