Question about Ricoh Office Equipment & Supplies
SC 569 EN LA AFICIO 2051 - Ricoh Office Equipment & Supplies
  • 24 Answers
SOURCE: how do I put a password on Ricoh Aficio 2051 printer?
go in to user tools, system setting, key operator tools or admin. tools. there you can set up password.
Posted on Oct 05, 2008
socalern
  • 48 Answers
SOURCE: my Ricoh Aficio copier 2051 the problem is SC
SC 863 indicates that there are bad sectors in your machines hard drive. You have two options. First, try to have your hard drive re-formatted (you do this through the control panel in the service mode) but beware, any documents stored in the document server will be deleted and so will the scan to folder pre-programmed in the machine.
Second option, assuming the re-formatting did not work, would be replacing the hard drive altogether
Hdd formatting procedures:
service mode entry: press clear modes, press 107 then hold down the clear stop red button for 10 seconds, screen will then change. select copier, then upper right side select "sp direct" then punch in 5832.
Execute 5832 001 to format the HDD.
Posted on Jan 16, 2010
  • 161 Answers
Bad hard disk, try formating it or replace it
Posted on Jan 17, 2010
Testimonial: "tanks."
joel_baleta
  • 155 Answers
SOURCE: sc 541 en aficio 1075 , cambié la unidad de
hello friend
SC541 indicates that you have a defective thermistor.
replace the two thermistor and run SC reset.
Posted on Feb 23, 2010
  • 126 Answers
SOURCE: ricoh aficio 2035 sc 322
sc 322 is a laser unit problem. find a ricoh technician and clean the laser unit or replace it. this laser problem is hard to solve usually.
Posted on Oct 01, 2010
Mon copieur ricoh aficio 201 affiche sc 120 error
netoie la bande blanche sous la petite vitre du chargeur
Mar 30, 2013 | Ricoh Aficio MP 201SPF Printer
En mi maquina aficio 650 sale el codigo de error sc 462-00
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 14, 2013 | Televison & Video
Sc 536 error code
Ol? tudo bem! o erro funcional (SC 536) trata-se de um cooler ou do sensor de temperatura que parou de funcionar levando o sistema a parar de funcionar por medida de seguran?a, infelizmente trata-se de um daqueles problemas que s? a autorizada resolve.
Jan 14, 2013 | Ricoh Toner for Aficio 1060, 1075, 2051,...
Sc 541 en aficio 1075 , cambié la unidad de fusión completa pero sigue marcando el error despues de 20 copias
hello friend
Feb 22, 2010 | Office Equipment & Supplies
Mi ricoh aficio 1013 sale error SC 552, quisiera saber a que se debe eso....!
así usted tiene un problema con la unidad de fusión, antes de llamar a un técnico que usted podría tratar de restablecer el código al entrar en el modo de servicio y restablecer el código de allí. Siga los siguientes pasos y usted podrá fácil de hacerlo:
1. pulse el botón (amarillo [C] cancelar)
2. a continuación, pulse el número en este
orden 1-0-7
3. a continuación, pulse el botón (rojo [C] parada) y por algún tiempo, hasta que en la pantalla LCD no aparece el menú de servicio.
4. cuando vas a ver el menú de servicio en la pantalla, oprima el número 1 sobre la almohadilla de número de la tecla y presione (OK) y luego con el cursor de flecha derecha al lado del botón (OK) Pulse hasta que vea en la pantalla el número [5.Mode ], cuando este está en la pantalla pulse el botón [OK] y luego otra vez con la flecha del cursor al lado de la [OK] pulse hasta que en la pantalla aparecerá el número de [810. Perdí mi código SC] cuando este aparece, pulse el número 1 en el número de teclado (confirmar que en la pantalla que está escrito el número 1 y presione juntos la tecla [OK] y la tecla para seleccionar el tipo original (esta clave se encuentraen el marco del [Aceptar]) Ahora que usted ha reinicia la máquina por la que se escuchará el sonido como empieza cuando se enciende por el tiempo que los abetos también si usted no presiona la tecla junto obtendrá un [error] en la pantalla LCD si esto suceda, inténtelo de nuevo, si después de algunos momentos de tratar de que no son capaces de reiniciar la máquina llame a un técnico.
Jan 14, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
How do I put a password on Ricoh Aficio 2051 printer?
Oct 01, 2008 | Ricoh Aficio GX5050 GelSprinter InkJet
Paper jam/misfeed constantly
creo que el sc 547 es el termostato del fusor de la maquina fijate reiniciandola en el modo "sp"
Jun 14, 2008 | Ricoh Aficio 1085 Laser Printer
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
