Question about Proscan Televison & Video
I have a 40" Proscan TV, It suddenly would not let me select the appropriate device from my Input dropdown on the TV. It will come up, and I can move the highlight to the device I want, but cannot get it to select it. what do I need??? I tried a different remote, but haven't had any good luck with that, bought a new universal remote, nothing!!!! HELP!!!
  • Cheryl
    Cheryl Oct 13, 2013
    I don't have a cable company that I use, That is why I have devices that connect to the internet, for netflix, hulu, youtube, etc.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Problem Solver:
  • 19 Answers
CALL CABLE COMPANY THAT YOU GUYS USE THEN TELL THEM UR PROBLEM! LET ME KNOW IF U NEED ANYTHING ELSE. (:
Posted on Oct 12, 2013
  • 362 Answers
SOURCE: remot not working for Sens TV/DVD 19''
Hi sifrid,
Program the RCA remote with the instructions below, this will tell us if the problem is with the remote or the tv.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Lone99star
Posted on Jan 27, 2009
SOURCE: lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Posted on Mar 17, 2009
  • 814 Answers
SOURCE: proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
Posted on May 21, 2009
SOURCE: need a remote control code
hi,i had the same problem and found out that the samsung remote codes worked,try that.
Posted on May 30, 2009
  • 54 Answers
SOURCE: VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Posted on Jul 07, 2009
Have a 19" Proscan flat screen TV. Can't get the channels back.
Not enough info
Channels from the air cable/satellite/fios
Using the tv to change channels or other device.
Is the INPUT button on the correct input port
Sep 28, 2015 | Proscan Televison & Video
Proscan tv input without remote
Without its remote control, you can't select the inputs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Apr 03, 2014 | Durabrand DWT1905 TV
Proscan 40lc45s won't stay on
Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Proscan 40LC45S 40 in. LCD TV
Can't find input setting on old proscan tv. tried channels 90/91/92. only white fuzz
You are trying to connect the TV by AV setup. You have to select the input selection to TV to AV. If the TV have a Menu button on its front panel, you can enter into its menu options, surf through, and select the input selection window. Here you can select input to AV.
If there is no 'Menu' button on the front panel of the TV, you can'd do this selction. You must have its remote control to select this option.
Jun 01, 2012 | Proscan PS27125 27" TV
I cannot get my Proscan 40" lcd HDTV out of
Check the resolution on your signal source. Well, first before doing that make sure the Proscan is on the right input i.e. make sure it is on the hdmi input if you have it and you signal source connected with an hdmi cable and then make sure the resolution on the signal source is 1080i fixed. Then there should be a button on the signal source remote (# hdzoom or format or aspect). You should be able to change the picture size with the #hdzoom, format , or aspect button.
Feb 03, 2011 | Proscan 40LC45Q 40 in. LCD TV
How to hook up a dvd on a proscan ps32600 tv
This tv has 2 AV inputs at rear to connect dvd player or any other video source.
Plug RCA video cable in AV Input-1 at rear of tv and select Input-1 source in tv remote to get dvd player playback picture in tv.
Click HERE to download user manual free copy that has details about tv operations.
Hope these info will help you.
Thanks.
Nov 26, 2010 | Proscan PS32600 32" TV
I have a proscan tv model #PS27108, I do not know how to hook up the dvd player in regards to the cords and what channel to put it on? I would appreciate any help with this! Thanks in advance?
The ProScan will accept input on input 90/91/92 using the connectors on the backside. You can use S-video[the little round black connector] or the composite video [yellow connector] for the video in and use the red / white pair for audio in.
90 selects S-video and audio 1 in
91 selects composite and audio 1 in
92 selects composite in 2 and audio 2 in
Connect these cords to the S-video or composite yellow output, and the Red-right White- left audio outputs on the DVD.
If you don't want to do this, get a RF modulator ~$15, and connect the yellow/red/white from the DVD output to the inputs on the modulator, and then connect the RF [cable] output of the modulator to the antenna input on the ProScan, and tune channel 3 or 4.
tom
Oct 22, 2009 | Proscan PS27108 TV
Trouble with 360 and hdtv
The cable your refering too are called Component leads.
The red and white are for your audio and the remainder are the video. All you need to do is connect the component leads matching up all the colour in the correct ports then using your av/source button change the tv to component
You will still have to connect the red and white audio cable to the tv as well.
that should sort your xbox out.
cheers
Little Dish Fitter
Sep 18, 2009 | Proscan PS36700 36" TV
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Feb 03, 2009 | Proscan 32LA25Q 32 in. LCD TV
RCR3273
It may be you have the wrong code assuming everything else works fine.
Go to:
http://66.77.167.109/rcaaccessories/RcaaccessoriesController.do?ACTION_TYPE_ID=ACTION_TYPE_CATEGORY&ACTION_CATEGORY_ID=STR_CATEGORY_UNIVERSAL_REMOTES
and on the left of the nav towards the bottom you'll see the remote code finder.
Click the link and select your model number from the dropdown, in this case, RCR3273 and then select your device from the dropdown. The codes are listed by manufacturer alphabetically. Find the codes for your brand of TV and try all of them.
Good luck.
Dec 26, 2008 | RCA Universal Remote 3 Device Remote...
Televison & Video Logo
29 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
