Question about Kenmore Sewing Machines
My sears sewing machine cams wont work it just sews a straight stitch or zig zag. I wonder if there is suppose to be a spring to hold it closer so that it follows the pattern on the cam.
    Champion:
  • 241 Answers
Yes there are springs and many other parts that need to make the stitch patterns. I suggest you take it to a qualified sewing machine repair shop. Often the pattern selector can be cracked, a linkage can be stuck or a dozen other problems will cause this.
Posted on Oct 13, 2013
bargainbox
  • 1388 Answers
SOURCE: singer sewing machine will not zig zag
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Denatured alcohol is fine, surgical spirit too, different countries have different names or products, essentially alcohol with few impurities that will evaporate quickly with little residue.
Hope this does work for you, tho' as I said, it may take a little time to penetrate depending on severity........the same applies to the reverse mechanism of many machines when they seize.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
bilabon
  • 46 Answers
SOURCE: zig zag stitches are not holding
When ever a machine is jamming up the bobbin thread, it is a result of your top tension. It is either set to low (under 4), or the thread has come out of the take-up lever. Check your threading, fromt he spool pin, down to 2 and up to 3. Three is the take up lever. From the take-up lever down to 4. Set the thread behind the thread guide and thread the needle form front to back. Low quailtu thread 9dual duty or all purpose) can also create this problem.
thanks,
Bonnie
Posted on Sep 02, 2008
RickE1
  • 202 Answers
SOURCE: Zig Zag Not working on my Bernina 830.
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps.
Posted on Dec 12, 2008
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
WonderTech
  • 268 Answers
SOURCE: Whenever I zig zag my machine skips stitches.
Try these solutions.
* Re-thread your needle
It may be threaded incorrectly (backwards).
* Reinsert your needle
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the
flat side away from the bobbin, but consult your machine’s manual to be sure.
*Change your needle
Your needle may be blunt, bent, or otherwise damaged.
*Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
thinner fabrics, smaller needles. You may also need a larger needle if
you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens (or a universal needle for either).
And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot
It may be too light for your fabric.
* Change your thread
If your upper thread and bobbin threads are different types, try using the same thread for
both. And use a good quality, brand name thread.
* Adjust your thread tension
It may be too tight or too loose.
* Re-thread your machine
It may be threaded incorrectly.
* Change your needle plate
Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important: If you change your needle plate, check to make sure your needle aligns perfectly with
this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which
could be dangerous. And make sure to change your needle plate back for zigzag and other wide
stitches.
I hope this helps you.
Posted on Sep 15, 2009
Testimonial: "great advice!"
My jones sewing machine wont stitch straight just zig zag tried moving parts
Probably the zig-zag mechanism has seized from lack of oil/cleaning. Pick up fresh, good quality sewing machine oil or Tri-Flow Synthetic Lube and apply a couple drops every place where metal rubs against metal (including the zig-zag mechanism). Do NOT oil any rubber or leather parts (belts)!!!
Then apply heat from a handheld hairdryer. Repeat until it loosens.
Aug 15, 2016 | Sewing Machines
Singer sewing machine
From the pattern selector (the bigger dial), select the zig-zag stitch. Then, using the stitch length dial (the smaller dial), adjust the stitch length. The closer your stitch length is to "0", the more dense will your zig-zag stitch be.
Sep 04, 2014 | Singer 2250 Tradition
TRADITION 2250 SINGER SEWING MACHINE HOW TO ZIG ZAG
Machine not picking up a zig zag stitch
it's possible that the cam that makes the zigzag stitch could be worn or damaged, it would probably be a good idea to have the machine checked.
Feb 23, 2014 | Brother XL-5700 Mechanical Sewing Machine
Kenmore 385.12490
Check the position of the Button Hole Stitch adjuster that is directly under the stitch length control. It looks like a flat head screw and should be straight up and down for normal sewing.
Jun 30, 2013 | Sewing Machines
Can't get the Husqvarna Viking Platinum 775 to do a zig zag
it's very possible that a cam or gear has worn down or broken
inside the machine and also if the sewing machine is computerized
then there could be a problem there, having the machine checked
would tell you for sure.
Nov 08, 2012 | Sewing Machines
I bought a R-2000 never used Necchi at an estate sale. Did not thoroughly read the manual before beginning to sew. Now it will only sew a zig-zag--think I did not use the release knob before changi
since you bought the machine at a state sale it would probably be a good idea to have the machine serviced.
you should be able to go from straight stitch to zig zag with out any problems.
if you move the dials or knob & the machine will not do a straight stitch then it needs to be checked
May 21, 2012 | Necchi Sewing Machines
Machine won't zig zag even though the needle goes from side to side the line of stitching is straight.
put in a new needle
rethread the machine top & bobbin--use every thread guide
make sure the zig zag settings are correct
it's also possible that the machine could have a worn or damaged gear or cam--which would have to be checked at a sewing machine shop
Mar 20, 2012 | Sewing Machines
Sewing Machines Logo
56 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
