Question about Sony Playstation 3 (PS3) Console
Truck has a shimmy at60km - Sony Playstation 3 (PS3) Console
  • Wayne
    Wayne Oct 12, 2013
    Tried it all
    Prodigy:
    An expert who has answered 500 questions.
  • Sony Expert
  • 537 Answers
You need automotive advice, not video game console advice, but I would hasten a guess that it's either out of alignment, the tires are too worn on one side, the ball joints are going bad, and/or the tires are out of balance.
Posted on Nov 05, 2013
What's wrong with the front end of my truck?
caliper malfunction brake fluid leak onto the pads causing it to slip and smoking from the brake fluid burning
Jul 06, 2014 | 2005 Chevrolet Silverado 1500 2WD
Truck shimmies when brakes applied
Check your brake rotors,are they worn even and no worn marks.When replacing,do both.
Jan 17, 2013 | 2003 GMC Sierra 1500
2002 Toyota Tundra shimmies when braking. Just raplaced rotors and pads and didn't fix problem.
Who is doing the work on your truck ?
Did they put in the problem or never
were asked to resolve it?
You can pretty much tell as you remove
brake parts, if they were in any way related
to the shimmy.
Sounds to me that issue has never been worked on
Nov 11, 2012 | 2002 Toyota Tundra
When decelerate truck shimmys
chances are, the deceleration shimmy is either the kingpins, or the tie rod ends!!!
Nov 02, 2009 | 2004 Chevrolet Silverado 2500HD
2007 DODGE RAM 1500 CASTER ON RIGHT SIDE WONT COME INTO SPEC GETTING SOME SHIMMY?? truck has 95,000 miles was last aligned with about 40,000 miles after a tire blowout and a bent rim alignment was...
The actual caster spec is not very significant - the handling is what counts. The caster will not cause a shimmy. Shimmy could be caused by tire problems, worn or damaged steering or suspension parts, bad shock absorbers or a bent wheel. As long as the vehicle does not pull and the handling is satisfactory, the caster is OK, If the tires are not wearing and the vehicle hamdles OK - don't worry about "specs." I have done a LOT of alignments where the readings did not match the specs, but the result was satisfactory.
Oct 25, 2009 | 2007 Dodge Ram Truck
2001 Ford Ranger SRS brakeks and bearing problems
Your truck has sealed bearings in the front but they can go bad after several miles. If the truck is not stopping straight or you are getting a pulse through the break pedal (and sometimes a shimmy in the steering) then it's time to replace the rotors and pads. If the truck is stopping and driving fine then I wouldn't worry about it.
Jul 17, 2009 | 1990 Ford Ranger SuperCab
My truck shakes too
Is it time for a tune up? Could be water getting into one of the coil packs which will cause a misfire under acceleration.
Jun 11, 2009 | 2001 Ford Expedition
Shimmy in front end
Try greasing the Idler arm and Tie rod ends. The grease will take some of the play out and if the shimmy is gone then it's time to replace steering components. Common is the Idler and Pitmen arm that causes the shimmying.
If the shimmy is still there, then it's time for a front wheel alignment. As the suburban get's older, the suspension settles down lower each year and the geometry to the front steering system may need to be adjusted for that. On the 4X4 the ride height can be adjusted by turning the torsion bars to achieve the proper ride height again, as for the 2WD then it's going to be a coil spring replacement.
The easy way out is to just adjust the front wheel alingment to compensate for the shimmying. ]
Good luck and hope this helps. Just make sure you find a font end person who knows what he or she is doing and not by what a machine is telling it to do. The tech must know that there must be an angel to the tie rod end so when you go over a bump you don't get what they call a bump steer where the truck will want to pull to one side.
May 22, 2009 | 1999 Chevrolet Suburban
I have a 1998 olds bravada. when driving, the truck shimmys from side to side. Ball joints are good, tie rods good, hubs are good and alignment is good. small amount of play in both idler arm and pittman...
I don,t think this can cause a shimmy, there should only be some play in the steering wheel. Check the tirs and see if any belts are broken wthin and for visible bulges, this can cause a shimmy. Also if you are not the original owner, is it possible that someone hit a curbe and bent the spindle a tad. I knew of a GMC Safari that had this problem.
Nov 30, 2008 | Oldsmobile Bravada Cars & Trucks
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
