Question about Pool & Spa
Sundance spa optima
Spa will not heat past 93 degrees
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Sounds like bad temp sensor should ohm out to about 78 ohms if ok you should be able to go into diagnostics and set temp calibration
Posted on Apr 19, 2014
Healeyman
  • 1198 Answers
SOURCE: we have a spa quip 2.5 maxi flow spa pump,tried to
Hopefully you have not fried the motor. To free a stuck motor: try to reach past the strainer to the impeller and turn it. If you can't do that, remove the electric end cover and find a double flat for a wrench where the shaft goes into the motor. Or maybe you can remove the spring thing from the end of the motor and move the shaft with a pair of vise grips or pliers. Don't damage the place where the spring thing mounts. Don't try to move the motor with the plastic fan thing near the pump, you'll just break it, and then you really have problems.
To keep a motor from sticking, thru off season occasionaly spin the pump, just a few seconds will do, don't need water.
Posted on Apr 17, 2009
  • 990 Answers
SOURCE: Heeeelp! How to hook up hoses on Sundance spa
There is a skimmer in the side of your tub( the part that skimms water off the top ) and what is called a main drain or a better tearm is deep suction that pulls water from the bottom of the tub and helps collect heavy dirt from in the tub these two lines ( three if there is more than one main drain) These will all come together and then hook to the front of the pump. If your filter is under the skimmer basket the top of the pump will go to the heater and then back to the spa. If your filter in not under the skimmre basket then it will come after the pump then on to the heater. So in answer to your second question, the front of the pump draws the water in and the top pushes the water out. But make sure that your heater is last in line so it only deals with clean water and it will not run on the suction side of the pump as it need water pressure in it to start and contious flow to keep it from over heating. Hope this helps.
Posted on Oct 03, 2009
  • 106 Answers
SOURCE: Hi! I have a Hayward Pro pool/spa system with
This is tough cause I can't see the valve setup. I have to assume they are manual valves. Normal operation probably takes some water out of the pool and spa than puts it back into both. To heat the spa, set the intake valves(the ones in front of pump) to take water from only the spa. Set the jets(valve(s) on output side of filter) to send water back to only the spa. The pool will be out of the loop. Normal operation usually has water taken out of pool and spa than put back into both. Make sure to put more water back into spa than you take out, (Adjust valve)
Posted on Apr 23, 2010
SOURCE: I have a Sundance Spa that has started tripping the breaker
It is unlikely the Breaker is BAD, that just doesn't happen. To trip a breaker there MUST be an Overload, or a Short circuit, that's it. You will have to use a meter an troubleshoot the system. Something is very wrong..please use the links below to troubleshoot and repair. Please Be careful. http://spababes.com/heaterhelp.html
http://www.spadepot.com/spacyclopedia/spa-heater-element.htm
http://www.poolandspa.com/page596.htm
Posted on May 07, 2010
Testimonial: "Looks like this info may save me a service call. Many thanks for the answer and the links."
Coastsider
  • 331 Answers
SOURCE: My customer's spa works/heats
This sounds like a flow issue. Your controller and heater is made by Balboa and requires a minimum flow rate of around 25 gallons a minute to function properly. This flow rate is measured by sampling temperature differences between the inlet and outlet of the heater. If the flow is low the temperature will increase at the outlet. As long as the difference is less than 4 degrees, then the unit will function normally, but once the difference increases to 4 degrees or above the unit will shutdown and display OH, OHH or DR ( may vary depending on model). Reasons for this occurring... dirty filter, clogged pump inlet, partially or completely closed valve in the same line as the heater, obstruction in the plumbing before or after the pump, blocked suction fittings. There is a simple test that can be performed to determine if the problem is flow related. On the main circuit board is 1 or more banks of micro switches (called DIP switches) They are usually red in color and numbered 1-x (x being the highest number from 5-9). On the insideof the control box lid is a schematic which references these switches in a chart or table. Usually Dip Switch 1 will be the one. This switch is usually OFF. With the System on and running - Using a Pen or small tipped (INSULATED) screwdriver, carefully push the switch to the ON position (up or down as needed). Now observe the display and watch for "A" and a temp, then watch for "B" and a temp. Note the difference between the 2 temp readings. NO difference is good, any difference less than 3 is good, any difference 3 and higher is NOT good and indicates a flow issue. If the reading is high, look for one of the above symptoms to be present.
Posted on Sep 09, 2010
Sundance optima spa, heater icon is on but will not heat.
check recirculation pump and pressure switch then heater element
Feb 16, 2018 | Pool & Spa
How to check my sundance spa temperature sensor on my 850 series cameo
disconnect and check with a ohm meter around 70 degrees you should get about 78 ohms if not familiar get a professional
Oct 05, 2014 | Pool & Spa
Tripping circuit breaker
Hi Kathy
Sometimes when a breaker keeps tripping, it will wear and will be in need of replacement...try replacing the breaker and see if that solves your problem.
If not then check the amps on the pump and make sure the breaker is able to hand the amperage the pump is requiring.
Bud
Oct 09, 2013 | Pool & Spa
Leisure Bay spa will not heat past 86 degrees. Element and sensors are new. Spa has excellent flow and correct voltage at terminals.
if the spa does not heat up to 104 degrees then the temp sensor is what you are going to need.
Are there error codes showing on the screen of the topside?
You will need to know the model number of the control box or the model number of the heater tube in order to get the proper sensor.
Rod
US Parts Center
888-521-6183
Feb 09, 2013 | Pool & Spa
My leisure bay spa will not heat past 86 degrees.
If your spa will not heat up to the 104 degrees or what temperature you set it at then you have a bad temp sensor.
RodUS Parts Center888-521-6183
My spa will not heat up to 102 degrees. It's been at 80 for the past hour and the previous days its had no problem heating quickly. What am I doing wrong?
Is your spa still not heating?
If the problem persists it indicates that your heater element is bad.
We have instructions on how to test it here
Sep 23, 2012 | Pool & Spa
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
My spa has stopped heating above 67 degrees. Can
it's most likely a temperature sensor, what is the readout on the top side control?
Feb 03, 2010 | RTO Sundance Heater Element Harness Black...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
