Question about Pyle pro Pmx402m 400-watt 4-channel Powered Mixer With Mp3 Usb Input
Pyle pro Pmx402m 400-watt 4-channel Powered Mixer With Mp3 Usb Input how i check the fusible?
  • Omar Andres Rivera Carmona
    Pyle pro Pmx402m 400-watt 4-channel Powered Mixer With Mp3 Usb Input. How I check the fusible?
  • 631 Answers
SOURCE: PLEASE HELP with PYLE PLUS GXA-280A
If the ground terminal is connected to a ground wire, the ground wire isn't connected to a good ground.
Posted on Sep 24, 2007
SOURCE: car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Posted on Feb 09, 2009
  • 524 Answers
SOURCE: what size amp do i need to run 4 1000 watt pyle 10's bridged
well first of all you cant bridge subs... you can bridge an amp... and for 2 they are probablly not 1000 watts, make sure you understand RMS and what the sub can ACTUALLY HANDLE properly... i would get a 1000 to 1500 watt RMS that is RMS RMS RMS RMS amp not one that says 2000 watts MAX POWER cuz thats cheap ****... get a kicker JL hifonic alpine or something in that category that actually tells you the TRUE power output of the amp... then run those 4 subs in a parallel circuit so its like really only having 2 subs. make sure then these subs do not run less then 2 ohms at the terminals while in a parallel, then bridge these subs acting as 2 subs not 4 to your TRUE 1000 watt amp and you should have a good powerful system
Posted on Mar 19, 2010
  • 222 Answers
SOURCE: 2003 Cadillac DTS w/Bose, has rear sub & adding Pyle dual 10 sub
two channel will do with the same power power rating of your speakers ex. your speaker is 500 watts per piece so you need to buy a 500 watts per channel amplifier
Posted on Jun 09, 2010
SuperTech-11
  • 1591 Answers
SOURCE: I have a pyle pro
you either have a cold solder joint or a bad capacitor or a bad input.
if it's only happening from one source, look to the source as the issue - there may be a DC voltage riding on the output into the amp, saturating the input until the caps charge...and if there's a bad cap on the input or output, it may take time for it to stabilize.
Meter the input at zero signal, and meter the output as well looking for DC voltage riding on it.
compare readings at zero signal between channels for discrepancies.
ground both inputs and start metering .
check the low ohm resistors between the output transistors unless it's a hybrid.
when I say transistors I mean mosfets.
Posted on Mar 20, 2011
I have a 15 inch powered Technical Pro speaker with a damaged audio board from applying too much eat trying to remove a bad transistor where can I get a replacement audio board
Shop for 15 inch powered Technic... on Google
Eminence Kappa Pro 15...
$154.99
Google Trusted StoreMusicians...
(5) Eminence Kappalite 301...
$209.99
Google Trusted StoreMusicians... Eminence Kilomax Pro P...
$239.99
(3) Eminence Kappa Pro?15...
$169.99
(3) Technical Pro zxp18 18 in. 4...
$151.88
Jet.com Search Results
    I have a 15 inch powered Technical Pro speaker with ... - Fixya
    www.fixya.com/.../t26013584-15_inch_powered_technical_pro_speaker
    1 hour ago - I have a 15 inch powered Technical Pro speaker with a damaged ... to remove a bad transistor where can I get a replacement audio board.
    Technical Pro Speakers ' eBay
    www.ebay.com/bhp/technical-pro-speakers
    eBayFind great deals on eBay for Technical Pro Speakers in Speakers and ... Package: (2) Rockville RSG12.4 Single 12" Three-Way, 4-Ohm Pro Audio ... Pro STAGE-212XU 3,000 watts Powered Speaker + 8 channel Mixer System + ... Technical ProPSHAKE1500 Two Way 15" Active 1500W Speaker Bluetooth and USB / SD.
    SA-15T - Seismic Audio Speakers
Dec 19, 2015 | Technical Pro power15usb 15 powered molded...
Need the schematic print for PMP 4000.
You can find it on the Web. Patience and some searching...?
Jun 03, 2014 | Behringer Pmp4000 Europower 1600-watt...
Fuse Type ?? Had a Speaker Cord Short out and Took out the Fuse....Can't Read the Little Glass Fuse
I am having the same problem but mine did not come with a fuse and I can't get a hold of Pyle.
Apr 10, 2014 | Pyle PRO PMX602M 6-Channel 600 Watts...
Need schematic
I just posted a solution for this. WTF?
The sink is aluminum or copper. Just secure the ground wire to any screw that is nearby, or where you see a scorch mark. If you could read a schematic, you would already know such a simple answer by looking at the board.
Nov 19, 2013 | Pyle PRO PMX802M 8-Channel 800 Watts...
Pyle PMX802M powered mixer blew at an event. Looking for schematic or picture of wiring for power supply to reconnect Ground wire to PCB on heat sink
If it is just a ground wire, you could solder it to any screw mount on the board or where the scorch marks are. What do you need to see?
Besides... did you really expect to have 800 watts of power as per Federal Trade Commission specifications with just a cheap piece of equipment?
Brand new mixer hooked it up and making a noise
Check your cable connections and turn down the gain levels
Aug 25, 2012 | Pyle Pro 800 Watt 8-Channel Mixer with MP3...
Would I need a mixer or amplifier with this product: Pyle-Pro Rack Mount 8 Channel Wireless Microphone System with 8 Lavalier/Headsets (PDWM8900)
The unit has a built in mixer as well as individual outputs. You would need an amplifier/speaker that could receive from teh mixed output jack of this. Use BALANCED TRS cable.
Aug 20, 2011 | Pyle PRO 19 RACK MOUNT PRO DJ MIXER SFX
180 watts mixer/amplifier and 400 watts speakers
Hiya, they are thermally or DC protecting. You will have to add some extra cooling if you can, external fan etc. Bottom line is you are going to have to crank it down a tad or increase amps and speakers. If its DC protection, its because the distortion levels are 2 high. Very easily achieved with mics not compressed. Again, try tone them down a tad.
Hope that helps
Jul 13, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
No Volume oe sound coming out of speakers
try connecting speakers to another sound source or if you have access to a ohm meter, check impedance of speakers, should measure 4~8 ohms.
Jan 25, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Pyle pro Pmx402m 400-watt 4-channel Powered Mixer With Mp3 Usb Input Logo
63 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Lawrence Oravetz
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
