Question about Vacuums
MY easyworship confertion cord has not giving a solution can u help
    Sergeant:
    Champion:
  • Vacuums Expert
  • 357 Answers
What is an "easyworship confertion" ?
Posted on Oct 21, 2013
Electrical cord needs to be replaced
Give me a little input on what you have-- such as:
Does the machine have a built-in-re-coil winder?-- Or do you have to wind the cord around the machine, when you wrap it up-- at the end of your vacuuming? (Obviously the latter will be much easier to replace! :-) )
May I ask WHY the cord needs to be replaced?
and what tools will you have on hand to do this job?
We are going to need small hand tools, -- Plus it would help to have a little multi-tester.
Let me know-- and I'll be able to help you to the next step.
Mack B.
Dec 30, 2010 | Vacuums
Cord won't retract or pull out. It is out about half way.
  • This is a common problem with retractable cords. Now because yours is not all the way pulled out you may be able to get it to go back in by giving it a quick **** on the cord. Not a long pull , but a quick tug! and it may release the jam. If not it will need to come apart and fixed. I will need the make and model in order to give you step by step instructions on this. Bissell makes many different makes and models and they are all slightly different from one another. so if this works for you great, if not write back with the make and model and I will give you step by step instructions on how to do this.
Oct 13, 2010 | Bissell Vacuums
The cord is all chewed up. How do you replace the cord?
Vacuum cleaner power cords are just insulated wires. It should be fairly easy and inexpensive to replace. You did not give a brand or model number, but hear is a list of available vacuum cleaner power cords
Jun 03, 2010 | Bissell 6594 PowerForce Bagless Upright...
How to take apart to replace power cord
In order to access the cord on the Miele S183 upright, you'll need to first remove the handle from the vacuum cleaner. There is a large screw that holds the handle in place that is located under neath of the lower cord wrap hook. Simply remove this screw, and slide the off the vacuum by pushing the handle towards the back of the machine.
Once you have the handle removed, now ope the bag door as if you were going to replace the vacuum bag. You'll see two screws directly above where the bag fits inside of the machine. These two screws will open up the switch and cord housing and give you access to the electrical cord.
You'll see that there are two screws that secure the cord as it comes into the vacuum from the back. Remove both of these screws so that the cord is no longer secured. I think the easiest way to replace this cord is to simply cut the cord (MAKE SURE THE VACUUM IS UNPLUGGED) so that there is about 4-5 inches of the cord jacket (rubber coating around the cord) remaining. You may now just pull this cord jacket off of the cord, along with the paper insulation so you have two bare wires of the old cord. Now take your new cord and push it into the back of the vacuum so that it comes through the switch housing. Instead of having to re-secure the cord with the two screws, I've found that if you tie a small knot in the cord, this works just as well at preventing the cord from pulling through the back of the vacuum.
Simply strip the wires that are left from the old cord, and simply wire nut the new cord after tying a knot (or re-securing it with the two screws), and reassemble the vacuum cleaner. Test the vacuum only after putting the switch housing cover back into place.
If you have any questions about how to do this repair, please feel free to use the clarification request form here on the Fixya repair page. If you found this helpful, please be so kind as to rate my repair as helpful by clicking on the 4 thumbs up icons in the top right hand corner of the repair. This is what keep Fixya's repair professionals continue leaving free repair advice on this site.
Here's a link to a blown up parts diagram to help you visualize how the vacuum comes apart.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/miele-s183-upright-parts-diagram.gif
Feel free to check out our website for any Miele supplies that you need:
Miele Vacuum Bags, Filters & Belts
Thanks again for rating my repair,
Chris J.
GoVacuum
Apr 07, 2010 | Miele S183 Powerhouse Bagged Upright...
Cord rewind hoover s3765
Remove the 5 Phillips-head screws carefully without stripping the heads. There are 2 at the front bottom, 2 at the top back (above the wheels), and 1 at the back beneath the dustbin. After the screws are loosened/removed, you can remove the top cover of the vacuum (be careful with the attached wiring harness). Then remove the black plastic cover over the cord rewind wheel, and you can easily remove the wheel. Pull the cord out a bit to give yourself some slack. You should be able to free the jammed cord and then reassemble the vac.
Nov 14, 2009 | Hoover S3765-040 WindTunnel Bagless...
Change cord on electrolux EL5020
In order to get to the cord that is disconnected you need to remove the screws that hold on the frame(the red shell). You will need to remove the "fenders" that are near the wheels. In order to remove the fenders get a flat tip screwdriver and pry up on the front part of the fender, there are three clips holding the left one on and two holding the fender near the cord. You will need to remove the left wheel (the wheel farthest from the cord). After you remove all the exterior screws and the four screws under the brissels the shell should be able to be removed. Next you will need to pull the cord all the way out and there will be a clear clip, use a flat tip screwdriver and release the clip in order to remove the clear piece that holds the power cord electrical ends. Reattach the clips of the power cord and be sure when you put the clear piece back in that the two contacts are not bending. You will need to use a screwdriver to guide the electrical clips back into place. I didn't count the screws there is a lot of them. I hope this helps you
Sep 20, 2008 | Electrolux EL5020 Vacuum
Replacing the electical cord on Kenmore Progressive Vacuum
To the right of where the cord comes out of the machine is a large screw. Remove it, and slide the upper handle assembly free.
Then, on the front of the machine, remove the screws located toward the top of the vacuum just inside the bag chamber cover. This will allow the front panel to be removed, giving you access to the cord from the front.
-R
Sep 15, 2008 | Kenmore 31913 Progressive Direct Drive...
Sebo K 3 Vacuum
I had a problem with my K1 Komfort model which sounds similar to this. I initially thought the cord was too short but the machine wouldn't give out anymore and retracting was difficult. A Sebo engineer/helpline told me to pull roughly on the cord, of which I did and was rewarded with 2 metres more than what I thought I didnt have! So, perhaps if your machine isn't retracting properly, give the cord a rough pull with gloves on, or a strong grip - the cables on the K series are notorious for stopping up. Afterwards wipe the entire cord down with furniture polish; it will retract much more quickly.
Feb 21, 2007 | Sebo Air Belt C3.1 Bagged Canister Vacuum
Vacuums Logo
41 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
