Question about IBM Lenovo ThinkCentre M55e PC Desktop
After i change the processor on the IBM thinkcentre M series the monitor only showing processor product name number config F1 and pause it
    Problem Solver:
  • 8 Answers
Possibly you need to flash the bios. there should be options in the post setup menu. be very careful flashing the bios. IT MUST BE DONE RIGHT THE FIRST TIME. if you never have, get someone with experience!!!!!!
Posted on Oct 14, 2013
4 Suggested Answers
pagebor
  • 2785 Answers
SOURCE: Computer switches on but does not boot (processor fan can be hear
plz try by resitting the ram
Posted on Nov 19, 2008
APremkumar
  • 564 Answers
SOURCE: i want network driver for IBM Thinkcentre please
http://www-307.ibm.com/pc/support/site.wss/TCTR-MATRIX.html
Here is what you need. Just click the Link Above and select your model. Please Rate My Response! Thanks!
PREM
Posted on Feb 21, 2009
  • 166 Answers
SOURCE: IBM ThinkCentre 8183 (M51) does not boot
The situation you describe is usually 1 of 2 things, Power supply (PSU) or Motherboard (mobo).
Situation #1: If you get a blank screen and no sounds or movement it either indicates that the power supply unit (PSU) has failed or something on the motherboard has failed, preventing normal startup. Fans are usually the first thing to get power, then the mobo for the Power on Self Test (POST).
Situation #2: You might get some power lights coming on and some fans spinning but the video output does not happen and normal startup sounds do not take place, usually indicates that motherboard is going out or has gone out. OR it may be due to a weak (damaged) PSU.
Always try a different power outlet that you know is working. (Eliminate the easy stuff first!)
If it is out of warranty, try opening up the case, with the power off, of course. Also take this time to inspect the capacitors on the motherboard (they look like tiny soda cans) and check for tops that are bulging, swelling or leaking anything. Capacitors should be perfectly flat on top. If you find these then your motherboard is bad (well technically the capacitors on your motherboard are bad). The bad caps will need replacing to fix (not a job for an amateur). If it passes the visual inspection then it may just be your power supply is bad. Notice that a bad PSU does not mean you are getting no power, just not enough to start and run the computer.
A few years ago a company stole the recipe for making capacitors and started making their own capacitors at really cheap prices. The stolen "recipe" was not complete and not correct so these caps started failing after about 2-3 years of use. Emachines, DELL and Gateway were the computer companies most affected by the bad capacitor issues, although any of the big companies could have the same problem. These bad caps also affected power supply makers.
Since you have tried removing components then it looks like you have narrowed it down to either the power supply or motherboard. If your motherboard looks ok and if you can get another power supply that has an output watts that is greater or equal to the one that you have, try replacing that first.
Posted on Apr 14, 2009
Intel pentium 4 3ghz driver download
There are no drivers for CPUs.
The drivers are motherboard and device specific (the motherboard can be regarded as a device).
They will also depend on your operating system (which you should specify)
Your computer is an
IBM ThinkCentre A51 8123 isn't it ?
Go here
http://support.lenovo.com/gb/en/products/desktops-and-all-in-ones/thinkcentre-a-series-desktops/thinkcentre-a51
Enter any chosen parameters in the drop down menus at the head of the table, eg drivers for what component, operating system, to narrow your search, and look for what you need. Good luck. Report bsck if you have problems
10.December.2014
Aug 08, 2014 | IBM Computers & Internet
After i change the processor dual core 1.80ghz on the IBM thinkcentre M 55e 9632 series the monitor only showing, cpu=1processors detected,cores per processors=2 intel pentium dual cpu 2160 1.80ghz 1527...
HI,
I am sharing some general info:-
If you are change processor no problem, some point see you like after change processor any beep sound, processor more hitting.
Second check it *********** board power come or not, your display cheap more hitting or not. Check RAM proper connect, your all cable proper connection. If all things ok then may be your PC not supported processor.
Thanks..
Oct 14, 2013 | Lenovo ThinkCentre M55e 9632 PC Desktop
The computer shows the is sound while i dont get anysound
"This device is working properly"
Sure, and I'm Brad Pitt
Suggest reinstall Audio Driver
("I'll be your Driver for today, but we have to limit the bathroom breaks"
No, wait...........I mean...........
Driver: Small piece of software that allows the Operating System to communicate with a device.
The Audio (Sound) chipset is the device.
The version of Windows operating system was not stated ]
http://support.lenovo.com/en_US/landing.page?
> Drivers & Software,
http://support.lenovo.com/en_US/downloads/default.page?selector=expand
Click on the Audio tab.
Now I need to stop.
I need the full product number.
IBM = Manufacturer
ThinkCentre = Series (S Series)
S50 = Subseries
I need the Machine Type, and Model that comes after it.
Example? IBM ThinkCentre S50 8183-26Y
[Back of computer ]
Also need what Operating System you are using.
What version of Windows?
Post back in a Comment
Regards,
joecoolvette
Apr 10, 2013 | IBM Thinkcentre S50 Main Board ...
IBM 9211 D35 driver downloads
Go to www.ibm.com
Click on the appropriate tabs for "support" and locate your model number.
Save all downloads to a common folder then save the drivers to a disc
Feb 16, 2013 | IBM ThinkCentre Computers & Internet
My ibm thinkcentre computer does not produce s music and video sunds.what is the name sound driver do i need to dwnload?
Open Device manager (Windows + Pause Break) > Search for Audio device > Click (+) icon > There is your sound device name
Feb 17, 2011 | IBM ThinkCentre S50 8183 - P4 3 GHz...
After i change the processor on the IBM thinkcentre M series the monitor green light just flicer all the time while the pc is on the cd rom green light just flicker on/off all the time the fans are running...
there are two reason for this problem. and the most probably is the first reason below.
1. your motherboard is not supporting the installed processor. although it powered up all the components and parts but the processor dont work at all.
2. even if your motherboard supports the processor and it works fine then there is problem with the VGA.
Finally to check the motherboard and processor whether they are working or not.
please remove RAMs from motherboard and start your computer and now if it gives the beeps sounds then motherboard and processor are working. and if you dint listen any beep sound then the installed processor is not being supported by motherboard.
Please dont forget to RATE my answer.
Sep 09, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
Driver provlem
Is it possible it's a Sound Blaster Audigy?
http://www-307.ibm.com/pc/support/site.wss/MIGR-51794.html
Hope this helps!
Mar 28, 2009 | IBM Computers & Internet
Where can i get the sound driver for my motherboard intel d865gkd
The sound driver you need is the SoundMAX Cadenza driver. according
IBM YOUR IS http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-51191&velxr-layout=printLenovo
Thank you.
Mar 26, 2009 | Computers & Internet
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
IBM Lenovo ThinkCentre M55e  PC Desktop Logo
60 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
