Question about Lenovo Computers & Internet
Onboard graphics controller not functioning. I need part # for replacement PCI VGA Video card. Thank you, Jeff Hempenius hempdolphin@icloud.com
    New Friend:
  • 156 Answers
You don't have enough information for anyone to help you we need your PC brand and model number but based on your problem I would check the Bios sometimes you have to turn your onboard graphics controller on also some older computers have a jumper setting on the mother board for this and it wont work if you have another pci video card installed so uninstall any pci video cards you have inside the computer
Posted on Oct 13, 2013
SkullyFox
  • 93 Answers
SOURCE: video graphics card
being a PCI card, not a AGP or PCI-E the system may not simply switch to that one a primary display adapter when you install it, in the bios under advanced system settings or intergrated periferals, you should have an option to change the primary display adapter, make sure a PCI adapter is included.. if it isnt, chage it to recognise a PCI card as a primary adapter, turn the system off, and install your card then, depending on the bios/model of the mainboard on some of those dells, it may be a little hard to find, ive had to play with a few of them
Posted on Dec 06, 2007
SOURCE: Motherboard - disable onboard graphics
1. open your cabinet.
2. remove the battery form the motherboard.
3. wait 15 seconds and then replace the battery again.
4. connect your screen to the pci ex card.
now it should work.
CS
Posted on May 15, 2008
tunmun
  • 413 Answers
SOURCE: H Slimline New Graphic Card-No new DCI output-Yes old VGA output
you are missing nothing actually the graphic card over rides the onboard graphics and you have to use the graphic cards output ,only one hardware at a time for pci devices
Posted on May 08, 2009
  • 13433 Answers
SOURCE: replaced power supply on T2240 emachine now cant get onboard video" or any video,also tried PCI video card with no results. Need video to see if machine can boot
the fact that your not getting any video is that your computer is not booting or it can't boot right now.
might be best if you found someone to test and help you with it or if you took it to someone.
Posted on May 21, 2009
bob_computer
  • 3153 Answers
SOURCE: Onboard VGA port disabled, in Vista
You should try to disable it in the hardware list.
E-machines have an odd bios where not all the functions of the motherboard are available to the user.
If you can find the make and model of your board there is a good chance you can find the PROPER bios for it.
Emachines use motherboards from a variety of regular motherboard suppliers
My older e-machine has a hacked bios so that I can alter ALL the settings.
Posted on Aug 24, 2009
Conflict with onboard video
your onboard video card and your video car will not work together.. you need to configure at your virus set up.. thank you and have a nice day....
Apr 29, 2011 | Jaton Video-208PCI-64Twin GeForce MX4000...
When i install my video card the screen is blank
Use onboard graphics and enter the BIOS/CMOS by pressing the delete key during boot.
Go through the options, some-where there, there should be an option to enable PCI-Express slot, PEG when one is inserted. This need to be set.
So onboard VGA is disabled unless PCI-E Graphics card/PEG is inserted.
damnor01
Jan 25, 2011 | PNY GeForce 6200, AGP Video Card
Im trying to install my ATI Radeon 9250 265mb graphics card and I have installed the Catalyst control center but when i turn off my computer and unplug my machine and put in the graphic card (PCI) And boot...
There may be a setting in your BIOS for your video output.
If you were originally using the onboard VGA video output, there may be an option in the BIOS to switch to PCI output.
Jul 11, 2010 | HP Compaq Presario SR1820NX (ER919AA) PC...
I want to use a better vga but it isnt any port
Without a VGA port, you can't use a VGA card, pretty simple stuff.
If you want to add a video card, you will need to get a PCI video card (NOT PCI-E!) There are a number of them out there, and pretty much anything made in the last 3 to 4 years will be better than the on-board video...
Dec 18, 2009 | ASUS P5P800-MX Motherboard
PCI-E card does not work, onboard video works fine, this is the second card.
The Abit IP-95 manual doesn't show you how to adjust your bios settings when adding a PCI-E x16 graphics card. When adding a PCI-E card you'll need to adjust a few settings within, Advanced Setup.
Press the delete key on your keyboard every two seconds to load your bios menu. Within Advanced Setup look for, Onboard Device Configuration and open it. Find, Primary Graphics Adapter.
Set this to read as [PCI-E, VGA] save your changes and exit.
Currently your onboard graphics is enabled. You'll need to change this setting to PCI-E first. When you use the onboard UniChrome Pro 2D/ 3D Graphics & Video Controller you are also using some of your system memory to run the UniChrome graphics. Once you enable the bios to boot to the PCI-E card you can also stop using your system memory assigned to the UniChrome card. Link to Abit is provided below, click on it to open;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=IP-95&fMTYPE=LGA775
Cheers!
Mike
Nov 12, 2009 | Abit IP-95 Motherboard
Aug 24, 2009 | eMachines EL1210-11 PC Desktop
May 08, 2009 | Computers & Internet
Replacing the onboard graphics card
Friend,
There are three PCI slots on yoyr motherboard. You can add any PCI VGA card to your board. After adding the VGA goto BIOS setup and make ON BOARD VGA DISABLED.
Thanks & Good Luck
Iqbal
May 27, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Want to disable onboard graphics to install and use pci vga card
You should be able to turn it off by booting the pc up into the Bios and changing your video settings to AGP.
May 17, 2008 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
54 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
