Question about Cycling
Vitamaster 80c bike
I have a Vitamster Ergometer 80C exercise bike that makes a loud noise while riding and the RPM guage is not working. Any suggestions for repair? Where might I find an owner's manual? Thank you.
  • 4 Answers
SOURCE: NEED A MANUAL FOR A VITAMASTER EXERCISE BIKE
I own this particular Old Fashioned bike -lol - its a hardy one thou and I dont think you can find the original book but the book that came with it came from the company Roadmaster Corp. which is now named Roadmaster Industries, Inc - 250 Spring Street NW - Atlanta, Georgia 30303 -- phone number -- (404) 586-9000. I hope this helps ya. My resource came from the website that tells all about the cpy.
http://www.fundinguniverse.com/company-histories/Roadmaster-Industries-Inc-Company-History.html
So good luck in finding your manual. I am pretty sure that they can help after all they made this bike originally in 1992,
Posted on Sep 10, 2009
SOURCE: PTS Turbo 1000 recumbent exercise bike
Wow, just happened to be searching around and found this on google.
Posted on Feb 22, 2010
SOURCE: The bike makes a loud, rubbing noise. Any ideas?
The most common problem that causes a loud rubbing sound is a tire, usually the back tire, rubbing on the frame, and you can usually see exactly where it is rubbing. Brakes can rub too, but they usually are not that loud, so let's assume it is the tire. This happens when the rear axle wasn't tight enough, and when you pedal hard or hit a pothole, it can make the axle pivot in the slots it fits in, and this lets the tire to rub on the frame, usually on the front part of the rear tire.
Solution: For this kind of work, I usually flip the bike upside down on an old piece of carpet, etc. so it is sitting on the seat and handlebars with the front wheel pointing straight ahead. There are two common methods to secure the axle:
1. Two pretty good sized nuts, one on each side. Find a wrench that fits just right. I prefer a socket, box end or open end wrench, one for each side. On metric nuts, it will often be 14mm or 15mm, sometimes bigger. American sizes are usually in the 9/16 - 5/8 - 11/16" range. I strongly discourage you from using any kind of pliers or even an adjustable (crescent) wrench. You have to tighten these babies pretty tight, and you can easily burr the corners off your nuts with adjustable tools, believe me I've done it. The tricky part is you have to do three things at once. First, you have to keep the front part of the tire evenly spaced between the two sides of the frame. Next, you have to slide both sides of the axle back in their slots until the chain has the proper tension. If you have a ten-speed style bike, the derailler mechanism will adjust the tension automatically for you, so slide the axle all the way back until the side with the gears is against the back of its slot, and let the other side move forward or back as needed for the tire to be centered between the frame. Finally, while you are keeping things lined up - a patient friend who is willing to help makes this much easier, just have them hold the tire so it is evenly spaced between the frame, and then you have to tighten the nuts. If you don't have a ten-speed style gear changer on the back tire, you have to take up most of the slack in the chain yourself and hold it tight until you get those nuts tight enough to keep the axle from slipping. Don't be surprised if you have to loosen up the nuts and do it again - on a single speed bike you should have about 1/4" to 1/2" of flex in the middle of the chain, halfway between the front and rear sprockets. Too tight, and it can wear out your bearings or chain well before their time. Too loose, and your chain will fall off at the worst possible moment, and you will have to do this process all over again, after you push your bike back home. Tighten a little on each side until things get snug, and if the tire is still centered between the frame, do both sides again, harder now (grunt a little this time, it helps) and you should be good to go. Remember, you are not trying to strip the axle threads, or break anything, but you do have to get it tight enough so it won't slip on you again.
2. Oh, yeah, there is another common method you find pretty often on ten-speed style bikes, the quick release.
91177b4.jpg This is an assembly that consists of a lever built onto the axle nut, and the lever is only on one side. You don't use a wrench on the quick release, but they are a little tricky until you understand how they work. As you pull the lever away from the frame, a cam inside loosens the axle, and as you push the lever toward the frame, it tightens. When the lever is in the loose position, you can also spin the nut on the axle tighter or looser (careful, it doesn't take much, and clockwise should be tighter on most bikes). Tightening or loosening the nut part does most of travel, and the lever does the last little bit. The lever is short, usually only 2-3 inches, so if you don't have to push pretty hard on the lever, the nut is probably too loose, and you need to loosen the lever and rotate the nut part clockwise a little bit, until it feels like the axle is getting really good and tight just about the time the lever gets close to the frame. This can also take 2-3 tries of loosening the lever, tightening or loosening the nut, and retightening the lever again, until it feels good and tight, and of course, you have to check your tire alignment one more time to make sure it is still nicely centered between the frame of the bike. Turn the wheel by hand a few turns to make sure it doesn't rub on the frame. If everything is tight, and your tire is still centered, you're ready for a test ride. Just up and down the driveway to start with, and make sure your brakes are okay. Then you can go a little farther, and pedal a little harder. Hopefully the axle will be nice and solid, and you can say, "Good Job! I fixed it myself, on Fixya!"
Posted on May 14, 2010
  • 3 Answers
SOURCE: no change in resistance
IF you have the one i have, there is a knob with two connected arrows and a plus and minus sign. turn toward the plus, more resistance, turn toward the minus, less resistance.
Posted on Jul 24, 2010
taran_2005
  • 10515 Answers
SOURCE: I'm trying to find an
Download the same from :-
http://www.kettlerusa.com/SX1.pdf
You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 27, 2010
I need part for vitamaster Bike L504. I need a manual and speed odomer
Fixya does not sell parts. As for the manual, try Googling (vitamaster)(L504)(manual) without parens.
Jul 20, 2017 | Cycling
I have a vitamaster magnetic exercise bike and lost the battery cover now it does not work where can I get a replacement cover
You should contact the store that you got it from and ask them to send you a battery cover or if you have warranty to give you a new magnetic bike.
Sep 15, 2012 | Exercise & Fitness
Where can iget info on ergometer
Never heard of a ergometer for a bicycle. You understand that an ergometer measures the workload, so you would have one on an exercise bike, or a bicycle trainer. There bicycle accessories, like a cyclecomputer, and you can wear a heart rate monitor. Go to a bike shop that sells fitness and bikes, they can hook you up.
Sep 17, 2010 | Cycling
I am looking for pedals to a Vitamaster Air 990 exercise cycle. I was informed Vitamaster is defunct when I called their 800 number. I also called S&R Workout Warehouse and they do not provide parts...
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Most of the time you can find an aftermarket pedal that will fit your bike. The important part is the size of the pedal shaft. Most commonly they are either 9/16" or 1/2". I will post a link to a video on how to measure the pedal shaft diameter as well as a link to some possible replacement pedals.
Identifiying the Proper Size Pedal for Your Bike
Pedals for Exercise Equipment Bikes Ellipticals Steppers SPD 1 2 9 16...
Mar 17, 2010 | Exercise & Fitness
Have need parts to a tunturi ergometer / exercise bike
It looks like the only cable FitnessRepairParts has for Tunturi Ergometers is a speedometer cable for serial numbers greater than 474100.
Aug 26, 2009 | Tunturi Cycling
Cycling Logo
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
