Question about Honda Garden
Engine runs find but has low water pressure - Honda Garden
    Champion:
  • 220 Answers
That's a pump problem. Not a simple repair. Replacements may be close to cost of new unit.
Posted on Oct 30, 2013
2 Suggested Answers
  • 332 Answers
SOURCE: hooked it up with water started engine and no
Your water system is plugged with "gunk"
You will need to slush it out with water and air pressure if you can until it runs clear
Posted on Apr 04, 2010
Need help in getting Honda engine on NorthStar pressure washer to run.
Could be low water pressure I have found.
Also, I purchased a can of "stuff" at Lowes today which allows you to circulate a liquid substance which lubricates the pressure pump....the pump could be frozen up...
I have a rotating nozzle which I bought...and it had frozen up...this stuff works
Aug 31, 2012 | Northstar Pressure Washer 3000 PSI
We have a new honda gx390 pressure drain cleaner with bertolini pump we can not get max pressure to the hose can you help
Assuming that you have a pressure gauge to determine actual system pressure. Without pressure gauge, you could use the sound of the engine as test for capacity pressure (if engine and pump are paired correctly, engine will labor at full throttle under high pressure). Using your machine at rated capacity will decrease the life of the unit. Better to use at 75 ~ 80 percent of cap. (2500psi on your unit). Pressure is developed thru the restriction of the tip/orifice assuming that the pump is working correctly. Tip should be correct for the capacity of the pump. Check the pump capacity for gpm (or test by removing tip connect water supply, then with engine running, catch water in bucket for exactly one min. and measure quantity). Example, 4 gallon per minuite should use a tip with 4gpm markings. If wrong tip size is used, (too large, low pressure, too small, pump will go into unload condition resulting in low pressure) . If thru testing you determin that the correct size tip is installed, suspect valves or unloader. Leaking valves or orings that seal valves will cause low pressure and also cause a pulsating sensation. Worn unloader will cause pressure to rise and fall in a slow cycle. Good luck with your repair
Apr 26, 2011 | Honda Pressure Washer PSI 3000
03 mk4 vw golf 1.6 petrol 143000kms new tbelt and water pump and thermostat fitted 12 months ago. Fans running full time when engine is running. Overheats when engine is running at low speed ok at high...
Water pump is bad because overheats when engine is running at low speed, and good at high rev. The water pump impeller can not push the coolant with the required pressure.
Apr 19, 2011 | Volkswagen Golf Cars & Trucks
Oil pressure or temperature can cause overheating problem?
Low oil level can cause an engine to run hot but the pressure must be extremely now for that to cause a rise in operating temperature. Naturally, if the temperature is high on the guage, the engine is already overheating, and there are a multitude of reasons why an engine could overheat, from silly things like low tyre pressures to low coolant levels and water leaks. If you like, come back with some more specific information and lets see if we can put a finger on your problem.
Mar 04, 2011 | 1998 Cadillac Catera
Hooked it up with water started engine and no
Apr 04, 2010 | Briggs Stratton 020273 Elite Series...
What is the check gauges light
CHECK GAGES light (1) indicates a potential engine failure(low oil pressure, low coolant, coolant overheating) has occurred.
· Check gages and shut down engine. Gages should read as follows: Oil pressure 5 to 10 psi (34 to 69 kPa) at idle; Water Temp gage below 230 degrees (110 C).
· Check engine oil level (Para 2-11) if OIL PRESS gage indicates low reading. Check coolant level (Para 2-11) if Water Temp gage indicates high reading. Notify Unit Maintenance if levels are low.
If CHECK ENGINE light (2) is on, check engine oil pressure gage (3) and water temperature gage (4). If both indicate normal, proceed with mission and then notify Unit Maintenance. If either one does not indicate normal, stop engine immediately and notify Unit Maintenance
Oct 16, 2009 | 1999 GMC Jimmy
Doesnt build pressure up ,it just runs right without pressure does the compressor require being oiled?
HELLO THERE:
Here is some troubleshooting tips for you and a web link for you ok this should help
best regards michael
Troubleshooting Your Pressure Washer troubleshooting_pressurewasher.jpg General points to check if a problem occurs
  • Are the engine and fuel switches in the “ON” position?
  • When troubleshooting, always check oil and gas levels.
  • The oil for the pump is a 30W non-detergent mineral oil. Do Not fill over halfway on the sight glass.
  • Is the water tap open?
  • Check the choke and throttle levers.
  • Is the correct nozzle in the lance? Is the nozzle plugged?
  • Only the black nozzle is for soaping at low pressure.
  • Is the water-inlet screen clogged?
  • Hold the gun trigger open while pull starting the engine.
  • Check for O-rings in the lance and quick couplers.
  • Has the unit tipped over? Close the fuel switch and keep pull starting the engine until the excess fuel is burnt up, then open the fuel valve and try again. Some engines will need to be primed every time they are started.
  • Make sure the engine is turned off after each use. It should not be left running without use for longer than 2 minutes as the pump can overheat.
Are you experiencing low pressure?
  • Is there an air leak?
  • Dirty pump valves?
  • Check for worn pump valves or broken valve springs.
  • Check for a worn out spray nozzle.
  • Check for leaks in your plumping or hoses.
  • Troubleshoot your nozzle, is it turned to the highest pressure setting?
  • Is the unloader improperly set?
  • Are the engine RPMs too low?
  • Check if your water supply is sufficient.
  • Check if your engine is getting enough power.
Trouble with high vibrations
  • Do you have a sufficient water supply?
  • Is there are in your water supply?
  • Is the inlet water filter clogged?
  • Clogged or damaged spray nozzle?
  • Make sure it has the correct fuel
  • Has the choke been left on after the engine has warmed up?
If the engine won’t start
  • When troubleshooting the engine, check if it's low on fuel or oil?
  • Worn or dirty spark plugs?
  • Is the switch in the off position?
  • Is the fuel valve in the off position?
  • Is the engine flooded from over choking?
  • When cold starting, was the engine properly choked?
If the starter is hard to pull
  • Low oil in the crankcase or pump assembly.
  • Oil or fuel in cylinders (hydro locked).
  • Pressure built up in the system, relieve this by squeezing the trigger.
Sep 15, 2009 | Honda Garden
Pressure washer - My water blaster does not speed up
I was mistaken in my thinking about how the pressure washer works. There is a by-pass valve that takes the load off the engine when you stop spraying. The engine actually runs at a constant RMP. When the spray is on, the by-pass valve closes and this increases the load on the engine. This is what I had been hearing as a "speeding-up" of the engine and was no longer hearing. Anyway, I took the un-loader apart and blew it out with some compressed air. It works fine now.
Sep 12, 2009 | Garden
Diesel engine, grey market kubota, the turqouise
yes there is a low pressure pump and a high pressure(incjector pump) if your no getting fuel to engine check for low pressure pump to be working may also have air in system which is very hard to get out and a diesel wont run untill most or all air is gone
Sep 05, 2009 | 1984 Dodge Caravan
Garden Logo
29 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
