Hotpoint aquarious has suddenly stopped emptying and spinning
    Genius:
  • Washing Mach... Master
  • 1,467 Answers
Sounds like pump is blocked/ jammed ,could be button /coin.
Posted on Oct 13, 2013
barkencoa
  • 3463 Answers
SOURCE: dryer runs no water enters condenser draw, empty water light on.
Remove the filter draw on the bottom left, and wash out under running water to flush out all fluff.
Reach inside opening and clean as much fluff anf gunge as you can from the cavity.
Get a plastic bag tie, reach and feel for a small at the rear of the compartment, and poke hole clear..
If this does not solve the prob, then it is probably a sticking or faulty float valve., or switch.
This involves a complete strip down to access these components.
Plz rate my solution.
Thanks.
Posted on Jan 09, 2009
barkencoa
  • 3463 Answers
SOURCE: operating instructions
Hello.
I can help you with your query.
In your browser bar type in hotpoint user manuals
In the drop down list, click on
manuals-user guides-handbooks-hotpoint service
In the search box enter your model number and download the instructions.
Please rate my fixya solution.
Thankyou
Posted on Jan 29, 2009
barkencoa
  • 3463 Answers
SOURCE: Machine full of water and towels. Spinning at same rate then stop
Check pump filter located at rear of washer, remove rear cover, locate and remove large black hose, remove and clean filter.
Please rate my solution.
Thanks.
Posted on Jul 15, 2009
  • 16 Answers
SOURCE: The washer has stopped emptying and spinning .
OK... Pessure switch is proberbly stopping the machine from spinning due to the water level in the machine... The pump could have just stopped working, or, the control board could be broken and therefore the pump not getting a supply current, or, the propeller in the pump could be jammed by debris.
1. Turn the machine off, and unplug...
2. Take the drain pipe and lower it to an outside door or other place to safely drain the water away that is still in the drum.
3. Follow the drain pipe till it reaches the pump. Check the lead to the pump to make sure it is properly engaged into its recess on the pump motor.
4. Take the hose off the pump in order to clear any debris and then replace the hose
5. Having done all that, plug the machine in and turn it on
6. Put it onto a spin programme ... The machine should now lock the door, then both pump and spin actions should start... If not, your control board or cabling is at fault
Posted on Aug 25, 2009
  • 86 Answers
SOURCE: Hotpoint Aquarious WF210. Machine stops mid
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Posted on Mar 06, 2010
Hotpoint aquarious 1200, not completing a washing cycle
where does it come to a stop
five mins in to progam or at rinse
Jan 13, 2014 | Washing Machines
Hotpoint aquarious making loud gring noises and sometimes does't start
sounds like motor brushes. physically check your motor for black power, that's a sure sign of brush wear. could be seized bearings, try spin the barrel of the washer by hand, if it's stuck/very hard to turn, thats a sure sign of bearing seizure.
Nov 10, 2013 | Hotpoint Washing Machines
Hotpoint aquaries wf321 is making a loud clicking/knocking noise when its in the spin cycle, to me sounds like a poss bearing gone or maybe something is caught up?
From the front of the washer, spin the drum by hand, if it feels rough or is noisy or rumbling, then the drum bearings have failed.
It is possible that there is something caught between the inner and outer drum.
Nov 30, 2010 | Hotpoint Washing Machines
HOTPOINT AQUARIS WMA40 WONT SPIN
Try changing motor brushes, this is most likly problem. You will need to remove motor to do this. Cost if you do them yourself is about £18.00
Feb 13, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT AQUARIES WM63 , NO SPIN SPEED- MOTOR WORKS OK ON WASH, BRUSHES LOOK OK.
If the brushes are less than 3 or 4 mm long, then they need replacing.
If still no spin , but washes o/k, then the high speed part of the motor windings could be faulty, which entails replacing the motor.
Thankyou
Jan 19, 2010 | Hotpoint Washing Machines
Hotpoint Aquarious 1200 IE When spinning the drum ocsillates violently and is very noisy.
Remove drive belt, and spin drum by hand, if noisy or rough, then bearings have failed, if no noise, then could be suspensioon leg problem.
Tghanks.
Sep 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Operating instructions
Hello.
Thankyou
Jan 29, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Brushes
if replacing the brushes has not fixed then its most likely the motor is duff.
Feb 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
