Question about Sport & Outdoor - Others
Genesis viewloader paintball - Sport & Outdoor - Others
2 Suggested Answers
SOURCE: This a genesis lethal threat paintball gun I just got it and I am new to paintball what size paintball do I get for my gun please get back to me as soon as possible thank you
First off do you have a hopper and an air tank or co2 tank with air or co2 in it. If no get those things and fill your tank at a local paintball field. If yes your gun takes a .68 caliber paintball. That's really any paintball that you can buy at Walmart or sports authority.
Posted on Dec 09, 2012
What should I consider before buying paintball gun?
Most paintball markers have either a center feed or a balance sustain. The benefits of a center feed are that the marker is able to use both hands, more adjusted and you can tilt it somewhat so your container remains behind cover. Paintball Gun Buying Guide is the best for you to get the full information.
May 13, 2017 | Paintball Sport & Outdoor - Others
Paintballs keep blowing up in my tippmann 98 custom HELP!
it could be a combination of a number of things.. most likely it has to do with the type of paint you're shooting; in regards to shell.. tippman guns are harder on paint therefore require a harder shell paint, also not all paintballs are exactly .68 caliber, meaning some a bigger and some are smaller.. could be that they're slightly to big for the bore of you barrell
Feb 13, 2013 | Tippmann 98 Custom Act Paintball Gun
If a player gets hit with a paintball that doesn't break, is he still out?
In most paintball games and tournament play, a paintball impact but non-break is non-elimination. It is good sportsmanship to call out "bounced" or "didn't break" if he/she is hit but does not receive paintball splatter.
Jan 17, 2013 | Sport & Outdoor - Others
Dec 01, 2012 | Toys
When i put my paintballs in the gun and i aim down they fall out the top where they shoot from
Sound like your ball detent is gone or broken.
The detent is a tiny piece of rubber that keeps the paintballs in the chamber and from rolling out the barrel. It's a cheap part, but you will need basic knowledge of disassembling a Tippmann 98 to replace it.
You can find ball detents here!
Feb 12, 2011 | Tippmann 98 Custom Act Paintball Gun
I bought a tippman stock for my carver one but im not sure how to put it on?
In order to use you gun you will need 3 basic things. First, you need to have your hopper with paintballs in it, second you will need a CO2 bottle to propel the paintballs, and finally **** the gun on the side have the gun in the ready position. There are some security measures to be followed like having a paintball mask for facial protection and to handle it as loaded weapon at all times since it can harm a person if not handled carefully.
Oct 21, 2010 | Tippmann 98 Custom Act Paintball Gun
Bruizer outlaw paintball gun
There are many things to take care of the paintball gun. The good thing is that with paintball gun so much choice available, you should always be able to find a marker that meets your requirements perfectly. To get the details about each and everything you can refer to Best Paintball Guns.
Aug 26, 2010 | Sport & Outdoor - Others
98 Custom Act Paintball Gun: i want it to go fasteer...
I can take that a couple of ways. Do you mean you want to fire more balls per second or you want the paintballs themselves to fly faster?
If you want to fire faster, make sure it's clean and properly lubed with a quality oil that made for paintball. Practice makes perfect and fire that ****** as often as you can, even without paint (that's cheaper!) so you can get your trigger finger in shape.
There are custom mods to the trigger, or you can buy a trigger that's smoother or a shorter pull. There are electronic trigger assemblies that make firing faster even easier.
If you're talking about making the balls fly out of the gun faster, that would be the "velocity adjustment". Your user guide shows you how to make that adjustment and which direction is up, and which is down.
A good suggestion is to check out a local field or paintball store, or an airsmith and they can give you some definite ideas you will want to pursue.
Play hard, play safe, play with honor!
8^)
May 17, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintball gun is rapid firing when trigger is pressed. CO2bottle is full and i have tried other bottles but stillth same.
Tippmanns are known for their reliability and are very simple markers making them very easy to repair. you need oil from a local paintball shop or regular sewing machine oil will do.
On one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns, if not..
Sometimes paintballs can break inside your gun. Look and feel inside your breech (where the paintballs go into the gun) and check for paint. If its dirty this can be causing your problem, strip it down and clean it (refer to your manual if you have difficulty)
on one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns
Jan 08, 2010 | Tippmann 98 Custom Act Paintball Gun
Sport & Outdoor - Others Logo
96 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
