Question about Sanyo DP32649 31.5 in. TV
My tv model # DP32649 will get real loud then a few minutes later goes off. It usually will come back on after an hour or so then in a hour or two does the same thing. I need help with this please. Thank You
3 Suggested Answers
SOURCE: Sanyo DP32649 works fine for a few minute, then
I have the exact same problem. It's a volume control issue. For me, when I turn my TV on and have it on low volume, it works fine (but sounds somewhat distorted). But once I turn the volume up to normal levels, the speakers crackle and then go out. I opened my tv and checked my speakers, and they were perfectly fine; not blown or anything. As well, the audio processor and circuitry didn't appear burned at all.
This used happened every few months for 30min or and hour at a time. Then, about 2 months ago, it happened again, and ever since then it still hasn't worked properly. The only way I got around this was by buying a cheap 2.1 speaker system, and connecting it to the audio output on the TV. Or you could buy a speaker bar or home theater system. I believe this issue has to do with problems with the circuitry in the audio amplifier, and there's not much you can do except add external speakers, or contact Sanyo if you still have an active warranty.
Depending on where you bought your TV (such as from walmart), its possible that the LCD panel was produced by Sanyo, but the electronics were done in China. Walmart does this with nearly every TV they sell.
Posted on Feb 21, 2010
ripleymojica
  • 643 Answers
SOURCE: The power went out and
surge protectors will go bad. try direct to wall outlet.
Posted on Mar 21, 2011
Tv goes loud and then shuts off
check the fuse may have blow up
Feb 03, 2015 | Sanyo DP32649 31.5 in. TV
My Kenmore gas range 2274233 makes a loud noise when the oven is turned on.
Since it is new--have them bring you a new one. That should have been fixed before shipment
Jun 26, 2014 | Kenmore Kitchen Ranges
Hello, my 55513 tv when turning it on was blurry. after a few minutes it became clear. shut off and came back about 3 hours later and it was blurry again for about 10 minutes. about 10 minutes later it...
in the customer menu select convergence when set acts up---look to see if grid of lines is skewed, see some photos and let me know if your problem anything like this..........
Apr 08, 2012 | Mitsubishi WS-55513 55" Rear Projection...
My Sanyo is a year old. We got a new cable box, plugged in in and it worked fine for about 10 minutes. Then the volume spiked very loud, it glitched, shut off for 10 seconds, and then comes back on. It...
Hello roby, hi, to find if the problem is the cable box or the TV, try using another TV. if the cable box performs normally, you have a problematic TV. Otherwise its the cable box.
Dec 04, 2010 | Sanyo DP32649 31.5 in. TV
Tv will turn on for a few seconeds then turns its self off
Tries tv unplug,replug it back like an hour later.The tv is resetting itself back to the factory setting now.The tv now should work,not than the tv have problems with it power supply board.The power supply board it not giving the tv,the wright voltages to the tv anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 14, 2010 | Sanyo DP32649 31.5 in. TV
Tv goes on and off a few times then turns off
Thats a common symptom which is usually caused by the Small signal board. You can get a replacement small signal board from www.tvrepairworld.com
Jul 16, 2010 | RCA HD52W66 Projection Television
Sanyo DP32649 works fine for a few minute, then sound goes off. turning the TV off for a moment & then back on restores the sound. But sometimes this will happen ever few minutes for the length of the...
Jan 30, 2010 | Sanyo DP32649 31.5 in. TV
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Sony TV Sound Problem
Obviously the TV needs to be serviced, if you plan on trying something yourself be carefull and please note- If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Suggest ESR all associated caps and change the audio output ic. If you're not sure how to go about that and you have some soldering skills I suggest that you first of all check for any solder defects in the area, and resolder if necessary. Still, If the sound coming out of the TV speakers while not connected to the stereo is OK, then you're looking at something else. Good luck
Mar 23, 2006 | Sony KP-57WV600 57" Rear Projection...
Sanyo DP32649 31.5 in. TV Logo
35 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
