Question about Whirlpool Refrigerators
Door won't close by it's own weight - Whirlpool Refrigerators
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 78 Answers
the legs in front are adjustable by a bolt either in the front of both sides or right on the legs themselves study here
your floor may not be level. you may need to buy some shims and put the fridge on a whole new piece of plywood and use shims
Posted on Oct 12, 2013
2 of 3 sliding doors don`t close on tgm-69r
there is a string and a weight on the inside of each door. if you cannot find the string it may be broken. lift and remove the door from the unit, then remove two screws from both top sides of the door and the top of the door itself will come off. you can then lean the door over, the weight should slide out.
Apr 16, 2014 | Turbo Air Refrigerators
Model GDM-69
A GDM 69 three doors. Each door closes using a string attached to a weight, which runs through pulleys or copper tubing, and is held to the top of door. The pulleys or copper tubing can be accessed by removing the aluminum siding located inside cabinet on either side. The left side contains the pulley and weightfs or left and center door, the right for right door (each held on by 4 1/4 screws) . To make the door close, simply make sure string is attached to weight, running though pulley, and attached to top of door.
Nov 07, 2013 | True Refrigerators
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
Cannot open the door of the dishwasher.
  • The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
  • If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
  • Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
May 04, 2010 | Maytag 24" Tall Tub Built-In Dishwasher -...
Door won't close stay closed or seal
check gromets on hinges for wear. check weight on doors is it causing the door to droop? are the gaskets cracked? more information is needed if possible.
Feb 01, 2010 | Kenmore Freezers
Freezer door opens when you shut the refrigerator door
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Sep 03, 2009 | Amana Refrigerators
Whirlpool gd5thgxks01 door does not auto close
You need to level the refrigerator slightly backwards so the weight of the door closes it automatically. The front legs are adjustable, so just turn them until the door closes on its own.
Aug 05, 2009 | Refrigerators
Freezer door opens When you close refir. door
The freezer door is relatively light weight, and when the fresh foods door closes, the air has to go somewhere and the easiest escape route is to momentarily pop the freezer door open. The door should close again quickly. If is does not, make sure the freezer door liner is not touching the top or bottom, causing dragging resistance, and make sure that the front leveling legs are raised up so the door closes by it's self when released from a 45 degree opening. Sometimes the hinge side gasket rubs and holds things up also, especially if that area was cleaned. If that is the case, rub a film of wax on the hinge side gasket to lubricate it. Additional weight in the freezer door will also help.
Oct 27, 2008 | GE Profile Arctica Stainless Steel Top...
Door doesn't close automatically.
it sounds like you need a new set of door cams. they should look something like this. they mount on the bottom hinge and use the weight of the door to close it.2fe6866.jpg
Jul 27, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
53 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
