Question about Sewing Machines
My bobbin thread won't come up, the top thread just tangles down below
    Champion:
  • 243 Answers
Several things can cause this start by replacing the needle. Make sure it is oriented such that the tip of the hook will pass in the scarf of the needle. The reason I write it this way is you have not described the machine you have.
Tangles can be caused by the take up lever not threaded or it could be a burr on the hook. It could also be the clearance between the bobbin case and the cushion spring.
I hope this jargon does not discourage you from trying the simple fix. My customers have learned it is easier to bring me their machine to diagnose it. Every day we fix a simple problem in under 5 minutes. and send them back to their sewing project for the cost of a smile.
Posted on Oct 13, 2013
  • 29 Answers
SOURCE: a horrible tangle
This is a bit late, could the bobbin case not be seated properly? You need to put it into place and then turn it clockwise until it seats soundly in the opening. Also, check for burrs...the needle may have left a rough mark on the plastic or metal in the bobbin area. A piece of batting, or even an old knee hi should snag on any rough areas.
Posted on Jul 14, 2007
  • 136 Answers
SOURCE: Singer 4622 drop in bobbin rattles
Recheck top threading
Posted on Jul 07, 2009
  • 9 Answers
SOURCE: burnette 65 bobbin tangling can't adjust thread tension
Have you replaced the needle with a new one? Your needle may be bent or in wrong, or the wrong size. You may have a bad needle. Check that the upper thread path is running freely and is not tangled or wrapped around anything. Make sure that the bobbin is unwinding in the correct direction as well, most bobbins, this is clockwise as the bobbin faces you. If you are using inexpensive thread, it could be the thread that is the culprit. Uneven thread in the needle will not flow through the needle properly, and cause bunching as well. Save it for the bobbin, and use good thread in the top.
Posted on Jul 17, 2009
SOURCE: I have a pc-8500 and
have a brother 8200 upgraded to a 8500. The touch screen seems to move to the right after some use. Is there a way that I can fix this or does it have to go to the shop.
Posted on Aug 23, 2009
bargainbox
  • 1388 Answers
SOURCE: top thread looks fine, but bottom thread is all
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Aug 30, 2009
Bottom thread is all tangled when I sew. Top looks fine, then flip it over and it's a mess.
is it the top thread that is too loose and making the messy stitch or the bobbin thread. if it is the top thread coming down and making large loops that tangle increase your top tension slowly try a few stitches, repeat till you get back to normal.
If it is the bobbin thread that is tangling, first make sure you are using the same thread top and bottom, some will just not work together, then rethread the bobbin, if it is still too loose there is a little screw on the side of the bobbin casing, the larger of the two, turn it no more than a 1/10 turn to the right if too loose and to the left if too tight. I would make the starting point with a piece of tape or nail polish so you can get back to where you were if this is not the problem. My book says you very rarely ever have to touch the bobbin tension. good luck
Jun 14, 2017 | Sewing Machines
Baby lock pro BL40, bobbin thread tangles, tried new bobbin, cleaned under plate, needle is straight, what to do?
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
could also be a timing problem
Jul 28, 2014 | Sewing Machines
Bobbin thread tangled
Try these suggestions and see if they help
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Dec 22, 2013 | Baby Lock Ellure
Tangled thread on wrong side of fabric, I did the remedy as per manual but problem still exist
Unthread the machine fully. Remove the bobbin. Is the bobbin thread the same as the top thread? Is it a Quality thread (yes, cheapie thread can give big issues!!) Do you have several different threads wound onto the bobbin?? Is the bobbin thread wound on quite tight? If you push your finger nail into the thread wound onto the bobbin, it must not feel soft or spongy. Check if there is any roughness / burr on the any part of the shuttle hook. If so, remove it with 800 grade wet and dry abrasive or similar. Put in a NEW needle as per user manual specs (not a 'new' one you used before 'just for a little bit'.!) REPEAT - put in a NEW needle - amuse me!!. Place the bobbin into the bobbin holder (the CORRECT direction - yes there is a Right and a Wrong direction!), thread it ready to put back into the machine. BEFORE you do, hold onto the thread tail and let the bobbin and bobbin case dangle. Thread should slip thru when you give a gentle pull upwards. If no slip, loosen the tension on the tension finger a LITTLE. If it slides down easy, tighten it a little. Fit the bobbin into the machine. Lift the presser foot (this releases the top thread tension discs) Check there are no bits of thread or fluff between the tension discs Rethread the top thread - check the thread path is 100% correct. Hold onto the end of the needle thread and draw up the bobbin thread. Hold both threads, start to sew - check the result. Tip : If you use a different color bobbin thread (same brand etc etc) it will help you to see more easily what is going on. You should be seeing some of the bobbin thread color on the top side of the sewing. If not, INCREASE top tension a little - retry.If there is a lot showing, decrease top tension. Good luck
Dec 14, 2012 | Sewing Machines
Top thread tangled in bobbin.
try changing the needle---flat side goes to the back side of the machine
also check the top tension
depending on the fabric your sewing on--the needle & thread have to work
with the fabric--example light fabric needs a different needle & thread than
a heavy fabric
check to see if the thread is coming off the thread take up lever when you
sew.
Apr 04, 2012 | Singer 8280 Mechanical Sewing Machine
My Brother XL-5021 sewing machine has stopped working and won't pick up the thread from the bobbin.
it's called being out of time,,and the machine can only be timed by a sewing machine repair technican,, because they have the tools for job
Feb 01, 2012 | Sewing Machines
First the top tension started being loose, so I changed the tension different ways and tried to fix it...now the thread is getting all tangled up under the fabric and is locking up. Also giving me the E6...
Do you mean the stitching on the top of the work was loose? If so, you should check the bobbin tension. Make sure you have the thread pulled under the tension plate or spring on the bobbin case. Tension should be just enough that you can suspend the bobbin in the case by the thread (think yo-yo). Upper tension should be tighter than lower. Make sure you put the presser foot down.
Sep 01, 2011 | Brother CS6000i Computerized Sewing...
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled....
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled. I cleaned underneath the bobbin holder but it didn't help.
Oct 13, 2010 | Husqvarna Viking 1
How do i put threed into the bobbin and keep it from not getting tangled?
Is it getting tangled while you're spooling the bobbin on the top right corner of the Singer 1507 machine? If this is the case, you have to pull the thread through the top tiny hole in the bobbin, and hold on to the thread end. Then click the bobbin to the right to lock it in place, power up your machine. Keep holding the thread as you begin spooling the bobbin. Let go of the thread once the bobbin starts to spin a few rounds and the thread should not get tangled.
Sep 29, 2010 | Singer 1507
Amatur Sewer?threads tangled below
Stop sewing! You need to adjust your tension. Your book will explain exactly how to do this. If you can't find your book, try setting the tensions to the same number. If your tension adjustments have a mark at a certain number, use that setting for most materials. If not, try setting it to about 3.
To test your settings, thread your bobbin with a different color, then do a test stitch. Check the top and bottom stitches for a spot of the other color thread showing through. If the bobbin thread shows in the top, raise the bobbin tension setting a bit and try it again.
Hope this FixesYa!
Aug 11, 2008 | Singer 3116 Simple
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
