Question about Monster Beats By Dr. Dre Solo Hd S450 Wireless Bluetooth Stereo Headset In Box
User guide s450 bluetooth headphones
Manaul
Installation Manual for TX500
Hi Kathy Cox,
You can access the User Manual for your TX500, at this link:
http://bit.ly/1sCM4uU .
Regards,
Gaby
Motorola Mobility
Oct 12, 2014 | Motorola Mobility TX500 89494N Bluetooth...
Can beats s450 be connected to any soundbar?
If the soundbar is Bluetooth-enabled, yes. But I have not read or heard about a Bluetooth-enabled soundbar yet. And why would you want to connect the headphones to the soundbar ? The only situation where this would make any sense is if the soundbar were hooked up to a TV. If this is the case, your only solution is to use regular (not Bluetooth) wireless headphones, which consists of two pieces: the headphones and a transmitter that you hook up to the audio output of your TV. The transmitter piece transmits any sound coming out from your TV wirelessly to the headphones.
Sep 27, 2014 | Beats By Dr Dre - Wireless Bluetooth...
How to connet bluetooth on nokia 5230
Bluetooth is a wireless technology that allows devices to communicate via high-frequency radio signals. Bluetooth headphones are just one of the many devices designed to work with portable music devices as well as ordinary phones. With Bluetooth headphones, you can listen to music as well as make and receive calls--all from the same device. Connecting them is a snap.
  • Turn on your cell phone. Enable Bluetooth by accessing your phone's general or network settings. Your phone will search for Bluetooth signals in the area--they are usually denoted by a small icon displayed on the screen. If you don't know how to turn on Bluetooth or aren't sure whether your phone supports Bluetooth technology, refer to your phone's user guide.
  • 2
    Turn on your Bluetooth headphones while near your cell phone. Turning on a Bluetooth-enabled device will usually put it in pairing mode, meaning it is actively searching for a device to connect to. Since your phone also is actively searching for a Bluetooth device, it should find it right away and prompt you to connect to it. It may ask for a password--refer to your headset's user manual for the default password and how to change it.
  • 3
    Test your connection. Once your headset is paired, the phone will usually start sending calls and audio to it without any additional configuration. Some phones may prompt you and ask which device to use. Try making calls and/or playing music. If you hear music from only one ear, your phone may not support stereo Bluetooth. If you don't hear anything, re-pair the headphones. Power off your phone and headphones, then turn them back on and repeat steps 1 and 2.
  • Dec 09, 2011 | VXI Corporation Blueparrott B250-XT...
    How can i connect my bluetooth headphones
    Things You'll Need
    • Bluetooth capable phone
    • Bluetooth headphones
      • 1 Turn on your cell phone. Enable Bluetooth by accessing your phone's general or network settings. Your phone will search for Bluetooth signals in the area--they are usually denoted by a small icon displayed on the screen. If you don't know how to turn on Bluetooth or aren't sure whether your phone supports Bluetooth technology, refer to your phone's user guide.
      • 2 Turn on your Bluetooth headphones while near your cell phone. Turning on a Bluetooth-enabled device will usually put it in pairing mode, meaning it is actively searching for a device to connect to. Since your phone also is actively searching for a Bluetooth device, it should find it right away and prompt you to connect to it. It may ask for a password--refer to your headset's user manual for the default password and how to change it.
      • 3 Test your connection. Once your headset is paired, the phone will usually start sending calls and audio to it without any additional configuration. Some phones may prompt you and ask which device to use. Try making calls and/or playing music. If you hear music from only one ear, your phone may not support stereo Bluetooth. If you don't hear anything, re-pair the headphones. Power off your phone and headphones, then turn them back on and repeat steps 1 and 2.
    Jun 12, 2011 | Cell Phones
    I go to set up my wireless headset with my playstation 3 but it won't pick up any devices.
    You must put both the PS3 and the Backbeat into pairing mode. See your instruction manual for the PS3 for pairing. Once you have both devices searching for each other they should pair right up.
    Instructions for putting the Backbeat 903 in pairing mode:
    With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
    Use the PS3's menu to search for the Bluetooth headphones and select 9xxBackBeat.
    If prompted, enter 0000 for the PIN code/passkey.
    Here is a link for the User's Guide:
    Plantronics Backbeat User's Guide
    Good luck from Headsets Direct!
    Mar 23, 2011 | Plantronics Backbeat 903 Bluetooth...
    I just purchased Plantronics BackBeat 906 and am receiving sound only from one earpiece. Is there a setting that I am not aware of that could be causing this problem?
    I would try the reset option listed in Plantronics user guide. Here are the steps for the reset and I will include the link to the user guide also.
    Instructions to Perform a system reset:
    While plugging in the AC charger, hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset.
    Jan 28, 2011 | Plantronics Backbeat 903 Bluetooth...
    I need to know how to sync to my iphone4
    Pairing Your Headphones and Phone/Device
    1 Turn on your phone’s or device’s Bluetooth® feature.
    2 With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
    3 Use the phone or device menu to search for the Bluetooth headphones and select 9xxBackBeat.
    See your phone’s or device’s user guide for more information.
    4 If prompted, enter 0000 for the PIN code/passkey.
    Some phones also require that you accept the connection. Pairing is successful when the LED indicator flashes blue.
    (from plantronics website)
    -The Determined Observer (TheDeterObs)
    Jul 13, 2010 | Plantronics Backbeat 903 Bluetooth...
    How do i connect my backbeat 903 to my phone
    (from plantronics web site)
    Apr 04, 2010 | Altec Lansing BackBeat Plus Mobile ...
    Monster Beats By Dr. Dre Solo Hd S450 Wireless Bluetooth Stereo Headset In Box Logo
    Top Monster Radio Communications Experts
    eradiostore
    eradiostore
    Mike Charette
    Are you a Monster Radio Communication Expert? Answer questions, earn points and help others
