Question about HP Media Center m1170n Photosmart PC Desktop
I can't use the vga input - HP Media Center m1170n Photosmart PC Desktop
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 156 Answers
Not very meny computer have a VGA input..... assuming yours does you probably dont have the correct drivers installed for it.... stock windows drivers wont work you need the latests drivers from your video cards manufacturer
Posted on Oct 13, 2013
What type of cord do I use to connect my PC to HDMI
Hello
There are two types of connections can be done with PC to TV, according to TVs inputs. If TV has a VGA input socket, a VGA to VGA cable is necessary. If the TV has only HDMI input socket, a VGA to HDMI cable is needed.
Feb 13, 2012 | Panasonic TH-50PX77U 50 in. Plasma HDTV
Tip
How to Hook Up a Laptop to a LCD TV by VGA cable?
First of all check out does both the LCD tv and laptop both have vga cable input socket This is the most important step, as it will allow you to buy the right equipment.
VGA cable is the standard 15-pin connection that you would use to connect a monitor to a PC or laptop. Use a VGA cable to connect your laptop's VGA output with the television's VGA input. Use separate audio connection with mini-jack (3.5 mm) to RCA adapter.
Turn on your devices. Once you've made the connections, turn devices on. Switch your TV to the input mode that corresponds with the input you used to connect your laptop, and you should now view your laptop on your LCD TV.
This will help.Good luck.
on Mar 08, 2010 | Computers & Internet
How to set up cctv camera video output to Alba 19880HDF via vga input
vga input is a 15 pin D shape connector. find vga out put in your cctv camera. note that cctv camera's vga out & Alba's vga input are male or female connectors. get the appropiate vga cable & connect to input & output.
Aug 24, 2011 | Televison & Video
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
When we turned on the tv it says no signal vga input? It is a polaroid Flat Screen hdtv.
This might sound like a silly question but is the VGA input the one you wish to use?
If you are trying to use the VGA input what do you have it connected too?
A) Laptop 2nd VGA output.
B) Desktop VGA output.
NOTE: If you trying to connect it to a laptop you may have to engage your 2nd VGA output by depressing the 'Function Key' and either F4 or Some times it's the F8 key at the same time.
Blessings,
A/V Media Tech Guy
Oct 23, 2009 | Polaroid FLM-2632 Television
RGB port
A VGA & RGB port is the same thing. RGB is Red/ Green/ Blue for seperate input & VGA the video graphics array which does the same thing.
A DVi is an entirely different type of input port for digital input where your VGA port is more for analogue type inputs
Jul 13, 2009 | LG 32LG30 32 in. LCD HDTV
Why won't my tv display my computer screen
Hi. The best way to hook your computers display to your LCD screen will be to use the VGA input socket. If your video card can support both S-video input and VGA, you can use either one but, the VGA is best for optimal resolution. This is the easy way to do this. Step one, connect the VGA cable to the computers video card and then, run the other end of this same cable to the VGA input slot on the LCD screen.Step 2, next you will make sure that the LCD's input selection is selected to show what is being transferred from the CPU video card by using the input button on the lcd remote control. The lcd(your tv) should be on VGA or PC input signal. Step 3, now, you Will have to also make sure that your video card is set to transfer this signal as well by pulling up your video cards software window and switch to the proper options. once this is done, you should get a signal. Be sure to use the VGA input/output ports on both the lcd television and your cpu for optimal transfer of the video stream. Here is a pic of your back panel. use the input port labeled I for good PC input quality.
Mar 24, 2009 | Proscan 32LB30QD 32 in. LCD TV
Use of HDI-V input on PPM42M5SBx
the answer is no as VGA is a analog connection whereas the DVI connection is digital just like HDMI.
A DVI input on your display wont understand the analog signal and vise versa, hope this helps
Jun 17, 2008 | Samsung PPM42S3 42 in. Plasma Television
HP Media Center m1170n Photosmart PC Desktop Logo
26 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
