Question about Whirlpool GEW9250 Electric Dryer
Test a thermistor for a Whirlpool Duet dryer - Whirlpool GEW9250 Electric Dryer
  • 36 Answers
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Posted on Dec 16, 2008
lenwest
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
jsrock516
  • 5911 Answers
SOURCE: My whirlpool dryer (Duet) will not heat. What
If your dryer runs, but does not heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop and compare.
If you need further assistance, please post back and let me know. I hope you find this information helpful.
Posted on Dec 23, 2009
SOURCE: Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Posted on Jan 19, 2010
heatman101
  • 43501 Answers
SOURCE: whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Apr 06, 2010
Testimonial: "Thanks, so now how do I get the extended warranty plan to pay for it. They will not send someone out for squeaks and squeals. "
Whirlpool duet dryer GEW9200LW1 heats
If the element was replaced, and now verified that it is not presently shorted to ground, your next diagnostic would be to to test the timer connections per the schematic lookiong for a fused contact that energizes the heater, while set to air fluff setting.
Apr 08, 2014 | Whirlpool Dryers
Whirlpool duet dryer goes to sensing..but wont turn on
The control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box. Here is the part to order.
Nov 26, 2012 | Whirlpool Dryers
The dryer shuts off, keep getting an E1 code, what needs to be done
It sounds like this is a Whirlpool Duet or a Kenmore Elite Dryer due to the error code E1 being available only on this models. The problem here is an open thermistor as what error code E1 means. It's either the thermistor is exhibits an extremely high resistance or the wire harness connecting it to the control board is broken or cut open. Click on the link below for the detailed procedure in accessing the thermistor.
Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Measure the resistance of the thermistor and refer the table below. Normal thermistor resistance is around 10000 ohms (10K) at room temperature.
Replace the thermistor if the resistance is significantly higher (or lower) than what it is supposed to be based on the resistance table above. Check the wire harness connecting it to the control board, if the resistance turns out good, and make sure the connectors are good and the wires are intact. Replace the wire harness if necessary. Consider replacing the control board if both the thermistor and the wire harness turn out good. The link below might enlighten you further on the troubleshooting of the thermistor.
Thermistor Troubleshooting on Whirlpool Duet and Kenmore Elite Dryers
Aug 21, 2011 | Dryers
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
I get an E1 code on a whirlpool duet dryer. What could the problem be.
The problem is the control thermistor being detected open by the electronic control. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values. Click on the link below for the detailed troubleshooting procedure.
Troubleshooting Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
Feb 04, 2011 | Whirlpool GEW9250 Electric Dryer
First I had an E1 code, replaced the Thermistor then E2
check the ribbon cable to and from the control board for small breaks and make sure to clean the contacts gently by removing and replacing the cable too,try this
Aug 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Duet 9250 dryer. Won't start up. I did bridge
try the door switch. in some models you can jump the wires to see if it starts.hope this works.
Jun 23, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer runs and heats well for 4-5 minutes then shuts off. it has a light that flashes E1. what is the problem??
E1 THERMISTOR OPEN "E1" flashes if the thermistor is open.
Check your wire connections on your thermistor and your control board. If they (connections) are good you should replace your thermistor. If you would like more detailed instructions in performing the "THERMISTOR TEST" post back here and I will find you a manual or find a way to scan you mine. Or, you can merely remove the top of your dryer and inside you will find the TECH SHEET giving you detailed instructions on this test and many more.
Cheers
Dave
Jun 07, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer (5yrs old)
An E1 Code is a thermistor fault TEST #3a Thermistor Test
The machine control electronics monitors the
exhaust temperature using the thermistor, and
cycles the heater relay on and off to maintain
the desired temperature.
Begin with an empty dryer and a clean lint
screen.
1. Plug in dryer or reconnect power.
2. Set the following configuration:
➔ Door – must be firmly closed
➔ Press Control On
➔ Press End Of Cycle Signal (Louder)
➔ Press Start
3. If after 60 seconds, E1 or E2 flashes in the
display and the dryer shuts off, the thermistor
or wire harness is either shorted or open.
➔ Unplug dryer or disconnect power
➔ Check wire connections at the machine
control electronics and thermistor.
To access the Thermistor you will need to open the bottom front panel 2 screws the thermistor is on the exh duct (Center) check it there let me know if you need futher help
Nov 10, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
60 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
