Question about Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand
Kohler K3386 leaking water from seat anchors - Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand
3 Suggested Answers
  • 3 Answers
SOURCE: What is the best way to remove stuck toilet anchors
try rotating the entire toilet counter clockwise so the bolts are in the insert slot of the toilet flange and rotate the nut and the bolt head should line up and pop free of flange.
Posted on Oct 31, 2009
  • 3600 Answers
SOURCE: How do I replace the toilet seat on a Kohler
I repaied one of these laast week and it had the Plastic nuts in between the webbing on the seat where the lid connects I believe You remove the plastic cap with a knife and use a flat tip screw driver to remove the screws and replace the seat.
Posted on Jun 01, 2010
After flushing my Kohler 3386 Rialto Toilet the top of the valve assembly shoots water out while refilling the tank wich hits the tank top and leaks down the front. What do I need to do to fix this? ...
sometimes removing the 3 or 4 screws that hold the top of assemble and separating the assemble will dislodge debri..and adjust the seat so that the water comes out of the small tube into the overflow tube like it should.
Nov 25, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
How do we replace the seat on a Kohler K-3386-0 Rialto one piece toilet? The screws/nuts holding the seat down are inside the toilet and aren't accessible. Is there a way to replace the seat without...
Kohler will try to sell you $46 anchor bolt kit 84999 & also there special tool. You should expect that for a $400 toilet.
Try this instead:
1. Use 1/8" drill bit and drill and drill around the bolt until the anchor material can be removed.
2. Carefully clean hole with 11/32 drill to remove all remaining acchor material.
3. Go local hardware store & buy a 10 - 32 3/8"X3/4" rubber expansion plug (make certain threaded part is brass & has shoulder on 1 end), a 10 - 32X1.5" Phillips bolt and couple of small fender washers fit the seat.(about $4 for 2)
4. Assemble carefully not to over tighten and crack the porcelain.
Hope it helps
Oct 06, 2010 | Kohler K-3386-0 Rialto one-piece...
I cannot get the toilet flapper to fit on my K3386 toilet. Can you help find the right part and with installation?
go to your local Kohler showroom. they will be able to fix you up with the correct flapper.
Sep 05, 2010 | Home
I just installed a kohler toilet fresh from the crate. The fill valve runs every few seconds for just a few seconds. I suspect a leak but can't find any water drops in or around the toilet. Can you...
possibly the flapper valve not seating properly..
open lid of tank, check if chain to flapper is too tight, then check if something blocking flapper from seating properly
Jun 13, 2010 | Kohler Home
Jun 01, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
Get seat of Kohler K-3386
Roberta3fan could be giving bad advice based on experience with other toilets. This does not seem to be an option for this toilet design. I am in a similar situation and it appears that the nut (and it is a metal bolt) is not what you would expect. Here is a picture of the anchor kit for this toilet seat: http://www.plumbingsupply.com/images/kohler-anchorkit-84999.jpg I am going to assume that the sleave that should be engaging the bolt is cross threaded and try to grab it with a pair of vice grips. I'll let you know if it works.
Jan 09, 2010 | Kohler K-3386-0 Rialto one-piece...
Toilet seat
Here's what I did. Unscrew them as much as possible. Then I used a bolt cutter and hacksaw to cut away as much of the plastic seat holders as possible. I could then remove most of the seat, and get better access to the screws. I then raised the loose screws enough to cut them with a bolt cutter. Soft screws cut easily. The screw heads are now out. Now, tap down on the screw/anchor and it falls into the bowl. It will stay there. The remaining problem is that you need anchors to secure the new toilet seat. Kohler wants $50. I have a usable but loose seat. Never again-Kohler.
I strongly recommend using a boltcutter. A hacksaw will tear up the bowl.
Nov 25, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Oct 30, 2009 | Kohler K-3384-2 San Raphael Elongated...
Kohler Rialto flap valve leak
if so cut 1/4 inch off the bottom of round part of flat valve
Feb 23, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand Logo
48 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
