Question about Halex 64339 Match Play Electronic Dartboard
Got new board but have no instructions on install or set up
I installed a new pc board part number WE4M536. Now when I turn on the dryer, all the LED's just blink on & off. Do I need to program the new board? If so, how do I program it?
Yes it sound like it needs programed to your model number. Should have been instructions in the part box. There may be instructions inside the control panel. GE usually puts a sheet of paper with service info inside most dryer control panels. It usually consists of pressing 2 buttons at the same time to get in service mode and then turning the big knob to set it.
Jun 06, 2015 | Dryers
Maytag Neptune MAH4000 Motor Conversion Kit Instructions
I do please post your email here and i will send it to you
Feb 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
I just installed my brand new printer cartridge in my hp a526 printer (NEW) and when I follow the instructions for set up to perform printer alignment it failed and will only print re and yellow colors...
First of all if there is a procedural fault when a new ink cartridge is installed this fautl can occur.
So first of all remove the printer, Uninstall the software. the reinstall the printer software and on instruction connect the printer to the PC. The new harware will be now installed .
make a test print. It must work fine.
Failing this test there can be errors in the printing head / main board.
Sep 11, 2010 | HP Photosmart A526 photo printer
SONY SDM-HS75P/ I want to purchase and install a MONITOR BOARD. I have identified that is the reason that it won't stay "ON" I need instructions on "how to" install a new board too.
Are you sure that it is the bad lamps assemblies? You will need a set of test lamp.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <a href="http://lcdalternatives.auctivacommerce.com/Viewsonic-C196320.aspx"><span style="mso-spacerun: yes"> </span>http://lcdalternatives.auctivacommerce.com/</a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
Aug 26, 2010 | Sony SDM-HS75P/S 17" LCD Monitor
Code comes on on the screen C8 then 76 hot water stops then you have too turn it off and restart
bad circuit board. Call 1 800 432 8373 and tell them you're having this code, they'll overnight you a new board. Once installed, call them again for the final set up (because they don't include the last programming in their instructions!)
Aug 06, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I replaced the control board FD2518-020, which included the temperature sensor that mounts to the side of the condenser. The condenser now freezes over and the unit continues to run. I experimented and...
Was there any instructions with the control board? I'm assuming we are talking about a heat pump control board or defrost board.
Some have time or temperature settings on the board that needs set. There's a lot of different boards out there, some have jumper pins and some have dip switches, you almost need either the unit installation instructions or the instructions that should have came with the board. Not sure if this will help you but if it doesn't you may need to contact a dealer or the company that made this unit.
Aug 05, 2009 | Maytag M7DH65B2A Dehumidifier
Sound quality
The sound quality built in to most mother boards is not the best quality. It is a compromise. The best solution is to install a high quality sound card in an available slot.
For video quality, it is the same issue when it comes to high quality video.
Before installing the new sound card, uninstall the existing sound drivers and sound software for the built in sound as necessary. You may have to go in to the BIOS set-up and dissable the mother board's built in sound. It is best to consult the instructions for *********** board to know the details for the particular mother board. You should contact the dealer for your computer to have proper details.
Turn off the computer, and disconnect the AC cord. Open the case, and install the new sound card according to the instructions that come with it.
When the computer re-starts, it should tell you that it found new hardware. Go through the installation procedure. There will be drivers and some software and drivers that must be installed.
If you are not used to this type of procedure, it would be best for you to take the computer to a computer service place and have them do the installation for you.
Jerry G.
Sep 13, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Instruction Manual
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
78
Jun 13, 2008 | Intel D845GVSR Motherboard
Halex 64339 Match Play Electronic Dartboard Logo
19 people viewed this question
Top Halex Toys Experts
Stitch85
Level 1 Expert
ray gallant
Are you a Halex Toy Expert? Answer questions, earn points and help others
