Question about Honeywell Computers & Internet
Ati 9250 driver
Hi the scanner tends to put extra letters in front and the end of the code for example if my scanners scan 123 the 9250 scanner will do d123c how do i stop it from adding the extra letters
  • 3 Answers
SOURCE: Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Posted on Aug 23, 2007
  • 25 Answers
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Posted on Jan 05, 2008
SOURCE: Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
Posted on Apr 23, 2008
  • 111 Answers
SOURCE: CanoScan LiDE 50 error code: 2,7,0
Has your scanner been working before?
If so, has anything changed since then such as new printers or other devices added to the computer, or upgraded to a new OS?
Which OS are you using?
When exactly does the error occur?
Does ScanGear open?
Are you able to preview?
Try connecting the USB cable to another port on the computer (directly to the computer...not through a HUB or any other device). Bypassing a hub, which would have to be a powered HUB, or other devices would rule out any issues with those devices.
Ultimately trying the scanner on another computer would rule out issues with the scanner as well.
Posted on May 10, 2008
ser71
  • 818 Answers
SOURCE: Ati 9250 DRIVERS 64BIT
go here
and find your driver
Sergio
Posted on Jul 21, 2008
I want certain letter to down load to my laptop. I have an HP printer scanner. Tell me how?
Among with the scanner/printer, you recieved a cd with the machines drivers and software. You have to install these two to the laptop to make the machine work. When you install the software, you can use this to scan your letter. It should be called something like "hp solution center" or similar. There would be clear instruction/options there for your task!
Sep 04, 2011 | HP G60-120US Laptop
Can i ask for a driver for my ATI Radeon 9250 Pro PCI Video Card, hope you could help me please...
Hello, here is a link to a site you can download the above driver from. http://www.soft32.com/download_170551.html. I hope this help solves your problem. Have a wonderful day.
Oct 07, 2010 | Computers & Internet
I have pixma MP145. i want use my scanner corectly
you have to install the scanner driver & application in able to use the scanner to scan documents.
here is the driver for your scanner, download & install it.
Canon PIXMA MP145 Printer Driver 1.05 For Windows Vista(32/64)/XP
Jul 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Scanned image is blank, although the page inside the scanner has text &/or picture.
Scanner contains Unlock botton below it, just unlock it it will scan fine.
Vikrant
May 08, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
When i scan a letter 2 page is scanned:letter and blank page
You may be set for front & back (duplex) scanning. Change the setting for front only or simplex. This could be done with check/uncheck boxes, a drop-down menu, or a keyboard shortcut. I believe the standard Kodak settings are via check boxes.
This model is also capable of putting out color & bitonal (black&white) images simultaniously. If that's the case the pages should be separate image files. Uncheck either color or bitonal depending on which you want.
Apr 09, 2009 | Kodak i40 Path-Through Scanner
I have a ls2208 symbol scanner that need to scan code 39.... The example below is return when I scan the following information. It seems to be do stange thing with the first 2 charecters. Can you help?...
Your scanner is set up for full Ascii mode.
$B = CTRL B
%I = >
Re-program to enable "Code 39" and disable "Code 39 Full Ascii"
In Code 39:
$B = Control key on
%I = Tab
Hope this helps.
Jan 10, 2009 | Symbol LS2208 Handheld
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Computers & Internet Logo
23 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
