Question about Eureka Vacuums
Eureka vacuum wont start model AS1101. not clogged
Eureka vacuum wont start model AS1101. not clogged not over heated.
    Sergeant:
    Champion:
  • Eureka Expert
  • 357 Answers
Possible bad cord, or bad plug at the end of the cord. Take it to a vacuum repair shop
Posted on Oct 21, 2013
DaVincii
  • 17 Answers
SOURCE: Eureka vacuum belt how do i replace on model #4688
How To Replace Brush Roll Belt
NOTE: Turn off the switch and unplug the electrical cord
before replacing belt. Belt pulleys can become
hot during normal use. To prevent injury, avoid
touching the motor shaft when checking the belt.
1. Lower handle to floor to change belt.
2. Loosen, but do not remove, two screws to release hood.
Lift hood to remove.
3. Lift left end of brush roll.
4. Remove and discard belt.
5. Place new belt around motor shaft.
6. Place belt around brush roll pulley.
7. Align left end cap with base. Push end cap
securely into place.
8. Pull right side of brush roll to stretch belt.
Secure right end cap into base.
9. Rotate brush roll to seat belt.
10. Replace the hood. Make sure hood front is
behind furniture guard. Hood should seat
onto self-locating screw tabs.
11. Tighten screws.
You can goto this website enter in the model number 4688 and you can see detailed pictures of how to change the belt as well as print off a new user manual.
http://www.eureka.com/servlet/FindOwnersGuide
Regards
Posted on Feb 14, 2008
  • 30 Answers
SOURCE: Burning smell and smoke
I ran into a scenario similar to this at work. With the burning smell and smoke combined, it leaves only one problem remaining; the motor. The motor and the pulley that enables the belt to spin could be malfunctioning (causing friction between the 2 parts) and thus causes the burning smell and the smoke. I'd highly advise not to touch either part after having the unit on (YOU WILL BURN YOURSELF).
The only other likely possibility is to make sure there aren't any hairs caught in or around the motor and the bearings of the agitator.
Posted on Mar 08, 2008
reddevil6
  • 1673 Answers
SOURCE: my eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Posted on Jun 17, 2008
dragonsthatk
  • 547 Answers
SOURCE: I have a Eureka 2961 avz bagless vacuum with no sucktion
please ask for Premium-Assistance:
Posted on Feb 13, 2009
Vac Belts
  • 701 Answers
SOURCE: We have a Eureka True Clean vacuum cleaner. Our
There isn't a difference really.
Posted on Dec 28, 2009
I have a new eureka vacuum AS1101 and the roller brush wont spin. The S belt doesn't look worn. When the clutch is engaged the second smaller toothed belt doesn't run. Are the larger and smaller pulley...
The answer is you small wheel that is burned or melted is a result of having the carpet height setting too low for surface being vacuumed. Because of that, it causes the brush assembly drive to work harder. The smaller of the two wheels has..had a piece of plastic to hold it against the shaft to allow it to turn. It will have melted off and will not spin. The belts and even the other larger wheel will work, but just not engage the smaller and allow the brushes to turn. The part needed does not sell by itself, you would need to purchase the on/off wheel assembly. OEM Part # 84708. It is about $30 on amazon shipped. new-eureka-vacuum-as1101-roller-brush-imoup3n5z40rufpnmkir3rab-3-2.jpg
Jul 17, 2014 | Eureka SuctionSeal Bagless Upright Vacuum,...
Hi, I have a question, I just got my vacuum 3 mouths ago and it shuts-off?
Your new filter should last more than a week but you may have to clean it thoroughly after each use. One problem with vacuums that do not have a bag is the surface area of the filter is usually not very big so it does not take much fine dust to clog the pores of the filter. If air can't pass through the filter the motor will get hot and shut off.
Mar 27, 2014 | Eureka Vacuums
The eureka model # 4703D does not **** although the motor is running
The vacuum cleaner probably is clogged. Look especially in the opening behind the roller and follow the path to the bag/container. If you have a pet that sheds, you can clog a vacuum quickly
Dec 29, 2012 | Eureka Capture Upright Vacuum Vacuum
How can i make my roll brush move on my eureka vacumn AS1101 A the belt is not broke so why wouldnt it work
My issue is that the belt circled spins independently of the main drive belt. Main drive belt will spin fine but 2nd belt does not engage or soon if there is any resistance...like the ground.
What are you suggestions from here?
Sep 02, 2012 | Vacuums
My eureka 5855 wont **** up anything and where can i get a manual
if the motor is working ang the bag is empty means you have a clog somewhere, look for a hairball or something at the bottom of the unit,
Jun 17, 2009 | Eureka 5849A Boss Bagless Upright Cyclonic...
The vacumm over heat?
The filters are clogged and need washing or completely cleaned. Also check all hoses and dust channels to ensure the model is completely cleared out.
Nov 14, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Eureka Altima Spitting dirt back out
your intake is clogged at the bottom and your filters are dirty not letting it create suction.is the dirt cup full
Oct 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
144 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
