Question about Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator
Replaced water filter, ran the water thru for 3 minutes....around 2min 45 sec the water turned hot...it is almost 4 years old,,,what's up
2 Suggested Answers
vanni7
  • 163 Answers
SOURCE: suction
hi!!! clean motor blower blades ,they collect alot of duct and the air in chopped,Good luck.Clean blower fan blades..
Posted on Feb 04, 2009
Hansgrohe PB shower cartridge (brand new) passing water thru cold side with valve turned off. Six-year old cartridge replaced the other day. Removed side filters and cleaned. O-rings ok. Applied silicon...
What is the model number of the unit in question? What color was the old cartridge in the valve and the new cartridge that you replaced it with? If no model number do you have any pictures of this valve/trim in question? It could be that you got the wrong replacement cartridge or something is not properly aligned within the valve. Feel free to contact me direct at Hansgrohe. I'd be happy to help. 1-800-334-0455. Press 2 for tech and ask for David. Or email me at david.scarborough@hansgrohe.com
Jan 07, 2013 | Hansgrohe Plumbing
Onga water pump not pumping water thru to house
either water lock or motor burnt out ,
Mar 17, 2012 | Plumbing
Stop 2min and run for 2min, stop 2min and run for
your motor thermal safety relay is protecting the motor from burning out
this is usually caused by: an old motor about to fail (tight shaft bearings) bad centrifical switch or, an obstruction in the water flow causing the motor to work too hard (draw too many amps, get too hot then cool down and, start up again
check the relay it is located on the side of the motor on most motors; under a cover; unless the motor is bad the relay may just be too sensitive (old) and, may need to be replaced.
Jul 24, 2010 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
No heat
The fix is take off heater hoses get 4ft 3/4 heater hose fitted it to the top port on heater core used one of the squeeze clamps to keep it from pouring out around the hose poured in the black bottle of draino slow process i could tell it had a block only a little poured it in at a time did this twice rinsed with hot water then took the spray nozzle on the end of the garden hose put it into the 3/4 hose used a screw clamp to tighten down the 3/4 hose to the spray nozzle then turned on the water full blast & wow it took a minute but blew a wad of rust out till it ran clear the hooked up the bottom heater hose and let it flush the heater hoses alot of rust came out no cleaner you buy at any autopart store helped your method is the best method i have ever seen & it work's I HAVE HOT *** HEAT NOW THANKS to this person & again thanks SO MUCH FOR PASSING THIS ON ANY ONE ON THIS SITE IF ITS NOT LEAKING POWER FLUSH THE HEATER CORE IN DETAIL NO NEED TO CUT THE HEATER HOSES TAKE THEM LOOSE FROM THE CORE & flush it till its clear 45 min tops saved me mega dollars i recomend every late spring early summer flush the entire cooling system & the heater core old saying 1 ounce of prevention is worth a pound of cure tahnk you so much..........
Nov 11, 2009 | 2001 Jeep Grand Cherokee
Insufficient Pressure From Pump
Take the strainer at the end of the hose on the tank off. Throughly clean it. I used an old tooth brush, then ran hot water through it several times. Also drained the tank and flushed it out 3-4 times with fresh water, then ran fresh water through the pump for several minutes
Hope this helps
Aug 03, 2009 | Fimco Spot Sprayer, 25 Gallon, 3.8 GPM, 45...
Problem with KitchenAid KUIA18PNLS0 Under-Counter 18-inch Ice Mak
There is no solution. I have three kitchenaid ice makers and they do not work. The 18inch was under warranty. I had it serviced every friday until warranty ran out. I put an inline filter on the machine and it ran like a charm for three months, which is a first. It's out again! The two 15 inch same thing... inline filter and it worked for a month. Yes I have cleaned the machine over and over with appropriate products. It will turn on water fills but it appears as though the pump is not moving the water. Either way the machine worked correctly for two years only for the 15 inch and for the 18 inch one year.
Jul 15, 2009 | Kitchen Appliances - Others
No fuel to the cyciders
there is another pump in the tank, it is callled the low pressure lift pump.
Apr 20, 2009 | 1986 Ford Econoline
Electrolux EI28BS56IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
18 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
